Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Compact Digitals by Canon
Reply
Thread Tools Display Modes
Old 6th of August 2002 (Tue)   #1
palmos
Default A40 AVI
Hi,
Just bought my A40 and a 128mb CF card, i thought i should be able to record about 5 minutes of high resoulution avi, but after 10 sec. it stop recording!?
Is 10 sec. the limit per recording or what?
Regards
Jens
palmos is offline   Reply With Quote
Old 6th of August 2002 (Tue)   #2
brutal
Default Re: A40 AVI
on a 128 card you should be able to record 305 seconds in 320 mode.
Did you format the card before using? Does the camera tell you what size card you are using?
If you go into any record mode and click menu then scroll over to the little tool icon it will have an item called CF and it will say the formatted size of the CF.
brutal is offline   Reply With Quote
Old 6th of August 2002 (Tue)   #3
palmos
Default Re: A40 AVI
Yes, i formatted the card as the first thing.
I both tried to click the record button once, and to hold it in, but still it stops after 10 secs!
Old 6th of August 2002 (Tue)   #4
brutal
Default Re: A40 AVI
When you take an AVI press once and release and then press the shutter button again to stop.
Maybe by holding the button down it is causing that.
Old 6th of August 2002 (Tue)   #5
Conk
Conk's Avatar
Default Re: A40 AVI
Page 65 of your A40 manual says,
Your new A40 will only record about 10 seconds (approx 20 frames per sec.) at a time when set to 320x240 and about 30 seconds at the 190x120 setting.
You can keep recording segments and edit the segments with Videoimpression.
Conk is offline   Reply With Quote
Old 7th of August 2002 (Wed)   #6
nuno
Default Re: A40 AVI
Hi ! I just bought a A40 and with a 64 Mb CF i could record a 22 seconds AVI ! 320x240 !
my package come with arcsoft software !
Video impression and photo impression !
Does anyone know where i can get photostich
to make panoramic photos ?
nuno is offline   Reply With Quote
Old 7th of August 2002 (Wed)   #7
palmos
Default Re: A40 AVI
Thanks for your answers, i read the page 65 again, and now i see it is not a videocamera i bougt.
Old 7th of August 2002 (Wed)   #8
brutal
Default Re: A40 AVI
the way I read the manual, I thought everything was referenced for the 8meg card. I'm gonna have to try that now.
Old 10th of August 2002 (Sat)   #9
Xizor
Default Re: A40 AVI
The camera has to have some sort of really fast internal memory. I think the deal with taking movies is that you can only shoot up to what the memory can hold. This *usually* results in 10 second movies in 320x240 and 30 second movies in the lower resolution. Because of the way compression works, however, you sometimes may be able to record for longer while other times not as long.
Xizor is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Downloading AVI from G7 amoeba Canon G-series Digital Cameras 3 16th of June 2007 (Sat) 06:21
Convert canon .avi to windows media .avi for use in Adobe kwort Canon G-series Digital Cameras 2 24th of April 2004 (Sat) 06:25
emailing AVI clips (A40) rmrm Small Compact Digitals by Canon 11 20th of January 2004 (Tue) 03:30
Can't play AVI files exported from A40 uniques Small Compact Digitals by Canon 2 21st of December 2002 (Sat) 17:03
Uploading AVI files to A40 camera tanloa Small Compact Digitals by Canon 0 2nd of December 2002 (Mon) 20:18
