Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > RAW, Post Processing and Printing
Reply
Thread Tools Display Modes
Old 6th of September 2004 (Mon)   #1
Longwatcher
obsolete as of this post
Longwatcher's Avatar
Default Canon photo stich versus PS_CS photo merge
Sorry no pictures even the jpeg was 21meg in size.
I finally figured out where photo-merge in PS CS was hiding (I know it was in plain sight, but I didn't think to actually look there for it.
So I decided to see what happens when I try stiching together a set of images that did not work at all well in Canon photo stich. While it did not work perfectly, it worked way better. What I don't like is I could not find a way to adjust the one or two images (out of 10) that were mis-aligned (probably because my model moved ever so slightly). This is one area where I can get photo stich to work well. So if anyone knows how to correct a single image in photo merge, please feel free to let me know.
I like the way photo stich works overall (although I hate having to save my RAW to 8 bit TIF first (at least PS CS does this automatically) in that I place the images where I want them. What doesn't work in photo stich is that I can't have only one image on the bottom if I have 3 images on every other row, whereas, PS CS had no problem with this.
PS CS did seem to do a much better job on first go round, but until I can figure out how to correct an image after the fact kind of annoying. I will admit I did not try to stich the images in using manual mode, so that may end up working better.
My other annoyance with Canon photo stich is it has issues if you are not between 15 and 25% overlap. Less then that and it just won't get it and more and it seems to get confused.
I was also considering actually purchasing some stiching software, but it is low priority for me at this time.
The features I want are as follows if someone has used something that match all of my criteria let me know.
1. take in 16 bit RAW, I will settle for 8 bit TIF.
2. I like the way PS CS just let me select from the file list and then made a first attempt at it.
3. I like photo stich's ability to correct a single image by showing the boundary and then letting match a boundary between two images
4. I also like photo stich's placement for the images (although it seems is may be unnecessary in PS CS)
5. Lastly I want it to let me correct an individual images color balance (or image matching) speparately, but while still viewing it in comparison to the adjacent images. Or to have it do a better job of correcting the image versus the adjoining images.
Thanks, any help appreciated.
PS. I won't see any replys until Friday at the earliest since I am traveling this week.
"Save the model, Save the camera, The Photographer can be repaired"
www.longwatcher.com
1DsMkIII as primary camera with f2.8L zooms and the 85L
http://www.longwatcher.com/photoequipment.htm
Longwatcher is offline   Reply With Quote
Old 14th of September 2004 (Tue)   #2
rmhunt
Default
Try this sight and see if it fits your needs. I've used PS Merge and PTA and like them both. PTA works well for complex stitching.
http://www.tawbaware.com/ptasmblr.htm
rmhunt is offline   Reply With Quote
Old 14th of September 2004 (Tue)   #3
TonyKInTexas
Default Re: Canon photo stich versus PS_CS photo merge
I just did a comparison between these and RealVIZ Stitcher and I like PSCS Photo Merge best.
In the past I used PanoTools with PT Assembler. That combination produced good results for me. A lot of trial and error though.
TonyKInTexas is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Photo-merge - Aston wallisj Transportation 1 19th of January 2007 (Fri) 08:47
photo merge...the secret OceanRider RAW, Post Processing and Printing 28 11th of July 2006 (Tue) 20:15
help with photo resize merge can this be done? scott stokes RAW, Post Processing and Printing 7 9th of January 2006 (Mon) 17:43
Poster versus photo tarves57 RAW, Post Processing and Printing 3 10th of May 2004 (Mon) 13:05
