| sponsored links |
#2 |
Admin - MOD OF STEEL...
User Settings and Custom Functions Threads -=EOS 1D Mark III - User Settings and Custom Functions=- -=EOS 1D Mark II - User Settings and Custom Functions=- -=EOS 20D - Best CUSTOM FUNCTIONS and Settings=- -=EOS 10D - User Settings and Custom Functions=- -=ARTHUR MORRIS ON USING AI SERVO AND C.FN-04 =- -=The CFN #4-1 Thread=- Last edited by CyberDyneSystems : 4th of March 2008 (Tue) at 12:08. |
#3 |
Moderator
Slayer of Trolls Join Date: Jun 2004
Jon ---------- EOS, PowerShot and Domke - it doesn't get any better than this! T90 and stuff | F-1n, New F-1, FTb and more stuff out on loan Image Posting Rules and Image Posting FAQ Maryland and Virginia activities Report SPAM, Don't Answer It! (link) Marketplace Changes *** IMPORTANT! *** |
| sponsored links |
#4 |
Moderator
#5 |
All About Canon's Auto Focus Sensors.
I am not an expert but I play one on the internet... Facts: 1. Canon has four terms its marketing department uses to describe its AF sensors. High precision, Cross Type, Sensitive (vertical or horizontal), and Regular Precision. 2. A sensor that will work up to f5.6 also works all the way to f2.8. One that works up to f2.8 is BETTER than one that STARTS at f5.6 for its sensitivity. Some people want f8 sensitive. I would not want it. Ok now that you are familiar with Canon's terms let look at what the cameras offer. 350D = No cross type or High precision sensors. 30D = Only the center point is Cross type & High Precision. That is two things. The others are just like the 350D. 40D = Only the center point is Cross type & High Precision. The others are Cross Type with their sensitivity beginning at f5.6. In other words they are not Canon's best but better than before. 1D Mark III = 19 Cross Type & High Precision AF points beginning their sensitivity at f2.8! Now that is a Camera!!! Please STUDY these: 20D http://www.canon.com/camera-museum/tech/report/200409/report.html 5D http://www.canon.com/camera-museum/tech/report/200509/200509.html 30D http://www.canon.com/camera-museum/tech/report/200603/report.html XTi http://www.canon.com/camera-museum/tech/report/200609/200609.html 1D Mark III http://www.canon.com/camera-museum/tech/report/200703/200703.html Last edited by CyberDyneSystems : 27th of September 2007 (Thu) at 15:29. |
#6 |
I asked chuck westfall about any tips for microadjustment on mark3 since the manual is super vague about it and here was his response -- he has given me permission to publish it online here however he will most likely have this answer on his techtips one day:
-----Original Message-----so there ya have it folks.... http://digitaljournalist.org/archive....html#westfall Last edited by Pekka : 13th of June 2008 (Fri) at 17:47. Reason: layout, tech tip url |
#7 |
I specialize in photographing birds in flight and I make a living teaching others how to do the same. One of the techniques I use I call bumping the focus. This technique is often mis-understood and I get alot of questions about it. I just finished a lengthy answer to a question in another thread, so I thought it would be usefull to post my answer here as well where it would be easier for folks to find in the future. Here it is:
There are three different uses for the bump focus technique. I will try to explain each of them below. By bumping I simply mean letting off the focus and then refocusing quickly. 1. The first reason to bump the focus is to prefocus. The first task when photographing a BIF is to aquire it in the viewfinder and focus on it. It is beneficial to be able to do this as quickly as possible. When using long focal lengths, the bird may be so out of focus that you can't see it in the viewfinder even if it's there. Then when you do get it in the viewfinder it may take much longer to focus on it if the foicus is set to a drastically different distance. To overcome these issues, I will prefocus at the approximate distance that I anticipate for my subject. Then when the subject arrives, I can find it and focus on it quickly. I prefocus the camera by pointing the camera at something at the desired distance and then I focus on it. Now I'm ready for a BIF at a similar distance. If I need to switch the distance I will simply point the camera at something at the new distance and bump the focus. This will prefocus the camera at the new distance. Photogs that use a tripod will often prefocus manualy. Since manual focus is difficult hand held with big glass, I use the bump to prefocus. 2. When I am tracking a BIF against a varied bg and I miss and focus on the bg I will bump the focus to quickly return focus to the bird. Bumping the focus overrides the delay set by the tracking sensitivity custom function. Iset this tracking sensitivity to slow to get thelongest delay possible. This heelps when you are focused on the bird and want to avoid focusing on the bg, but it hurts when focussed onm the bg and you wantg to return focus to the bird. Bumping the focus overrides the delay. 3. This is the most important use of the bump technique. Most photogs will aquire focus on a bif and then try to continously maintain foucs while they are tracking and watching the bif in the viewfinder. They tend to focus continuosly waiting for the moment they wish to make a photograph. Often while watching, tracking, and waiting for the moment, the photographer will miss and focus on the bg. This is extremely easy to do when the bif is flying against a varied bg. This is the reason it is so much more difficult to photograph BIF against a varied bg as opposed to smooth sky bg. When the focus grabs the bg, then the photographer needs to re-aquire focus on the bif. This may take too much time causing the photog to miss the critical moment. I try to avoid this by only focusing on the BIF when I'm sure I'm on target and during the critical moments when I'm acualy making images. So, what I will typicaly do is aquire the bif initial and focus on it. Then I will let off the focus and just watch it in the viewfinder while tracking it visualy only. As the distance changes, the BIF will start to go out of focus. When that happens I bring it back in focus by quickly making sure the AF point is on the biurd and then I bump the focus to get it in focus again. I do this repeatedly as I'm visualy tracking the bird. When the BIF gets to the spot I want to start making pictures, I wil focus and shoot all at once. I shoot in short controlled bursts trying to time the critical moments with the best wing positions, etc. Because I have bumped the focus along, the focus is very close to where it needs to be when the moment to make pictures arrives. Then when I focus and trip the shutter it happens very quickly. If I tried to focus constantly while the bif approached I would likely miss, focus on the bg, and miss the critical moment. My goal is to keep the bird close to in focus and in the viewfinder without focusing on the bg and to do this up until the critical moment arrives. Then I try to maintain the focus while making great pictures. Bumping takes lots of practice, but if you develop this skill, it will make your keeper rate go way up.
Jim Neiger Kissimmee, Florida Please visit my website and subscribe to my mailing list Website: www.flightschoolphotography.com |
#8 | |
------------------------------- There's much more to shooting in manual mode than just turning the dial to M and playing with the settings. I think it is actualy easier to learn to make consistantly good exposures in M mode than it is in any of the auto modes, if you learn M mode initialy. If you learn in Av mode, than you sort of have to unlearn Av mode before you train your brain completely in M mode. To make consistantly good exposures in manual mode I do the following: 1. Choose a constant in the environment that is generally available to use as a base measure for metering. For me, in FL, this is usualy a deep green vegetation. The important thing is that it's usualy available. 2. I fill the frame with the constant while looking thru the viewfinder. The constant needs to be in the same light that I anticipate the subject being in. (I'm using full frame evaluative metering - EV) 3. I compare the subject to the constant to come up with an exposure compensation amount. 4. I dial in the exposure compensation amount I want by manipulating one or more of the three knobs that control exposure. This is done while filling the viewfinder with the constant in the same light as the subject will be in. Now, if I have chosen the correct compensation amount, I should have the exposure that is correct until one of two things happens. 1. The light changes, or 2. The subject changes. When one of those two things happens, then I repeat 1-4 above. Use the histogram and flashing highlight alert to help you evaluate your exposures and adjust your compensation values. Learning to select the appropriate compensation amounts is a matter of experience. Developing this experience in manual mode is much easier because you are constantly forced to evaluate how you have done and you have eliminated many of the variables that are involved with exposure compensation in other modes. Eliminating factors simplifies the process which is why it's easier to learn in manual mode. Manual mode also forces you to be more aware of the light and it's effect on your images. This will improve your photography in many ways.
#9 |
What is "HAMSTTR"**© ?
"HAMSTTR"© ( Histogram And Meter Settings To The Right )hamster.gif ...Is a more accurate term to describe what we really mean when we say we "Expose To The Right" or ETTR. (from this point on I will use only the term HAMSTTR. Suffice it to say, that the term is new, and prior to August 2009 the universally used term to describe HAMSTTR was "ETTR" )A brief History of "HAMSTTR"©.
The advantages are several.
So far so good, now fast forward to August 2009 and a simple question regarding ISO settings posted on POTN results in a 20 page long debate re: use of the word "exposure"The trouble with this? Two fold: 1. It's true!Use vs. Definition It was then suggested that a new term need be applied for the "other half" of our ETTR adjustments, the ISO settings. This term proffered is ITTR for "Iso To The Right" Further Reading on "HAMSTTR"©** *In the following articles, please substitute "ETTR" and "Exposure" with "HAMSTTR©" and "Histogram and Meter" as all these guys are wrong. And it's early impact on POTN with some threads I found circa 2004; Scottes On E (HAMS)* TTR:Discussion Thread; http://photography-on-the.net/forum/...03#post8534003 hamster.gif ** The term HAMSTTR© is copyright © CyberDyneSystems 2009
-DRY SEASON- 21 days across Namibia and Botswana Main Gallery GEAR LIST CDS' HOT LINKS My POTN Share Threads Are you shooting HAMSTTR©? ".. It's the customer support Stupid... ... Last edited by CyberDyneSystems : 27th of August 2009 (Thu) at 16:31. |
| Thread Tools | |
| Display Modes | |
| -= FAQ & IMPORTANT LINKS =- (Read Me First) | Scottes | RAW, Post Processing and Printing | 21 | 30th of December 2009 (Wed) 21:03 |
| -=FAQ=- Images and Avatars, How, Where and Why -=FAQ=- | Jon | Forum FAQ - READ HERE FIRST (read only) | 6 | 8th of August 2009 (Sat) 15:08 |
| -=FAQ=- Teleconverter/T-Con Tele extender FAQ | CyberDyneSystems | Canon EF and EF-S Lenses | 18 | 17th of June 2009 (Wed) 10:21 |
| FAQ - What studio lighting? - ** READ THIS FIRST ** | tim | Small Flash and Studio Lighting | 20 | 8th of January 2008 (Tue) 14:34 |
| FAQ - EOS Flash - ** READ THIS FIRST ** | scottbergerphoto | Small Flash and Studio Lighting | 40 | 7th of January 2007 (Sun) 12:01 |
