Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Compact Digitals by Canon
Reply
Thread Tools Display Modes
Old 9th of August 2002 (Fri)   #1
CastorX
Default IXUS V2 - WEBCAM
Is anybody know if it is possible to use an IXUS V2 as a webcam ? Do you know how to do this ?
Thank you
CastorX
CastorX is offline   Reply With Quote
Old 9th of August 2002 (Fri)   #2
Rustle
Default Re: IXUS V2 - WEBCAM
Sorry, CastorX, but it doesn't work. All the Powershots use the same driver and it's not built for that type of output. For details, do a search on 'webcam'.
Russ
Rustle is offline   Reply With Quote
Old 28th of November 2002 (Thu)   #3
sylvestor3
It seems like you can use the s200 as a webcam.... check out this link:
http://www.expressresponse.com/cgi-b...&submit=Search
sylvestor3 is offline   Reply With Quote
Old 1st of December 2002 (Sun)   #4
kintaro
Its possible, but ONLY if you have a Graphic card with a Video Input.
I have one (The leadtek a250 ultra TD geforce 4 ti 4600 myViVo), and directed the camera video out into my computer video in -
only problem is that the battery runs down in 40 minutes...
kintaro is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Using an IXUS II as a webcam - is it possible ? lemac Small Compact Digitals by Canon 2 9th of February 2004 (Mon) 00:47
IXUS v2 as webcam? fenrus Small Compact Digitals by Canon 2 22nd of October 2003 (Wed) 07:59
Ixus v3 webcam? JohnFHarrington Small Compact Digitals by Canon 0 18th of September 2003 (Thu) 06:21
Using IXUS 400 as webcam lazymanc Small Compact Digitals by Canon 0 8th of May 2003 (Thu) 21:18
canon ixus v used as webcam... ruffe2 General Photography Talk 4 26th of August 2002 (Mon) 08:29
