#1 |
User is banned from forums
I dont like how narrow the neck strap on the 1D is and i can tell it's been used a lot. Any of you ever bought a 3rd party strap they'd recomend?
| sponsored links |
#2 | |
Admin
#3 |
TQ,
I recently bought a Tamrac strap and I like it. It has a soft flexible strap around my neck and it is very comfortable, especially over a long period of time and when it is hot out. I don't know the model number but I bought it from Calumet Photo and I recommend it Dan |
| sponsored links |
#4 | ||
#5 |
Wait, all that time and all I get is "Cream of the Damn Crop" ?!!!!!!!!!!!!!!!!
I have an Op-tech on the MkII.. makes it ten times easier to leave around the neck.
Lowepro makes a good knock-off of the Op-tech too... that's on my 10D They are both neoprene.. a soft black flexible rubberlike material (like a wet suit) that just has no "teeth" to bite you with. Very comfortable. |
#6 |
The main thing i want to avoid is the "rash" i get from the cloth straps that i have. I guess anything rubbing against your neck for long enough is gonna have ill-effects, but i'd like to minimize them.
#7 |
Moderator
Oh just go and buy an OpTech. It's the best there is.
I can happily wander about with 10D, Big-Ed and 100-400L round my neck with one of those on the camera. |
#8 |
CDS,
That is the material I was trying to describe w/ the Tamrac strap I was talking about. I didn't explain it well but you hit it on the head. Just giving options. I'll have to look up the Op-tech strap you explained to see the difference. I'm also looking for a wrist strap since I've seen threads about those and I've seen that they are recommended. Does anyone use both a neckstrap and a wriststrap at the same time? Seems like a lot of stuff hanging off of the camera at one time but it could be usefull. Dan |
#9 |
Its got to be Op-Tech!!
#10 |
I have the Op/Tech Pro Loop strap. It's very comfortable with my 10D and an 80-200/2.8L suspended.
Steven 7D, 10D, 17-40/4L, 50/1.8 Mk I, 85/1.8, Tamron 28-75/2.8, 28-135/3.5-5.6 IS, 80-200/2.8L, 550EX, Pocket Wizard |
#11 |
Admin
One thing about Op-Tech straps is they have little rubber 'bumps' on the underside of the strap that reduce slipping. Around the neck, that's not important, but if carrying it over your shoulder, it's a big deal. There are several other straps available with similar construction and they all seem to use the same or similar material.
BTW, Op-Tech refers to their straps as "Weight Reduction Systems." I was a bit skeptical at first, but I'm a believer now. |
#12 |
Trigger Man - POTN Retired
OpTech.
You can take my 100-400 L away when you pry it from my cold, dead fingers. Scottes' Rum Pages - Rum Reviews And Info Finally, I have a Gallery! Follower of Fidget - Joined the cult of HAMSTTR© |
#13 |
My camera's neck strap doesn't spend much time around my neck. Most of the time it is wound around the tripod head (so as to prevent a long unexpected drop).
---Bob Gross--- |
#14 |
OP-TECH PRO!!! Get it in black with the rubber grips on the opposite side.
Best 20-30 dollars I've spent. Ro1 |
#15 | |
Thats just my first impression at least. |
| Thread Tools | |
| Display Modes | |
| Neck straps | miralee | Accessories & Storage | 28 | 6th of July 2007 (Fri) 05:38 |
| POTN Neck Straps | kampphoto | Accessories & Storage | 113 | 15th of April 2006 (Sat) 14:16 |
| We've got POTN neck straps... other stuff? | elbirth | The POTN Lounge | 1 | 14th of July 2005 (Thu) 18:35 |
| Neck Straps | mvonditter | Accessories & Storage | 8 | 6th of June 2005 (Mon) 12:31 |
