Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Critique Corner
Reply
Thread Tools Display Modes
Old 10th of September 2004 (Fri)   #1
nighthawk
Default Apache Point Observatory
I like it, but I'd like to make it better. Any thoughts? This is un-retouched.
I forgot to Post the EXIF:
EXIF Image Details
Width: 3072 pixels
Height: 2048 pixels
Focal Length: 28 mm
Compensation: 0 steps
ISO Speed: 1600
Date: 2004-09-05 18:19:20
Cannon EOS Digital Rebel
Tamron AF 28-200 Super Zoom Lens
Circular Polarizer Filter
I was taking some low-light photos just before of a deer in deep shadow and forgot to reset the ISO setting apparently
nighthawk is offline   Reply With Quote
Old 10th of September 2004 (Fri)   #2
Molydood
Default
maybe if you moved yourself to the left a bit whe taking the shot, the tree wouldn't have obstructed the dome section that little bit. I like the image a lot, but that little thing bugs a tiny bit. I never know if it's ok to offer comment on positioning, once the shot has already been taken?
My real name is Martin
20D (FS 300D), fifty, 18-55, 70-200 f4, tubes
Molydood is offline   Reply With Quote
Old 10th of September 2004 (Fri)   #3
nighthawk
Default
No, it's fine to suggest postitioning changes after the fact. I'll keep it in mind for next time. I was concentrating on how the light was hitting the dome and my lens. The sun and vantage point was a little limiting for this shot. I was also going for the hich-tech geometry juxtaposed on the natural surrounding. Not an excuse, just what I had in mind.
Old 12th of September 2004 (Sun)   #4
Big_B
Honorary Moderator
Big_B's Avatar
Default
Thoughts:
- I really like the coulours. The tower blends from white to blue, as does the sky. The effect is very complementary.
- I find all the trees rather distracting because IMO they distract from the simplicity of the colour contrasts. Perhaps you should add an axe to your photography kit
www.pbase.com/sam_blackie
Big_B is offline   Reply With Quote
Old 12th of September 2004 (Sun)   #5
Sailor Don
Default Good photo
Nighthawk,
The techincal aspects of the photo appear to be about the best you can get, with the observation you made that the ISO could have been reduced for better pixel level image quality. But at this resolution, it looks OK.
The picture seems to be "weighted" to the left with the large tree in the center and the observatory on the left side. Did you try any shots from a position to the left? Maybe that would have been shooting to much into the sun. Just a thought that it would have created a better balanced image if the big tree were separated more from the observatory.
Sailor Don
Sailor Don is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Griffith Observatory after the fire Tee Why Nature & Landscapes 6 1st of June 2007 (Fri) 15:31
Hancock Observatory in Chicago BB18 Nature & Landscapes 1 15th of April 2007 (Sun) 07:44
Lick Observatory - Mt. Hamilton, CA. Wsman2 Nature & Landscapes 8 27th of March 2007 (Tue) 18:19
griffith observatory overlooking LA shmoo597 Urban Life & Travel 6 17th of January 2007 (Wed) 16:22
Palomar Observatory Steve Parr Nature & Landscapes 4 8th of January 2006 (Sun) 15:03
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
