Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EOS Digital Cameras
Reply
Thread Tools Display Modes
Old 11th of September 2004 (Sat)   #1
MrKickalot
Default 8 or 16 bit?
I just got PSCS and opened a RAW that I took today of a Blackhawk helicopter and for the first time I could choose 16 bit tiff (was using C1 with 8 bit). Did my usual sharpening and slight color correction and saved... then almost crapped my pants!!! 47 MB file!! That can fill a hard drive real quick!! Questions... Do I need to use 16 Bit tiff (most prints 8X10 or smaller)? Do you keep your Tiff files after correction or do you convert to JPG and trash them to save space??
P.S. I need confirmation on this... is it true that you can save TIFF files as many times as you want without loss?
MrKickalot is offline   Reply With Quote
Old 11th of September 2004 (Sat)   #2
cecilc
cecilc's Avatar
Default Re: 8 or 16 bit?
Yes, that's true.....
I shoot RAW and convert to 16-bit tiffs, too (which usually get converted to jpgs at some point either for the web or for some other printing). But after I'm done with that "job", I'll save everything I've done with those images - RAW files, tiffs, jpgs - to DVD. You don't have to keep it all - but I'm a pack-rat - I keep everything.
Cecil
SportsShooter Portfolio
cecilc is offline   Reply With Quote
Old 12th of September 2004 (Sun)   #3
Doom1701e
Doom1701e's Avatar
Default
Again, yes you can save TIFFs over and over without any loss. TIFFs use a lossless compression. I always shoot raw and then save to an 8-bit TIFF. Here is something I learned with printing TIFFs. Fuji Frontier Printers (Alot of instore photo labs) can not read a 16-bit TIFF. So you either have to use an 8-bit TIFF or JPEG to have them printed at a local photo lab, so, I always save to 8-bit TIFF. I also save everything to DVD when my computer starts to get full. I actually make 3 copies of the DVD. Remember, these digital files are like your negatives, if you lose them, they are gone forever.
Doom1701e is offline   Reply With Quote
Old 13th of September 2004 (Mon)   #4
scottbergerphoto
scottbergerphoto's Avatar
Default
The real issue is what form should the file be in for editing. Once you are sure the file will never be edited again it doesn't matter if it's jpeg, 8 or 16 bitt tiff. For editing, you want 16 bit tiff.
I also keep my Raw, 16bit Tiff, and jpeg for Web on DVD. I only keep the files I'm working on on my HDD.
Regards,
Scott
One World, One Voice Against Terror,
Best Regards,
Scott
ScottBergerPhotography
scottbergerphoto is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
format for printing and 16 bit, 32 bit, etc. azpix RAW, Post Processing and Printing 1 16th of November 2006 (Thu) 02:40
Which version of Noise NInja - 8 bit or 16 bit? Mike Bell RAW, Post Processing and Printing 5 18th of February 2006 (Sat) 13:41
Converting from 16 bit Tiff to 8 bit Jpeg? dennykyser RAW, Post Processing and Printing 3 8th of March 2004 (Mon) 11:03
More colors in 8 bit JPG than in 8 or 16 bit TIF with Digita The Photo Tuell RAW, Post Processing and Printing 8 27th of September 2003 (Sat) 15:21
16 bit linear tiffs to 8 bit question gary shepard RAW, Post Processing and Printing 2 23rd of November 2001 (Fri) 13:07
