Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Transportation
Reply
Thread Tools Display Modes
Old 22nd of December 2007 (Sat)   #1
FnsweetS3
FnsweetS3's Avatar
Default Photographing Pearl paints and ghost flames
I have a friend who wants to get his car photo'd..... I shot a few test shots just to see what I was working with.
His car has something called Diamond ice in the paint.... it give it that "sparkly appearance" it also makes his car look two different colors. He also has very lite ghost flames that if the sun is out you can see... but if the clouds are out...
they are gone.
I am open for suggestions...
Here is one shot...
http://www.carhosting.com/roush/images//FNSide1.jpg
Canon EOS 20D w/Canon EF-S 18-55mm USM and CANON EF 24-105mm f/4L USM
FnsweetS3 is offline   Reply With Quote
Old 22nd of December 2007 (Sat)   #2
Mike Reynolds
Mike Reynolds's Avatar
Default Re: Photographing Pearl paints and ghost flames
Try very large reflectors late in the afternoon on a clear day. Focus the reflector until the ghost flames appear and you got it. Good luck
a special thanks to the Big Guy upstairs
http://mikereynoldsmotorsports.com/
my gear
http://photography-on-the.net/forum/...&postcount=289
Mike Reynolds is offline   Reply With Quote
Old 22nd of December 2007 (Sat)   #3
89AKurt
89AKurt's Avatar
My guess is late also, when the sun is low it should react with the pearl. Overhead light is always the worst time IMO.
It's just a little camera. Flickr
89AKurt is offline   Reply With Quote
Old 23rd of December 2007 (Sun)   #4
PhotosGuy
Moderator
PhotosGuy's Avatar
My experience, too. Crappy results with exotic paint on a great car: '68 Plymouth GTX 572 "Tennessee Thunder"
Late sun helps. Better, but with a pole & limited angles to shoot from:
'68 Plymouth Road Runner 500cid
If you can get the light at the right angle in the side:
Some shots of Jim's '68 AMX
Seen this?
A few Car Lighting Tips - Updated
And, sorry, but in the "Share" areas IMAGE POSTING RULES only allow 8 embedded images by the OP per thread. (Maximum 800 pixels on any side.), so I had to remove the image tags from the extra shots. Links to them are OK, though.
Some exceptions are "Show Me...", "Post your best...", etc.
www.FrankCizek.com
PhotosGuy is online now   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Need to shot paints all framed, with glass. Advice needed. tiziano General Photography Talk 11 7th of March 2007 (Wed) 06:02
affordable airbrush paints? bolantej The Business of Photography 2 16th of October 2006 (Mon) 19:50
Flames Yellow_Fuzzy Still Life, B/W & Experimental 4 12th of November 2005 (Sat) 05:18
Up in flames RiverRatt Transportation 11 30th of August 2005 (Tue) 10:36
Lyson Cave Paints Bodog RAW, Post Processing and Printing 1 29th of March 2005 (Tue) 21:30
