Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > General Photography Talk
Reply
Thread Tools Display Modes
Old 25th of December 2007 (Tue)   #1
Mike-DT6
Mike-DT6's Avatar
Default Trying To Make Sense Of Auto-Focus and Manual Focus! (20D)
EDIT: Unfortunately all my original image links are now broken. My photographs are now hosted at Flickr and on my website. Links to both of these sites are in my signature section.
Apologies for any broken image links that are now showing in any of my threads or posts.
Thanks,
Mike
Gear | Flickr | Website | Twitter
If at first you don't succeed, lose your temper and smash it to pieces.
Mike-DT6 is offline   Reply With Quote
Old 25th of December 2007 (Tue)   #2
Mike-DT6
Mike-DT6's Avatar
Default Re: Trying To Make Sense Of Auto-Focus and Manual Focus! (20D)
Thanks,
Mike
Old 25th of December 2007 (Tue)   #3
Doug Pardee
The first thing to be aware of is that there isn't "an infinity" point in the focus. There is a range, marked with an L-shaped line, depending on the temperature. At normal temperatures the infinity focus point will be near the "corner" of the L, not near the lemniscate (infinity symbol). This picture from Canon shows the lens set (approximately) to infinity at normal temperatures:
Second, autofocus doesn't use the distance scale. The camera measures the amount that the image is out of focus and tells the lens to correct for that. Even if the distance scale is incorrect, the lens might very well end up focused reasonably close to the correct distance. Of course, if the distance scale is incorrect there could be other problems with the lens, too.
Doug Pardee is offline   Reply With Quote
Old 25th of December 2007 (Tue)   #4
Mike-DT6
Mike-DT6's Avatar
Thanks,
Mike
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Do you use auto focus or manual focus more? sinitry23 Canon EF and EF-S Lenses 9 21st of September 2007 (Fri) 11:04
Auto Focus or Manual? WyzMan Canon EOS Digital Cameras 16 24th of August 2005 (Wed) 13:49
Manual focus or Auto? MrGibbage General Photography Talk 9 15th of July 2005 (Fri) 01:32
manual vs auto focus transcend Canon EOS Digital Cameras 17 19th of November 2004 (Fri) 18:24
Manual Focus vs. Auto-Focus jimmyd Canon EOS Digital Cameras 3 15th of September 2003 (Mon) 17:09
