Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Still Life, B/W & Experimental
Reply
Thread Tools Display Modes
Old 31st of December 2007 (Mon)   #1
eesparx
eesparx's Avatar
Default Quasi Infrared
Experimenting with a quasi infrared effect. Before image processed entirely with Lightroom; after image extremely enhanced with CS2 & then tweaked again with Lightroom. Vignetting is intentional.
I know the first image needs more work.
C & C most welcome.
Before
After
eesparx is offline   Reply With Quote
Old 1st of January 2008 (Tue)   #2
Mike-DT6
Mike-DT6's Avatar
Default Re: Quasi Infrared
Interesting experiment. I like the first shot. I'm not so sure about the second one because it emphasizes the snowy mountains even more and reduces even further the perceived depth of the photograph.
Mike
Gear | Flickr | Website | Twitter
If at first you don't succeed, lose your temper and smash it to pieces.
Mike-DT6 is offline   Reply With Quote
Old 2nd of January 2008 (Wed)   #3
lehayes
lehayes's Avatar
Nice photo, hope you don't mind me playing. Here's a version using the infrared filter under the Black & White adjustment layer in Photoshop CS3, plus a little tweaking with the dodge tool.
Larry
Midwest Freelance Photography
Canon IR Digital Rebel, 20D, 40D, 100-400 L IS, 70-200 f2.8 L, 24-70 f2.8 L, 100mm Macro f2.8, 50mm Macro f2.5, 50mm f1.4, 17-85mm IS, 10-22mm f3.5-4.5, 1.4x TC, 420ex, 580ex, Adobe Photoshop CS5, Lightroom & other assorted goodies..
lehayes is offline   Reply With Quote
Old 2nd of January 2008 (Wed)   #4
eesparx
eesparx's Avatar
Mike
I hadn't noticed the reduced depth of field. You are quite correct and I appreciate the comment.
Mike-DT6: No problem; I like the effect.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Quasi Macro...but a rose is a rose... conbu19 Wildlife 5 11th of June 2007 (Mon) 15:38
Infrared Crypto Still Life, B/W & Experimental 17 2nd of June 2006 (Fri) 13:29
Infrared gcmanfrin@comcast.net Canon EOS Digital Cameras 1 31st of October 2005 (Mon) 17:33
infrared with the g3? cprevost Canon G-series Digital Cameras 5 13th of September 2003 (Sat) 09:35
G2 Infrared Laziferous Critique Corner 4 7th of September 2003 (Sun) 12:34
