Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > General Photography Talk
Reply
Thread Tools Display Modes
Old 4th of January 2008 (Fri)   #1
Matija
Matija's Avatar
Default Droplets...?
hi all,
i'm new here, registered a couple of days ago...and browsing topics daily, and have seen some great pics...
the most interesting at the moment seems these "droplet pics"...
http://matthewlaw.ca/gallery/albums/...droplets_2.jpg
http://farm2.static.flickr.com/1427/...2b9ab32e_o.jpg
i've tried to "make" something like that but obviously i'm doing something wrong...
can someone explain me how to do this?
thanks
Matija
Canon EOS 400D KIT
EF 50 mm f/1.8 II
100 mm macro f/2.8
Matija is offline   Reply With Quote
Old 4th of January 2008 (Fri)   #2
alliec
alliec's Avatar
Default Re: Droplets...?
Hi Matija,
I believe the second image is one of LordV's.
The droplets in that image are naturally occuring dew on a blade of grass. He achieves these by placing a flower about 2cm behind the drops and then using a technique called focus stacking. These images are usually taken beyond x2 life size magnification using canons MP-E 65mm 1x - 5x life size macro lens. I dont know wether you have a dedicated macro lens but you would need a full set of extension tubes on a 1:1 macro lens to get x2 magnification. Yoy could try reversing your 50mm onto the camera or a set of tubes and then reversing the lens as this will give you greater magnification although not sure how much.
Here is a link to focus stacking.
http://www.digitalgrin.com/showthread.php?t=61316
Alistair
My Flickr
http://www.flickr.com/photos/alliec2007/
350D, 30D, Tamron 90mm, MP-E 65, 2 x 18-55, 50 1.8 II, 430EX Speedlite, MT24ex and Kenko Extension Tubes.
alliec is offline   Reply With Quote
Old 4th of January 2008 (Fri)   #3
Matija
Matija's Avatar
hi, thanks for answering...
no..i don't have a macro lens...
what i don't understand.. what does a macro lens have with seeing this "little pictures" in droplets?! shouldn't those flowers (from 2nd picture) be visible in droplets to our eyes, without looking through the MP E 65mm lens?
Canon EOS 400D KIT
EF 50 mm f/1.8 II
100 mm macro f/2.8
Old 5th of January 2008 (Sat)   #4
LordV
LordV's Avatar
Hi - they are visible but dewdrops are very small - about 2mm in diameter. At this size the drops are nearly perfectly spherical as surface tension easily overcomes gravity effects, larger more easily seen drops tend to go pear shaped due to gravity and severely distort the refracted image.
Brian V.
http://www.flickr.com/photos/lordv/
http://www.lordv.smugmug.com/
Macro Hints and tips http://photography-on-the.net/forum/...d.php?t=807056
Canon 20D, Canon 40D, Canon 5D mk2, Sigma 105mm EX macro, Tamron 90mm macro, Canon MPE-65,18-55 kit lens X2, canon 200mm F2.8 L, Tamron 28-70mm xrdi, Other assorted bits
LordV is online now   Reply With Quote
Old 5th of January 2008 (Sat)   #5
Matija
Matija's Avatar
ok..so smaller droplets give better picture "inside" ..and for this one need a better macro lens... got it.. thanks...
what about first picture? these are droplets on the glass (probably window glass?)
how far from this glass should the ..in this case flag.. be? as alliec said about 2 cm?
Canon EOS 400D KIT
EF 50 mm f/1.8 II
100 mm macro f/2.8
Old 5th of January 2008 (Sat)   #6
ajayclicks
ajayclicks's Avatar
Hi Alliec,
I read in a macro book that a 1.4x extender too would give 2x (something to do with maths 1.4*1.4= 1.96
Any idea if its true? I have the 90mm tammy and i wud prefer a convertor over tubes for the added benefit of extra reach.
ajayclicks is offline   Reply With Quote
Old 5th of January 2008 (Sat)   #7
simwells
Originally Posted by ajayclicks View Post
Hi Alliec,
A 1.4 extender will just give you 1.4 times the current maximum magnification. So if it's a 1:1 macro lens you can get 1.4:1
simwells is offline   Reply With Quote
Old 6th of January 2008 (Sun)   #8
ajayclicks
ajayclicks's Avatar
Hey Sim,
I have "The complete guide to close up and macro photography" by Paul Harcourt Davies" and in the section on Teleconvertors & Multipliers, he writes what you have mentioned above, i.e. a 1.4 extender will give 1.4 times the current magnification.
However, on the facing page, there is a shot of an insect taken with Nikon 105mm and a 1.4x extender, and he writes: Enlarging the body length of a small insect by x1.4 may not seem much, but other dimensions are also enlarged- the area the creatures body occupies on film increases by 1.4*1.4 which is 1.96- effectively doubling it.
Hence I was wondering if the above, if true (i mean - no flawed logic), would be applicable to dew drops as well...
Cheers
Old 6th of January 2008 (Sun)   #9
neil85
i have a page ripped out of a mag from years ago where a person was in a Cab/Taxi and it had just rained out. the picture was looking out the door window at all the drops and the drops had another taxi in them.
hope that makes sense? it was a very cool image
30D & 28-135 kit lens, 50mm F/1.8 MKII, monopod, tipod w/pan tilt head, 430EX w/ sto-fen omni bounce,
On the brown truck, due 10/26 ... 70-200 2.8L IS
neil85 is offline   Reply With Quote
Old 6th of January 2008 (Sun)   #10
simwells
Hey Sim,
Cheers
Well the standard mag of a Nikon 105mm is 1:1 so unless he's using two 1.4s the maximum magnification will be 1.4:1. Whether a single Tcon is enough for Dewdrop photos I can't answer, as I've never tried to do any personally.
Old 6th of January 2008 (Sun)   #11
ajayclicks
ajayclicks's Avatar
Thanks for the response sim
Old 7th of January 2008 (Mon)   #12
imdelapena
He means to say that the area will be 1.96 times bigger.
Hey Sim,
Cheers
imdelapena is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Droplets illusionest Macro 9 11th of December 2007 (Tue) 14:48
Droplets Let GO! BSBXTi Still Life, B/W & Experimental 4 19th of August 2007 (Sun) 15:51
jumping droplets marie People 7 26th of February 2007 (Mon) 14:43
Droplets markarian Wildlife 6 27th of May 2006 (Sat) 02:23
Droplets or two GIrven Wildlife 5 3rd of January 2005 (Mon) 09:58
