#1 |
I currently have a Canon 550EX Flash that I will want to use as a slave unit. If I get a Canon 580EX II, can I use it to trigger the 550? What about a step further...can both flashes be triggered by the onboard flash on my 40D?
| sponsored links |
#2 |
Hiding Under a Rock
Yes, either the 550 or the 580 can be a master. But not your onboard flash.
/Petra Hall Click here to view my geeky gear list I shoot as much as possible in available light... sometimes, my flash is available – Joe Buissink |
#3 |
Moderator
Yes, the 580EX II can trigger the 550EX, and no, the 40D onboard will not trigger the 580 or the 550. To do that you'll need the ST-E2 transmitter (to set flash ratios) or you'll need to attach some other separate triggers (optical slave sensors such as those made by Wein) to trigger them, but you lose automatic flash ratios going that route.
Mark ----- Some primes, some zooms, some Ls, some bodies and they all play nice together. Thirty-five years of shooting and still learning. My G&N Blog (NSFW)- My Complete Gear List - Mac-Photo Website - My Tumblr Site (NSFW) G&N FORUM EARLY ACCESS & IMAGE POSTING RULES |
| sponsored links |
#4 |
Thanks for the responses. I'm wanting to use the 550 for some side lighting with a reflector and wanted to make sure the 580 would trigger it. I may look into getting a 430 to use for back lighting.
#5 |
Does anyone have a good article or website to read up on using flashes Master and Slave style and possibly talking about how they work and such?
Canon 1D MkIIn, 580 EX II, 430 EX, 17-40 f/4L, 85mm f/1.8, 70-200mm f/2.8L IS, Sigma 300 f/2.8 EX DG HSM, Lowepro Flipside 400 AW |
#6 | |
Moderator
...Leo |
#7 |
Just what I was looking for PacAce! Thanks much!
| Thread Tools | |
| Display Modes | |
| Master - Slave flash Sigma vs Canon | jalafer | Canon EOS Digital Cameras | 5 | 11th of September 2012 (Tue) 10:08 |
| Using flash slave units with the 400D | pcook | Canon EOS Digital Cameras | 15 | 15th of April 2009 (Wed) 08:59 |
| Can any other Flash units trigger the 580EX set to slave? | the.good.life | Small Flash and Studio Lighting | 9 | 3rd of January 2006 (Tue) 11:58 |
| 20D master/slave flash quesion. HELP.. | johneric8 | Small Flash and Studio Lighting | 8 | 20th of March 2005 (Sun) 09:34 |
| 550EX Master Flash off Slave on ? | jhankins | Small Flash and Studio Lighting | 6 | 6th of March 2005 (Sun) 20:47 |
