#1 |
I don't have shots to post yet, but I had quite a rude awakening this weekend shooting my first indoor junior rodeo event. Apparently the guy who used to provide shots set up lights and flashes on poles which kinda blows my mind given the set up of these indoor arenas.
Let me just say it was dark and I'm not overly happy with what I got. What I am curious to know is who here has been to or shot similar events/venues and seen elaborate light set-ups put up by the photographer? I am not really wanting to do this again given the circumstances nor do I want to invest in tons of lighting equipment. Anyone out here with experience with this? (posting this in lighting section as well)
Tony I use Canon gear...have several bodies and lenses and am quite pleased with them. "A person's gift will make room for itself." |
| sponsored links |
#2 |
For any arena event it is very common for photog's to set up strobes. And yes, i have seen this done at other rodeos as well, the lighting in these tends to be worse then all the other arenas. I set up strobes for the basketball or volleyball games that i go to shoot as well.
#3 | |
Location: Feeding my camera somewhere in Western Washington
EDIT: This blog site clips several parts of the web address away and I don't know how to repair the link it allows to post. Here's how to find the link on this site (I wish I knew the proper way). Go to the search bar and use these key words [white lightning rodeo]. The post by Dale Miller is the one I'm referring to. Actually the second post is another guy talking about his rodeo setup too. I'm assuming as a basis for this that you already have a good fast lens. If it's not less than f/4 you don't have much hope in rodeo conditions under artificial light. Lighting in that case would be a requirement (for great pictures) and you have to hope that your f/4 lens can get enough light to focus if that's what you're using. Higher shutter speeds of a minimum of 1/400 to 1/500 would be necessary to freeze the action typically. Most shots would probably be between 85mm and 300mm as well.
Canon ~ 7D, 1D MkIIn, 5D, 20D, 10D, 100-400L IS, 70-200 2.8L IS, 24-105 f4L IS, 17-40 f4L, 135mm f2L, 85mm 1.8, 50mm 1.4, 50mm 2.5 macro, Ext. tubes, TC's 1.4 & 2.0, Feisol 3441-S CF Tpod, Gitzo Traveler Mpod, Acratech ballhead, 550EX, 200EG bag, Epson Pro 3800 printer. Last edited by tkoutdoor : 8th of January 2008 (Tue) at 11:55. |
| sponsored links |
#4 |
I have a Norman an I usually shoot at around F5.6 at either 400 or 800 ISO. Mostly 400.
Pete Canon 40D & 7D 24-70 F2.8 L 70-200 F4 L Norman 400B, AB800,AB1600 White Lighting 3200 |
#5 |
How many units do you prefer to work with in your Norman setup and how do you spread out your lighting? Are you using battery packs, plugged in, or generators like the other thread I posted earlier?
Canon ~ 7D, 1D MkIIn, 5D, 20D, 10D, 100-400L IS, 70-200 2.8L IS, 24-105 f4L IS, 17-40 f4L, 135mm f2L, 85mm 1.8, 50mm 1.4, 50mm 2.5 macro, Ext. tubes, TC's 1.4 & 2.0, Feisol 3441-S CF Tpod, Gitzo Traveler Mpod, Acratech ballhead, 550EX, 200EG bag, Epson Pro 3800 printer. |
#6 |
I shot with my 70-200 2.8...and kicked myself for not bringing my 85 1.8.
My ISO was 3200 the whole day...and I think the fastest I ever got to shoot was between 320/sec - 400/sec. I'll post a few shots tomorrow when I'm done with them. While this was an interesting experience...(first time for indoor rodeo), I just marveled to think of anyone hauling in lighting equipment to such a venue...pole mounts along the sides...some hanging from the ceiling beams... I'm just not that hard core. Mostly I was just curious to see how others might do it. The full time professional outfit who have shot for them the past few years...I saw some of there work from this particular arena...and I don't know that the strobes 'helped' the quality of the pictures at all. Looked more like HomeDepot spotlights were used. I'll hunt the link down now.
#7 |
I use the Norman 400B. It's a single strobe head that mounts on a bracket for your camera. I can usually shoot ISO 400 250-200/sec at F5.6-4 With the Norman set at 100-200 W/S depending on the event and distance.
http://www.photo-control.com/battery...s_compkits.asp
#8 |
The norman is a very tough strobe. It's made for rodeo life. Mine has taken one kick and lots of banging on fences.
#9 | |
#10 | |
#11 | |
LOL...Bingo! I walked in to that place and took one look around and just said: "Well S--T"! I shot a local rodeo in our town this summer...outdoor arena...got some great shots...so there's no doubt I enjoy this venue...quite challenging for sure.
#12 | |
Hey...do you have any sample shots with this strobe being used?
#13 |
http://photography-on-the.net/forum/...d.php?t=356639
http://photography-on-the.net/forum/...d.php?t=356620 Here are some. The queen Pic is alittle off. It was just a guess shot as she rode past.
#14 |
Hey...not bad at all...
Thanks for posting those. Hey...how does that strobe unit compare...say to the 430ex or the 580? Are talking a lot more light here?
#15 |
It's a lot more light you got from 50-400 w/s. The only thing is you have to do all the thinking.
| Thread Tools | |
| Display Modes | |
| Indoor lighting question... | namasste | Sports | 2 | 26th of November 2007 (Mon) 13:39 |
| first indoor (lighting test) | RacEcaR | People | 4 | 4th of November 2007 (Sun) 20:45 |
| Help with indoor lighting | Dave Shively | Small Flash and Studio Lighting | 1 | 16th of August 2007 (Thu) 09:45 |
| Indoor Rodeo - 4 images | ssim | Sports | 11 | 1st of March 2006 (Wed) 09:49 |
| Indoor Crappy lighting--HELP | Lisa F | Sports | 43 | 26th of January 2006 (Thu) 21:23 |
