#1 |
having used an old slr camera for the last 30 years, i always used a uv filter in high altitudes, do i have to change settings on my a60 to compensate for this?
| sponsored links |
#2 |
Moderator
Slayer of Trolls Join Date: Jun 2004
No. A UV filter has essentially 0 filter factor. Or were you asking about changing settings on the A60 to compensate for the extra UV? There's not much other than a filter that can do this.
#3 |
You can modify your picture after the fact to remove haze, but that only goes so far, and is a lot more bother than removing haze with a filter...
If you're shooting lots of images where a UV filter is needed - use one if possible and save on the editing time later. |
| sponsored links |
| Thread Tools | |
| Display Modes | |
| Lee Filter Advice - esp. for Filter Sets | surfjungle | Accessories & Storage | 4 | 13th of June 2007 (Wed) 12:04 |
| WTB : Filter step-up ring (77mm thread, 82mm filter) | NAisBEST | Classifieds: Buy | 0 | 16th of October 2006 (Mon) 14:30 |
| Anyplace that sells filter rings? (filter w/o actual filter in it) | JonathanSQ | Accessories & Storage | 1 | 18th of August 2005 (Thu) 18:29 |
