Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Accessories & Storage
Reply
Thread Tools Display Modes
Old 8th of January 2008 (Tue)   #1
oak3x
oak3x's Avatar
Default Stupid Question...Tripod and Vertical Grip
For those of you who utilize the Canon Vertical Grip Attachment, do you remove when mounting on your Tripod?
Or, can you mount Camera / Vertical Grip on the Tripod?
oak3x is offline   Reply With Quote
Old 8th of January 2008 (Tue)   #2
slappy sam
slappy sam's Avatar
Default Re: Stupid Question...Tripod and Vertical Grip
You can mount it, but I prefer to remove it. I think it will make the camera more unstable.
On a sidenote, removing this grip with the handstrap on is gonna be a PITA. And then putting it back on with the handstrap is gonna be quite a process as well - beginning to not like the hand strap so much.
40D|10-20|17-50|70-200|580ex
FS: XT with 2 OEM batteries
slappy sam is offline   Reply With Quote
Old 8th of January 2008 (Tue)   #3
Riff Raff
Riff Raff's Avatar
I've never removed the grip since buying the XTi (and grip, obviously). The tripod thread on the bottom of the grip should be fine.
Shawn McHorse - AustinRocky.org / RockyMusic.org
Bodies: 5D Mark III, Rebel XTi, Elan 7NE Compact: S100 Flashes: 580EX II, 430EX
Lenses: 16-35mm f/2.8L II, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 50mm f/1.4, 85mm f/1.8
Bags: Stealth Reporter D400AW, Toploader 75AW, Modulus Belt System
Riff Raff is offline   Reply With Quote
Old 8th of January 2008 (Tue)   #4
Mark001
Mark001's Avatar
I have the battery grip for the 20D and never take it off. When using smaller lenses, I mount to the bottom of the grip, and with my larger lenses, I use the tripod collar provided with the lens.
- Mark
1D Mark III, 20D, 400 F5.6, 24-105 F4 IS, 17-40 F4, 70-200 F2.8 IS, 100 F2.8 Macro, 1.4xII, 580EX II
Mark001 is offline   Reply With Quote
Old 8th of January 2008 (Tue)   #5
ben_r_
-POTN's Three legged Support-
ben_r_'s Avatar
I would like to feel that leaving the grip on is fine but IMO it does feel more stable with the grip removed.
[ Gear List | Flickr | My Reviews ] /|\ Tripod Leg Protection /|\
ben_r_ is offline   Reply With Quote
Old 8th of January 2008 (Tue)   #6
ben_r_
ben_r_'s Avatar
The only problem with that method is when you have the 24-70L attached. It weighs as much as a larger telephoto but has no tripod ring mount. With the grip attached it feel VERY front heavy when on a tripod.
Old 8th of January 2008 (Tue)   #7
timnosenzo
You can mount the camera on a tripod with the grip attached, but its not terribly sturdy--you'll find that the grip flexes more than when you mount the body directly to the tripod, especially if you're using a heavy lens.
The real downside to this is that you can spend time framing your shot, tighten up the tripod head, let go of the camera, and then watch your shot get screwed up because the camera sags.
timnosenzo is offline   Reply With Quote
Old 8th of January 2008 (Tue)   #8
slappy sam
slappy sam's Avatar
If your serious about getting a sharp shot I would take the grip off. The connection between the grip and camera is not perfect and as already said the grip flexes. This will defeat (IMO) the importance of using mirror lockup and a remote shutter release - if your just going to be using a grip that will flex with the weight of the lens and the wind.
Old 8th of January 2008 (Tue)   #9
queenbee288
queenbee288's Avatar
I second this. It seems the added weight may be too much for my ballhead.
Char
www.lanephotography.smugmug.com
Canon 7D, Sigma 70-200, Tamron 28-75, Canon 100 2.8, 50 1.8,
queenbee288 is online now   Reply With Quote
Old 9th of January 2008 (Wed)   #10
yogestee
"hangs around male genitalia"
yogestee's Avatar
Hasn't been off my 350D since I bought it whether on a tripod or monpod..
Jurgen
Jurgen
50D~20D~EOS M~S95
http://www.pbase.com/jurgentreue
yogestee is offline   Reply With Quote
Old 9th of January 2008 (Wed)   #11
Jethro790
Jethro790's Avatar
I use my XTI on a tripod with the grip on all the time.
If you must know...
Jethro790 is offline   Reply With Quote
Old 9th of January 2008 (Wed)   #12
Familiaphoto
Familiaphoto's Avatar
I think it depends on the body you are using. When putting my XTi with grip on a tripod all is fine. The 40D with grip though I can tell a difference. But does that make me take it off...NOPE. I have an E1 handstrap on my 40D and don't want to deal with it.
Man I'm lazy.
Paul
Blog | Gear | Gallery
Bag Reviews: Domke F-3x | More to come...
Familiaphoto is offline   Reply With Quote
Old 9th of January 2008 (Wed)   #13
ATI058
ATI058's Avatar
Have you concidered an L shape tripod mounting bracket? The RRS company have custom fitting mounting brackets that are built very sturdy. I use one of these for my 20D + 24-70mm full time. On or off the tripod, it feels very solid and is quality built to last.
ATI058 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
stupid tripod question - maybe Marcy Accessories & Storage 5 6th of November 2007 (Tue) 17:10
stupid tripod question rockabilly808 Accessories & Storage 6 10th of September 2007 (Mon) 06:09
stupid CF-994 Dynatran tripod question fivefish Accessories & Storage 3 25th of August 2006 (Fri) 22:13
Stupid Tripod Question Bill Crittenden Accessories & Storage 6 28th of April 2006 (Fri) 16:20
10D vertical grip question? dennykyser Canon EOS Digital Cameras 3 25th of June 2004 (Fri) 09:42
