Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > General Photography Talk
Reply
Thread Tools Display Modes
Old 13th of January 2008 (Sun)   #1
amironsi
amironsi's Avatar
Default Where to focus???
i was thinking,
if i am doing portraits and group pics that i would have 3 main Aperature sizes and focusing points as follows:
- Full body portraits: i would go for f/2.8 and my focusing point would be to any part of the body
- Face portrait and closeups: i would go for f/4 and my focusing point would be the eye of the person.
- Group pics: i would for f/8 or higher and my focusing point would be either the centre person or A-DEP mode
is that right should i change it or what Am i even thinking straight?
It's all about WHITE BALANCE.
http://www.amirwilliam.com
40D, 350D,BG-E3,EF-S 17-55 f/2.8,EF 70-200 f/4 L,EF-S 18-55mm f/3.5-5.6,580EX Speedlite,190XPROB,681B,322RC2,804RC2,234RC,5 batteries and 12GB of memory,Lowepro Stealth Reporter 650AW.
amironsi is offline   Reply With Quote
Old 13th of January 2008 (Sun)   #2
BradM
BradM's Avatar
Default Re: Where to focus???
I would wonder why you aren't choosing to focus on the eye on all scenarios, if the eye(s) aren't sharp it was a wasted shot from my point of view. For a group shot choose one persons eye to focus on and then use an aperture that would bring everyone into the dof required to keep them all sharp.
Shaking like a hypertensive squirrel on meth? Buy IS, cheaper than detox & it works.
www.bradmanchas.zenfolio.com
The gear list
BradM is offline   Reply With Quote
Old 13th of January 2008 (Sun)   #3
smorter
smorter's Avatar
What focal length are you planning you use for the above?
smorter is offline   Reply With Quote
Old 13th of January 2008 (Sun)   #4
amironsi
amironsi's Avatar
i can't confirm
but i will be mainly using my 17-55 f/2.8
Old 13th of January 2008 (Sun)   #5
daleftw
I think I'd go for a wider aperture for closeup portraits to make the subject "pop" by using bokeh/blurred background. Oh yeah, always focus on the eyes.
Canon Eos 5 | 28-135mm | 20-35mm | 50mm 1.8 | modified 28-80mm | 540EZ
As many megapixels as I could ever want all rolled into a film canister.
daleftw is offline   Reply With Quote
Old 13th of January 2008 (Sun)   #6
nwa2
nwa2's Avatar
For single portraits, always focus on the eyes. When we look at a picture of a face there is a natural connection with the eye. If eyes are out of focus that connection is lost.
Choose your aperture to bring attention to the part of the image you want the viewer to look at.
In the scenarios you suggest I would have started,
Face: f2.8
Full length: one or two stops down
Group: f8 to 9
Try different settings and critically assess your own results.. Post a few here and allow us to C&C ... you will learn a lot.
Canon 7D; 40D:
There are many tomorrows', but only one today!!
www.ImageSix.Weebly.Com
nwa2 is offline   Reply With Quote
Old 13th of January 2008 (Sun)   #7
PhotosGuy
Moderator
PhotosGuy's Avatar
For me... the eyes, always the eyes!
or A-DEP mode
Never! If you're in a controlled setting, I always use manual mode so everything is under my control.
Try this to set exposure: Need an exposure crutch?
www.FrankCizek.com
PhotosGuy is offline   Reply With Quote
Old 14th of January 2008 (Mon)   #8
Mark_Cohran
Moderator
Mark_Cohran's Avatar
You should have gotten the point by now that any time you do people photography, the point of focus should be the eyes. One thing you should remember, however, that with a shallow depth of field, if you focus on the eyes with the center AF point and then recompose, you may defeat your purpose. In these cases, you're better off to compose and manually select the AF point closest to the eyes in your composition, place it over the eyes, focus, and then recompose. This minimizes the recomposition and the subsequent focusing error.
Mark
Some primes, some zooms, some Ls, some bodies and they all play nice together.
Thirty-five years of shooting and still learning.
My G&N Blog (NSFW)- My Complete Gear List - Mac-Photo Website - My Tumblr Site (NSFW)
G&N FORUM EARLY ACCESS & IMAGE POSTING RULES
Mark_Cohran is offline   Reply With Quote
Old 14th of January 2008 (Mon)   #9
gooble
gooble's Avatar
Depending on the focal length used for group shots it isn't necessarily needed to stop down to f/8. Wide focal lengths will give you wide enough DOF for group shots even wide open.
For example at 18mm, f/2.8 while focusing at 8ft your near and far limits of focus will be about 4ft in front of and behind your main focus point.
I'm not saying you should shoot wide open. Chances are the lenses best IQ is shown stopped down a little. But I think f/8 is overkill.
gooble is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Sigma 24-70mm Front Focus to Back Focus Problem Hank2122 Canon EF and EF-S Lenses 15 10th of January 2011 (Mon) 14:36
Is my lens/camera back focus? here is my focus test picture highroller Canon EF and EF-S Lenses 6 8th of January 2008 (Tue) 18:43
Trying To Make Sense Of Auto-Focus and Manual Focus! (20D) Mike-DT6 General Photography Talk 3 25th of December 2007 (Tue) 20:40
New problem with 30d- auto focus in AI Focus metering mode Matt Stoltz Canon EOS Digital Cameras 10 11th of January 2007 (Thu) 20:50
Focus speed vs focus ability/camera focus vs lens focus timmyquest Canon EF and EF-S Lenses 8 2nd of April 2004 (Fri) 10:56
