Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Transportation
Reply
Thread Tools Display Modes
Old 25th of September 2004 (Sat)   #1
PhotosGuy
Moderator
PhotosGuy's Avatar
Default Why I love RAW - '53 Ford Sunliner (Fixed)
Rag-top, a pearl paint job, bubble skirts, lakes pipes, Packard tail lights, frenched headlights... what more could a kid in the '50s want?
I almost missed this one. The tripod was already in the trunk when I saw it, so I grabbed a couple quick shots at minimum settings before he drove away. Being a film guy for years, I totally forgot that I could have bumped up the ISO! I also forgot to take the bright background into consideration. The car was the subject, not the sunset, right? So here's the results.
300D, Kit lens, ISO 200, RAW, Manual everything.
1/80 sec, f-4.5, FL= 18mm.
This is a jpeg from the umprocessed RAW file. Nice, huh?
These are the results after processing RAW +2.0 exposure into tiffs, & the usual PS work.
www.FrankCizek.com
Have you thought about making your own book? / The new default version of FireFox is color managed!
PhotosGuy is online now   Reply With Quote
Old 25th of September 2004 (Sat)   #2
Conk
Conk's Avatar
Default
Great job Frank.
Conk is offline   Reply With Quote
Old 26th of September 2004 (Sun)   #3
PhotosGuy
Moderator
PhotosGuy's Avatar
Default
Thanks, Conk. This post seems to be "going down the tubes" fast. Maybe I should have added (topless) to the title?
www.FrankCizek.com
Old 27th of September 2004 (Mon)   #4
PhotosGuy
Moderator
PhotosGuy's Avatar
Default Apologies
Photobucket was down all weekend. Apologies to those who waited for this to load.
www.FrankCizek.com
Old 27th of September 2004 (Mon)   #5
wolverinesr1
wolverinesr1's Avatar
Default
wow is all i can say. that is a great testament to use raw. which i have slowly come around to using, because of pics like this. i'm even saving the raw files to maybe visit a year later to see if i can do even better processing. now if i could only get my PS skills up there i would be happy.
great job Frank.
jeff
Jeff
Canon 30 D with Kit Lens
24-70 2.8 L
70-200 F4 L
Canon EF 50mm 1.8 II
Kenko 1.4 TC
Canon Speedlite 580 EX
wolverinesr1 is offline   Reply With Quote
Old 27th of September 2004 (Mon)   #6
marie
marie's Avatar
Default
love the first shot especially
great atmosphere in it
Regards
,Marie
Pro1/ EOS 40D /24-105/70-300/10-22/60mm
marie is offline   Reply With Quote
Old 27th of September 2004 (Mon)   #7
Ballen Photo
Moderator
Ballen Photo's Avatar
Default
Marie hit it right on the nail head.
The PS work is great too.
-Bruce
The Captain and crew finally got their stuff together, now if we can only remember where we left it.
Ballen Photo is offline   Reply With Quote
Old 27th of September 2004 (Mon)   #8
drisley
"What a Tool I am"
drisley's Avatar
Default
I really like shot #2.
Excellent cropping and composition. It almost looks 3D.
drisley is offline   Reply With Quote
Old 28th of September 2004 (Tue)   #9
KevinO
Default
I not normally a 'still life' person, but these are just great shots.
KevinO is offline   Reply With Quote
Old 28th of September 2004 (Tue)   #10
Mooneyes
Default
Very classy shots, think I may start experimenting with raw after seeing these...
Mooneyes is offline   Reply With Quote
Old 28th of September 2004 (Tue)   #11
Ikinaa
Ikinaa's Avatar
Default Re: Why I love RAW - '53 Ford Sunliner (Fixed)
I didn't know that you could rotate the car when shooting RAW . Or do you have this blade-runner aka CSI-plugin for PS?
Great job...
how long does it take to isolate the car from the background.
I've never tried doing it because of the long (my guess) time needed
Ikinaa is offline   Reply With Quote
Old 28th of September 2004 (Tue)   #12
PhotosGuy
Moderator
PhotosGuy's Avatar
Default
The more you do it, the faster it is.
To select it & hide the background: Selecting areas in PS.
1. 5 minutes for the (dark) bottom of the car:
Add an adjustment layer (Levels) & kick up the brightness so I can see what I'm doing. Make the selection & save it, then turn off the adjustment layer. Then add the rest of the car to the selection & save it = another 5 minutes.
2. Erase or hide the background. see the bottom link.
3. Recall the selection, invert it, & expand it 1-2 pixels. Then erase any halo like the one you see at the top of the fender at the right in the first pic. (I didn't do that here before I posted the pic - I usually wait 'till I see what it looks like against whatever background I end up using.) Maybe another 5 minutes for that.
So, about 15 minutes for the whole process + time wasted if I see something interesting on the TV while I'm doing this.
EDIT: Using a Layer Mask to hide part of an image. Advantage is that the mask is reversible, where the effect of an eraser is not.
Need to remove a background from something?
www.FrankCizek.com
Old 28th of September 2004 (Tue)   #13
Ikinaa
Ikinaa's Avatar
Default
To select it & erase the background: (See my 'selection' tutorial in Post Processing)
2. Erase the background.
Seems easy
I guess it's all about training... like 1st time 3 hours, second time 2hours 59 minutes... etc 100th time 15 minutes
I'll give it a try, just read your tutorial too... very interesting...
Old 28th of September 2004 (Tue)   #14
4walls
4walls's Avatar
Default
Wow, great work as always Frank.
Canon 20D, EF 24-70 F/2.8L "The Brick", Sigma 70-200 F/2.8, 430EX, Lowepro Slingshot 100AW, BG-E2 grip
4walls is offline   Reply With Quote
Old 28th of September 2004 (Tue)   #15
PhotosGuy
Moderator
PhotosGuy's Avatar
Default
That's it! Thanks, 4walls.
www.FrankCizek.com
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
I Love RAW AussiePup RAW, Post Processing and Printing 1 17th of July 2007 (Tue) 14:01
'54 Ford Crestline Sunliner 289 **56K Warning!** PhotosGuy Transportation 18 11th of April 2006 (Tue) 18:41
'55 Ford Fairlane Sunliner PhotosGuy Transportation 9 28th of February 2006 (Tue) 09:14
I Love RAW! Maureen Souza RAW, Post Processing and Printing 26 20th of September 2005 (Tue) 00:50
I love RAW! FlyingPete RAW, Post Processing and Printing 14 17th of May 2005 (Tue) 19:06
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
