Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Presentation
Reply
Thread Tools Display Modes
Old 30th of September 2004 (Thu)   #1
Sam North
Default Website with Essays for Amateurs and Beginners
I first took up 35mm photography as a hobby 28 years ago. Around 3 years back I got into website design and created a site aimed at amateur photographers. Many out there may not be able to afford top gear, but still want to do the best they can.
My heart sinks when I open a mag for amateurs and read, "... many amateur photographers forget that great shots need great lenses" (Digital Photography User). This is nonsense.
Anyway, my site tries to deal with the amateur side of photography and includes a gallery.
The Image Plane
Sam North is offline   Reply With Quote
Old 9th of November 2004 (Tue)   #2
pradeep1
pradeep1's Avatar
Default
Sign me up! :P
Pradeep Satyaprakash
Please view my portfolio.
pradeep1 is offline   Reply With Quote
Old 11th of November 2004 (Thu)   #3
Sam North
Default
You're most definitely in, Pradeep.
I reckon I could learn a thing or two from your shots!
Sam
Old 3rd of December 2004 (Fri)   #4
PhotosGuy
Moderator
PhotosGuy's Avatar
Default
This is a great idea! There can't be too many sites for beginners, & I may recommend yours to my students after I have time to completely review it. I hope you suggest to them that this forum would be a big help to them, too.
Just a thought: On http://www.theimageplane.net/tip2_008.htm
...you might tell them why you say, " Be extra careful when using a wide-angle lens. Beware of lens hoods that may not be compatible with your chosen lens.", and add "because you may get image cut-off at smaller apertures. Use the depth of field preview to check, or if you don't have one, take a pic at f/16 & look at the corners to guard against cut-off."
Keep it up!
www.FrankCizek.com
PhotosGuy is offline   Reply With Quote
Old 3rd of December 2004 (Fri)   #5
malla1962
malla1962's Avatar
Default
ile have some of that please
malla1962 is offline   Reply With Quote
Old 26th of December 2004 (Sun)   #6
Sam North
Default Re: Website with Essays for Amateurs and Beginners
Just a few lines to let you know that I have taken your advice and revised the text which now reads:
"Always use a lens hood to protect the lens elements from bright light. If you use a lens without a hood your images may suffer from the effects of non-image-forming light that reaches the sensor or film. A lens hood that is not compatible with the lens in use may encroach into the lens's field-of-view and darken the corners of your images."
I've also moved it to another section. Thanks for the input!
Thanks for the above comments!
I should add that if anyone visiting the site is having any problems with text sizes, please check the technical info on Page 1: Advanced Display Settings DPI
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
pros vs amateurs J.A.F. Doorhof Sports 5 10th of May 2007 (Thu) 21:48
i9900 for schoolwork, essays, etc. oni0n56 RAW, Post Processing and Printing 11 30th of August 2006 (Wed) 21:08
Looking for a Website, for Beginners unconquerable Canon EOS Digital Cameras 9 1st of February 2006 (Wed) 10:56
For DSLR/SLR Amateurs and Beginners Sam North Presentation 5 17th of September 2005 (Sat) 22:04
Instructional/informative essays Del K General Photography Talk 1 11th of April 2001 (Wed) 02:48
