#1 |
I'm confused. I know the F stop goes up when the shutter speed goes down but by how much? If I was at F8 for 1/60 what would be my new speed if I change to F16? Or if there's a big change from F22 at 1/500, what if I change to 1/125?
| sponsored links |
#2 |
Cream of the "Prop"
To hold an equivalent exposure, each step up or down in aperture (f/stop) requires an equal but opposite change in shutter speed.
So however many stops you change your aperture, you need to change your shutter speed in the opposite direction by the same number.
"If you aren't getting extraordinary images from today's dSLRs, regardless of brand, it's not the camera!" - Bill Fortney, Nikon Corp. |
#4 |
Fatal attraction.
See the sticky at the top of this forum "Ben's Newbie Guide"and all will be revealed.
Elie / אלי "If you presume to love something, you must love the process of it much more than you love the finished product." John Irving, 5/2012. "In theory there is no difference between practice and theory, but in practice there is." Yogi Berra Site |
#5 |
Why did you start a whole new thread with the same subject when you already had one going?
Skip Douglas A few cameras and over 45 years behind them ..... ..... but still learning all the time. |
#6 |
Please read http://www.uscoles.com/fstop.htm
Play with camera. Again read http://www.uscoles.com/fstop.htm Play again with camera.
5DmkII & 85L and a bunch of other glass that rarely sees the light |
#7 |
Take a look at these sites:
http://www.photonhead.com/simcam/shutteraperture.php http://web.canon.jp/imaging/enjoydslr/ http://www.usa.canon.com/content/reb...lxtlessons.htm
What we see depends mainly on what we look for. |
#8 |
Also check out a book titled "Understanding Exposure" by Bryan Peterson
#9 | |
So, the full f-stop scale looks like this: f/1, f/1.4, f/2, f/2.8, f/4, f/5.6, f/8, f/11, f/16, f/22 and so on. Moving up the scale, that is increasing the f-stop decreases EV. Shutter speeds also follow this logic but it is a little easier to understand as you simply divide by two or multiply by 2 (in most cases). In seconds: 1, 1/2, 1/4, 1/8, 1/15, 1/30, 1/60, 1/125, 1/250, 1/500, 1/1000, 1/2000, 1/4000 etc. Also in this case, moving up the scale reduces EV by half with each step. With ISO settings you typically have 100, 200, 400, 800, 1600, 3200, 6400, 12800 etc. Here though moving up the scale increases EV. So, when one of these is adjusted, in order to maintain the same EV, per your question, one or both of the others must be adjusted to compensate. If you increase the EV with one you must decrease the EV with the others and vice versa. So if you were set at f/8 with shutter of 1/60 and you wanted to move to f/16 you have to know the f-stop scale to know that you're decreasing the EV by two stops so you must increase the EV with the shutter speed by slowing it down, i.e. going from 1/60 to 1/15 sec. Or alternatively you could increase ISO sensitivity by moving from say, 100 to 400. |
| Thread Tools | |
| Display Modes | |
| F stops and shutter speeds | theartist53 | General Photography Talk | 16 | 25th of January 2008 (Fri) 12:28 |
| Confused about EXIF - 2 different shutter speeds? | chet79 | Canon EOS Digital Cameras | 5 | 16th of October 2007 (Tue) 11:17 |
| shutter speeds | rosco1971 | Sports | 1 | 4th of October 2005 (Tue) 18:45 |
| Shutter speeds | hogzilla | Canon EOS Digital Cameras | 7 | 14th of March 2004 (Sun) 15:18 |
| f-stops shutter-stops | vvizard | Canon EOS Digital Cameras | 6 | 19th of November 2003 (Wed) 10:09 |
