Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Accessories & Storage
Reply
Thread Tools Display Modes
Old 21st of August 2002 (Wed)   #1
petiot
Default microdrive - battery life
Hi
once month ago i asked if using a IBM microdrive would reduce the battery life on a d30. Well, since a microdrive uses moving part the theoretical answer was "yes"
since then i bought a microdrive, and my opinion on this it that using a microdrive reduces the number of shot that can be taken with a battery fully charged by approximatively 20% (compare to a 128MB cf Card)
I plan to make some real tests (by curiosity) (exact number of picture taken in controlled condition) but if someone already has spend sometime on it!!!
10D and now 5D, 17-40, 24-105, 135 (whish list: 50F1.4, 1.4* converter)
petiot is offline   Reply With Quote
Old 21st of August 2002 (Wed)   #2
Roger_Cavanagh
Roger_Cavanagh's Avatar
Default Re: microdrive - battery life
Dan,
I appreciate your scientific curiosity, but if you are going to run tests in controlled conditions, I am assuming you will not be taking pictures of anything worthwhile. So you will be "using up" several hundred shutter cycles on your precious D30 for data that will surely be of academic interest only.
If you are a pro, then you will surely ensure that you have ample supplies of CF space and battery power in case you miss that vital shot. If, like me, you are an enthusiastic amateur, just buy a battery grip and extra battery and go out with your camera and know that you can shoot all day.
When I make a photographic excursion, the most images I've ever shot in one day is around 500. More usually it's 300 or so. There has always been plenty of juice left in the batteries and that's with IS lenses and plenty of histogram checking.
One good thing about the BP511 is that you can charge it up as often as you like, full or empty without damaging it.
Regards,
Roger Cavanagh
www.rogercavanagh.com
Roger_Cavanagh is offline   Reply With Quote
Old 21st of August 2002 (Wed)   #3
boBquincy
When I received my microdrive (as part of the D30 rebate) I just *knew* I had to test it. A quick trip to Walt Disney World and Blue Spring State Park gave me an excuse to shoot about 800 images in 24 hours! As I recall, the battery quit at about the 500 point (with very little use of the flash).
I have the LCD screen set to 2 seconds and the power-down to 2 minutes.
boB
boBquincy is offline   Reply With Quote
Old 28th of August 2002 (Wed)   #4
petiot
thank you.
Why should i worry about "using Up" shutter cycles?? is there something i dont know??
Thank you
Dan
Old 28th of August 2002 (Wed)   #5
Roger_Cavanagh
Default Re: Re: microdrive - battery life
petiot wrote:
thank you.
Thank you
Dan
Dan,
No particular reason, I just recall reading that shutter life was around 150k cycles, so using up 1-2k of these for no great gain didn't seem very worthwhile.
Regards,
Roger Cavanagh
Old 28th of August 2002 (Wed)   #6
mrchips
Actually the 1D has a 150k shutter click life, if I remember the D30 and D60 are 70k life expectancy.
Denny
mrchips is offline   Reply With Quote
Old 29th of August 2002 (Thu)   #7
petiot
Oh now i see, why i shouldnt waste shutter sycle.
thank you for the tip.
by the way, when the shutter comes to the end, is there any way to replace it?
thank you
Old 29th of August 2002 (Thu)   #8
mrchips
thank you
Sure the camera can be rebuilt but I consider heavy use of a camera 7 to 10k shutter clicks a year. I doubt I will have my D60 more than 2 to 3 years so I wouldn't worry about it.
Denny
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
A300 battery life or no battery life ?? arde Small Compact Digitals by Canon 4 4th of July 2005 (Mon) 03:02
Poor Battery Life on Speedlite 580EX? or Some other problems? Battery Recommendation? EricKonieczny Accessories & Storage 4 12th of March 2005 (Sat) 19:20
Microdrive & battery life jbrewco Canon G-series Digital Cameras 0 24th of January 2003 (Fri) 14:25
Battery drain - Microdrive ? petiot Accessories & Storage 6 26th of July 2002 (Fri) 11:57
Microdrive battery use tafflink Canon G-series Digital Cameras 5 14th of May 2002 (Tue) 11:48
