Reply
Thread Tools Display Modes
Old 21st of August 2002 (Wed)   #1
rubysue
Default Raw /Jpeg, compression, resolution.
Anyone know a good site to really teach me the mysteries of compression and resolution? Why is RAW lossless, why can I adjust a RAW file without loss, but I lose each time I play with a Jpeg? Know my G2 well now after several months play. The software learning curve, compression/resolution confuses me. Any help any of you can give me would be great. Keith
rubysue is offline   Reply With Quote
Old 21st of August 2002 (Wed)   #2
Mind Socket
Default Re: Raw /Jpeg, compression, resolution.
I can't think of any sites off the top of my head, but I might be able to answer your questions.
You are talking about file formats here, and this should be distinguished from workflow. Workflow is always lossless, apart from the inherent loss that you might get by processing a file that already has compression artifacts in it. It is only when saving a file that you are considering lossy compression.
RAW is a lossless compressed form of what the CCD captures. That is, it contains exactly the maximum information possible. JPEG is a lossy compression, which in simple terms means that the output file is not an exact representation of what the CCD captured. JPEG has a lower dynamic range, and also introduces compression artifacts of varying amounts (depending on compression level).
You can adjust a RAW without loss if you save it as, for example, a lossless TIFF when you are finished. The same applies for editing a JPEG, if you save it in a lossless format, then you aren't introducing _additional_ artifacts. If you were to save either a RAW or JPEG file as a JPEG after editing, and subsequently edited that JPEG, saved as JPEG over and over again, there will be more and more artifacts introduced each time.
Think of it this way. It is not the "playing with it" that is potentially lossy, it's how the file is saved.
Hope that makes sense
Mind Socket is offline   Reply With Quote
Old 21st of August 2002 (Wed)   #3
slejhamer
slejhamer's Avatar
Keith and Rubysue,
A few links for your reading enjoyment:
http://www.shortcourses.com/how/files/files.htm
http://www.shortcourses.com/choosing/files/08.htm
http://www.digital-image.co.nz/DIT_TIFF.htm#tiff
http://faqs.jmas.co.jp/FAQs/jpeg-faq/part1
The first link has a basic comparison of RAW vs. JPEG from a Canon technical manager.
As to why RAW is lossless, you'd have to ask (and thank!) the programmers who created the algorithm...
P.S. How 'bout some pix of the dog?
Mitch
slejhamer is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
What resolution/compression? ColDaveG Small Compact Digitals by Canon 5 31st of July 2006 (Mon) 10:38
Resolution vs. compression Livingston Canon G-series Digital Cameras 41 24th of October 2005 (Mon) 16:57
Resolution vs. compression Livingston Canon G-series Digital Cameras 0 29th of September 2005 (Thu) 10:16
Compression and resolution pvdiamon Canon G-series Digital Cameras 1 20th of January 2002 (Sun) 17:39
Compression and resolution pvdiamon Canon G-series Digital Cameras 0 4th of January 2002 (Fri) 14:21
