Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 28th of January 2008 (Mon)   #1
GerBee
Default PW Plus II my observations.
Am new enough to PWs and only really started working them.
I seem to have a wee problem with my Sekonic L-358 and it's RF module to trigger the PWs. It is not constant, but on my last shoot I though it had given up ~ back home it's working again.
Also thought I had a PW problem as one would not fire, again back home this worked too ... This little issue is down to the 'transmit mode button' which can be just off, imperceptibly off the mark, for 'local' 'both' or 'remote' ~~ note to self to check this ~ though I actually did on the job but under pressure missed this and I did not move the switch as it looked in the right position.
Finally, when firing the PW from the camera's sync socket the PW must be plugged into the camera/flash socket on the PW ~~~ must remember this too, as with my other little problem on the shoot and the client present, I missed this little ditty too as it was plugged into the flash socket ~ in time I won't make this mistake again.
GerBee is offline   Reply With Quote
Old 28th of January 2008 (Mon)   #2
ben_r_
-POTN's Three legged Support-
ben_r_'s Avatar
Default Re: PW Plus II my observations.
Well, it sounds like you got all your issue worked out. Once you figured it out they are really a great combo huh?
[ Gear List | Flickr | My Reviews ] /|\ Tripod Leg Protection /|\
ben_r_ is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Interesting observations on the 5D Dchemist Canon EOS Digital Cameras 43 24th of September 2006 (Sun) 16:01
Just got a 17-55, initial observations calicokat Canon EF and EF-S Lenses 18 16th of August 2006 (Wed) 09:07
observations Two Fish Still Life, B/W & Experimental 7 7th of August 2006 (Mon) 16:39
5D Arrival...first observations. Masta Pasta Canon EOS Digital Cameras 10 17th of March 2006 (Fri) 06:20
