Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Compact Digitals by Canon
Reply
Thread Tools Display Modes
Old 24th of August 2002 (Sat)   #1
jjin
Default Problems in adding a new S30 Start-up Image
Followed the instructions given in the S30 Software Starter Guide manual to the letter, that is, created a new 320x240 pixels JPEG file startup5.JPG (The file size is 14,739 Bytes or about 14KB), connected the camera to the PC, started Canon's DoomBrowserEX 3.3.1.31, then selected Setup Options and then My Camera, then Add new Startup-Image, but it did not accept this JPEG image with the error "Cannot copy Startup5: The filename, directory name, or volume label syntax is incorrect."
Any idea what went wrong? Thanks.
James
jjin is offline   Reply With Quote
Old 7th of October 2002 (Mon)   #2
look30
Default Re: Problems in adding a new S30 Start-up Image
I might be wrong but I read somewhere that you can't change the picture on S30, it's a G2 only thing.
look30 is offline   Reply With Quote
Old 7th of October 2002 (Mon)   #3
Inactive member 38
Nope, it works for the S30 too. Dunno how to help you otherwise though, mine transferred fine.
Inactive member 38 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
how to do this: adding an image then go to index azpix Presentation 6 15th of March 2007 (Thu) 17:22
Adding signature to image puttick RAW, Post Processing and Printing 8 23rd of December 2005 (Fri) 16:30
Adding colour to a B&W Image? ATPL RAW, Post Processing and Printing 4 18th of September 2005 (Sun) 19:39
Adding image from one exhibit to another dohara Version 1.0-1.5 discussion 1 15th of January 2003 (Wed) 13:03
New S30 and two problems seattlepop Small Compact Digitals by Canon 0 30th of August 2002 (Fri) 22:52
