Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EOS Digital Cameras
Reply
Thread Tools Display Modes
Old 1st of February 2008 (Fri)   #1
Jefflesh
Default Indoor Sports and Canon 40D
Ok, here is a question for you guys that I am sure will result in a few different suggestions.
I will be shooting indoor sports for a little while and I am wondering which setting people typically shoot. M, Av, or Tv and why you shoot in that mode?
I will be using the following lenses, EF 85 f/1.8, EF 100 f/2.8 macro, or EF 70-200 f/4.0.
Thank you for your time.
Sincerely,
Jeff
Jefflesh is offline   Reply With Quote
Old 1st of February 2008 (Fri)   #2
gravy graffix
gravy graffix's Avatar
Default Re: Indoor Sports and Canon 40D
shoot in AV as low as you can ie: 1.8
look for shutter speeds above 300 depending on movement of subject.
adjust ISO to get your shutter in that area...
prob use AI servo as well... 1.8 is pretty shallow even at distance
and if you have AF set to af-on its like having 1 shot AND servo at the same time....
gravy graffix is offline   Reply With Quote
Old 1st of February 2008 (Fri)   #3
TeamSpeed
I do it a bit differently. I put the ISO at 3200, and go into Tv mode for indoor hockey. I set speeds at faster than 1/300th, and then let the aperture fluctuate accordingly. A puck or stick locked in air is more important to me sometimes than the dof. I have done it the other way as well though, as gravy described above. I also shoot the ice to set custom white balance because it is one less step later during the raw conversion.
I have used both the Sigma and Canon 70-200 f/2.8 lenses, the 100-400, and even the Bigma at hockey games. These last two lenses were not very useful during the heavy action however, but between periods, they were good for getting the fun mascot shots, center ice action, etc.
7D | 100L | 24-70L | 70-200L f2.8 IS | Σ 50-500 OS | Σ 50 1.4 | Tok 11-16 | 18-55 IS | 55-250 IS
Past Equipment | My Gallery | My Mini-Reviews
Resources For Sale: Focus Genie MicroAdjustment Chart | Gel Genie Flash Gel Holder | High ISO Denoiser Action
TeamSpeed is online now   Reply With Quote
Old 1st of February 2008 (Fri)   #4
Jefflesh
Thanks guys for your replies. Do you know anything about using flashes? I typically do not like to use flash but I may have to as some of these gyms are pretty dark. My questions is, are the speed-lights far superior than the camera flash? Now, I know that they are better but, how much better are they? I am sure that is not easy to answer.
Sincerely,
Jeff
Old 1st of February 2008 (Fri)   #5
BaumannPhotography
BaumannPhotography's Avatar
Manual
ISO 1600-3200
f/1.8-4.0 (because of your lenses)
SS aprox. 250-500
RAW
Spot metering (expose for skin/or 18% gray card)
Al Servo
Center focus point
6.5 fps
AWB
if lighting is constant than these settings should work fine, just play with it a little to get it to where you want it.
I have bad experience with Tv, and Av mode because that camera makes the decision for me which I don't get satisfactory results with, for instance if one team has white uniforms and the other red/black and you fill the frame with the player you will get 2 very different results, in Av mode if you are set for 1.8 and shoot the white team, it's no problem, but the red team can effect your shutter speed to the point that it will cause blur. This is not always the case because other factors come into play, But in highschool gyms I find that it is best to take control of whatever you can. Hope this helps
www.action-fx.com
1Ds Mark III - 1D MIIN
300L 2.8 IS - 24-70L 2.8 - 70-200L 2.8 IS - 85L 1.2
580 exII - 430ex
BaumannPhotography is offline   Reply With Quote
Old 1st of February 2008 (Fri)   #6
partsman
i have a rebel xt and shoot a lot indoors. the 430ex speedlight was the best purchase i've made. literallly the difference between night and day compared to on camera flash. also lots of other options for bouncing, focusing in low light etc.
partsman is offline   Reply With Quote
Old 2nd of February 2008 (Sat)   #7
Jefflesh
Ok, I went and bought a speedlight 430 last night to use with the 40D and I must say that I am pretty happy with the results, see for yourself.
The flash worked great!
Photo taken with the 70-200 f/4.0 at 1/200 sec shutter and ISO 400.
Sincerely,
Jeff
Old 2nd of February 2008 (Sat)   #8
Mike R
Remember to ask the coaches from both teams if flash is OK. This will save you from looking unprofessional if they don't allow it and need to stop an event to tell you to turn it off. If you are covering more than one event be sure to ask again. While one may not have a problem, another might. I like the shot.
Mike R
www.mikerubinphoto.com
Mike R is offline   Reply With Quote
Old 3rd of February 2008 (Sun)   #9
Joe Cyr
Joe Cyr's Avatar
Sincerely,
Jeff
Nice job... next time go up to 800, with the flash on, and see the results. I think you will like them.
Canon 1D (MARK III),
10d, Elan IIE (old school), 580exII
70-200 f/2.8L, 17-40 f/4L, 85 1.8, 50 1.8 (nifty)
http://josephcyrphotography.smugmug.com
Joe Cyr is offline   Reply With Quote
Old 3rd of February 2008 (Sun)   #10
PhotosGuy
Moderator
PhotosGuy's Avatar
More: Question and Answer Sessions with some noteable POTN Members
Sports Shooting Tutorials and Advice
Q&A Session with Gmen: Sports Photography
The week's sporting events in images...
Why do you guys use manual? AV makes more sense.
http://www.photography-on-the.net/fo...d.php?t=130176
www.FrankCizek.com
PhotosGuy is offline   Reply With Quote
Old 3rd of February 2008 (Sun)   #11
Jefflesh
Mike,
Thanks for the advice, I didn't think if that, should I also ask the refs?
Sincerely,
Jeff
Old 3rd of February 2008 (Sun)   #12
Jefflesh
Joe,
Thanks or the advice. I have to ask, how will that improve my picture? Will it make the picture more sharp?
Sincerely,
Jeff
Old 3rd of February 2008 (Sun)   #13
emtp563
emtp563's Avatar
I was at a sporting event last night at the Meadowlands. It was a monster truck race and I used manual exposure. This would apply to you also. The trucks's colors ranged from black, to blue, to orange, to red. This would effect exposure. I set my aperture to 2.8, ISO to 1600, and I used manual and spot metered off of the stadium floor. To my surprise, I achieve a shutter speed of 1/640 and I knew that was more than enough for what I needed. I could have decreased the ISO or I could have decreased the aperture a little if I wanted to, but I knew my lens performs well at f/2.8 and the camera handles ISO 1600 well. So it didn't matter if the stadium suddenly lit up all of their spotlights, or if flames shot out of an engine- my exposure was always constant and correct.
*cameras: Canon 1D Mark III | Canon 1D Mark II | Canon 1D "Classic" | Canon S95
*lenses: Canon 16-35L f/2.8 | Canon 24-70L f/2.8 | Canon 70-200L f/2.8 IS | Canon 1.4x TC II
*accessories: Canon 580EX II/430EX | Quantum Turbo SC | CP-E4
http://www.cyclingcaptured.com
emtp563 is offline   Reply With Quote
Old 3rd of February 2008 (Sun)   #14
JeffreyG
JeffreyG's Avatar
Joe,
Sincerely,
Jeff
The problem is that the background is so dark, so the picture is not pleasing. Faster aperture and high ISO will allow more ambient exposure which will brighten it up.
I don't shoot indoor sports with flash. I shoot M mode and adjust my settings to push the histogram right to control the noise. I prefer ambient for the balance and because the flash can distract the atheletes.
5D, 85mm, 1/320, f/2, ISO3200.
My personal stuff:http://www.flickr.com/photos/jngirbach/
Commercial sports:http://girbach.zenfolio.com/
I use a Canon 5D and 1DIV and a Panasonic GF-1 Gear List: http://photography-on-the.net/forum/...postcount=1550
JeffreyG is online now   Reply With Quote
Old 3rd of February 2008 (Sun)   #15
khaz
Can you explain pushing the histogram to the right to control the noise? How does that control the noise?
Kevin
Just trying to get better!
khaz is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Canon EOS 40D - Sports Settings hammer5680 Sports Talk 8 29th of January 2011 (Sat) 13:35
40D settings for indoor sports? CCapriati Canon EOS Digital Cameras 75 19th of February 2010 (Fri) 09:51
Canon 40D in Sports genebrowder Canon EOS Digital Cameras 8 16th of September 2007 (Sun) 18:14
EF 85 1.2L for indoor sports ust82gopher Sports Talk 20 20th of November 2006 (Mon) 21:01
Canon 70-200L f4 for indoor sports possible? PeteNJ Sports Talk 20 3rd of February 2006 (Fri) 18:26
