Thread started 05 Feb 2008 (Tuesday) 11:19
Studio flash vs. speedlights
Feb 05, 2008 11:19 |  #1
PROs and CONs of speedlight vs. studio strobe
Pro speedlight:
Very portable, no reliance on AC outlet
ETTL or Auto flash exposure control
Minimal setup time on location
Very rapid light output, typically 1/1000 - 1/10000
Pro studio strobe:
Higher light output than speedlight
Modelling light lets you immediately SEE the effect of setup, without taking a shot
Many light modifiers available (umbrella, softboxes, snoots, grids, barndoors)
Radid recycle, typically <1 sec.
Unlimited flashes (wall power)
Con speedlight:
Slow recycle from full output, without supplemental expensive battery packs
No ability to see affect of lighting setup without taking a shot
Need to transfer photo to a computer to see image at full size to assess lighting
Fewer available light modifiers (umbrellas, minisoftbox)
Con studio strobe:
Always have to find AC outlets
Slower to set up on location
More cables (AC) to trip over
No ETTL control, no Auto flash; manual only
Need separate flashmeter for efficiency of setup
You need to give me OK to edit your image and repost! Keep POTN alive and well with member support​hp
Curtis ­ N
Master Flasher
Feb 05, 2008 12:04 |  #2
That's a very nice synopsis, Wilt.
To put the power aspect into perspective, here are the readings I got using a Speedlite vs. an Alienbees B800 strobe, shooting into a silver umbrella and measured at a distance of 9 feet from the umbrella:
B800 full power: f/13
580EX II full power: f/4.5
That's a difference of three stops. That means it would take eight 580EX II Speedlites to equal the output of one B800 strobe. Speedlites are remarkably efficient when used direct, because of the reflector and fresnel lens that concentrates the light where it's needed. But any sort of diffuser or modifier throws this efficiency out the window.
This doesn't mean that a Speedlite won't do the job. But it depends on the job. For three out of the last four portrait shoots I did, I used Speedlites because of the portability and ease of setup advantages that Wilt mentioned. But they were single portraits so I could put the light very close to my subject, and I was dealing with adults with the patience to wait for the units to recycle. Not every job gives us these luxuries.
Double ­ Negative
Feb 05, 2008 14:30 |  #3
There's also the matter of remote firing.
Speedlites need another Speedlite or ST-E2 for wireless, Off-Camera Shoe Cord for wired as far as Canon solutions. There are also third-party solutions, but can be flaky (such as optical triggers not working on Speedlites). The 580EX-II now features a PC sync socket, opening up other means. You can use hotshoe adapters also.
Studio strobes require a PC sync cable or radio trigger (such as Pocket Wizards, Einchrom Skyports or other third-party). Many have built-in optical triggers at least.
La Vida Leica! (external link)LitPixel Galleries (external link) -- 1v-HS/1d Mk IIn w/E-1 & Op/Tech straps
15mm f/2.8, 14mm f/2.8L, 24mm f/1.4L II, 35mm f/1.4L, 50mm f/1.2L, 85mm f/1.2L II, 135mm f/2.0L
16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100-400mm f/4.5-5.6L IS, Extender EF 1.4x II & 2x II
6,901 views & 0 likes for this thread
version 2.0 /
Latest registered member is dejs
423 guests, 368 members online
Simultaneous users record so far is 6430, that happened on Dec 03, 2017 Digital Photography Forums is the website for photographers and all who love great photos, camera and post processing techniques, gear talk, discussion and sharing. Professionals, hobbyists, newbies and those who don't even own a camera -- all are welcome regardless of skill, favourite brand, gear, gender or age. Registering and usage is free.
