Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Weddings and Other Family Events Talk
Reply
Thread Tools Display Modes
Old 9th of February 2008 (Sat)   #1
mudbug46
Default Mixed Race Wedding
First I'm not a racist and this strictly a lighting question. I normally don't do alot of weddings so I have never come across this before. I am shooting a very dark skinned black man wearing a white tux to a very light skinned white lady also wearing white soon I always meet with the couple in the church before I shoot them to go the layout and do some light readings. Should I overexpose by 1 fstop to be able to make out facial features on the man and risk blowing out the bride. Just curious any help would be appreciated.
mudbug46 is offline   Reply With Quote
Old 9th of February 2008 (Sat)   #2
Scott_Quier
Default Re: Mixed Race Wedding
It's all about incident light readings, not reflected light readings. Measure the incident light, and expose for that. You may be able to get away with +1/2 stop, but more than that will blow out the dress and his tux. In addition, if you expose based on the incident light readings, his skin will be exposed correctly. It's a challenge, but no more so then shooting a bride and groom together where the bride is in traditional white and the groom in traditional black.
Scott_Quier is offline   Reply With Quote
Old 9th of February 2008 (Sat)   #3
sobad
Howdy neighbor. I second Scott's comment, in situations like you described i usually go +1/2 stop and its still a challenge. A good flash is a must in my opinion.
Canon 1DMKIIN, 7D, 40D, 70-200 f/2.8L IS, 17-40 f4L, 28-135mm IS, 85mm 1.8, 35mm 2.0, 50mm 1.8, , 18-55mm kit, 430EX II, 580EX II (2), AB800 x 2
Tamron 17-50 f/2.8
sobad is offline   Reply With Quote
Old 9th of February 2008 (Sat)   #4
canonloader
canonloader's Avatar
Great question. Can you use fill flash? Or is flash taboo when shooting weddings? It would solve the problem though.
Mitch- ____...^.^...____
My Microscope Stuff
Gear List, My Flash Gallery, My You Tube, Ride My Bi-Sickle
canonloader is offline   Reply With Quote
Old 9th of February 2008 (Sat)   #5
mudbug46
Yes will be using a good flash Canon 580EXII
Will shoot some test shots before and will post
Old 10th of February 2008 (Sun)   #6
canonloader
I'll be interested in seeing them, but I think that is going to be the fix for your problem. I suggested it cause I know that fill flash works wonders on black birds in snow, black and white birds, and white birds against dark backgrounds.
My Microscope Stuff
Old 10th of February 2008 (Sun)   #7
bieber
bieber's Avatar
There are basically two ways to resolve detail in a black man's face: overexpose and blow out the whites, or put a light on him that produces some direct reflection. The latter is obviously the preferable choice, and the 580EXII is the way to do it. If at all possible, get it off your camera, but if you can't then head-on works, too...
EOS 20D w/ BG-E2 grip
Nifty fifty, EF 28mm f/2.8, EF 70-200mm f/4L USM
Speedlights SB-25/SB-26/580EX, Pocket Wizards and such
My Gallery
bieber is offline   Reply With Quote
Old 10th of February 2008 (Sun)   #8
canonloader
I was going to suggest a diffuser, so you don't get any pointlights. A piece cut from a plastic milk jug and held on with a rubber band works wonders.
My Microscope Stuff
Old 10th of February 2008 (Sun)   #9
bieber
bieber's Avatar
Ehh, it won't really do anything that ceiling bounce can't. If (and this is a big if) the ceiling in the church is low enough to get a reasonable ceiling bounce, just point the flash up at it and use an index card and a rubber band to send a little bit of light directly at the subject.
My Gallery
Old 10th of February 2008 (Sun)   #10
canonloader
I would at least take one with me. Bounced light takes on a tone of what it bounces off of, like wood. The diffuser won't. Try both.
My Microscope Stuff
Old 10th of February 2008 (Sun)   #11
PhotosGuy
Moderator
PhotosGuy's Avatar
Test this work around before the shoot: Get the flash off the cam to his side of the shot. (have someone hold it) The light fall off will give him more light than it will give her.
www.FrankCizek.com
PhotosGuy is online now   Reply With Quote
Old 10th of February 2008 (Sun)   #12
mudbug46
Thanks for all the suggestions. Just don't want to have to spend the next 2 weeks in pshop lightenor darkening all images.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Red Bull Air Race - Race Day souporman Motorsports 10 10th of August 2007 (Fri) 15:38
shooting a mixed wedding.... LeesaB Weddings and Other Family Events 5 30th of December 2006 (Sat) 13:31
mixed race wedding, exposure? Bushman Weddings and Other Family Events 4 30th of March 2006 (Thu) 20:30
Mixed Bag - Wedding Shots. MattyB People 14 19th of October 2005 (Wed) 02:06
First wedding shoot (mixed emotions) Photonut29 People 3 15th of May 2005 (Sun) 14:04
