Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Accessories & Storage
Reply
Thread Tools Display Modes
Old 28th of August 2002 (Wed)   #1
jd_D60
Default Extra Storage & Compaq ipaq
I gathered a great deal of information from this very informative site and so looking for more advice or experiences.
I have recently bought a D60 and have 64Mb and 128Mb CF cards which I download through the D60 onto P4 2.2Ghz PC, shooting High/fine I am good for around 25 shots per 64Mb.
One problem is the D60 viewfinder is a bit too small to really know whether you can delete a shot or not.
I also own an ipaq 3660 (64Mb) Pocket PC 2002
I am looking for more storage options, probably 1Gb and think the IBM microdrive is in pole position.
What I am wondering is does anyone use the ipaq for viewing photos, do you need any extra software, what CF jacket is recommended (bearing in mind the battery life of an ipaq), is the ipaq compatible with microdrives and is data transfer (USB cradle) any faster/slower
Alternativley the 10Gb digital wallets look good for transfering images but this might be yet another gadget to carry around rather than using my current investments to their full potential.
Any advice always welcome
john
jd_D60 is offline   Reply With Quote
Old 28th of August 2002 (Wed)   #2
hawg
Default Re: Extra Storage & Compaq ipaq
the ibm microdrive will work in an Ipaq I use it for storing Mp3s but I do not think it will work very well to view files because of the resolution. The pic will be bigger than the screen so you only a portion of your pic at a time. Also accessing the Microdrive for viewing might take longer since the Ipaq is running at around 233 MHz and only has 64 meg of RAM. Then again I have an older version of the Ipaq so things might have changed.
hawg is offline   Reply With Quote
Old 29th of August 2002 (Thu)   #3
henkbos
Use the D60 and Ipaq as well. Wondering if anyone has experimented with using the Ipaq as viewer with any kind of remote control program.
Is there any software that will run under Windows CE?
Henk
henkbos is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
What do you do for Extra Hard drive space/storage for Large files/Raw ?? OverRunWithSons Accessories & Storage 15 11th of October 2005 (Tue) 16:41
Extra storage - what to buy? tommykjensen The POTN Lounge 7 2nd of October 2004 (Sat) 21:30
Extra rechargable battery storage LSC Canon G-series Digital Cameras 0 9th of April 2004 (Fri) 08:24
Extra Storage jd_D60 Accessories & Storage 9 27th of March 2003 (Thu) 08:30
