Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > General Photography Talk
Reply
Thread Tools Display Modes
Old 16th of February 2008 (Sat)   #1
jack Sparrow
Default Problem with changing light
Hi all.
Yesterday i was at a butterfly farm, and i took my canon 400d.
My questionis how do you quickly change your camera setting for changing in light condition, like one shot can be over exposed and one could be under in a matter of seconds. i had my camera set to manual, and was just using the dial on the front to change shutter speed, but im just wondering how other manage to control fast light changing conditions.
regards
Jack
jack Sparrow is offline   Reply With Quote
Old 16th of February 2008 (Sat)   #2
Cody21
Cody21's Avatar
Default Re: Problem with changing light
In constant changing light situatons, it might be better to set to Aperture Priorty mode and let the camera manage the shutterspeed for you. But that might also result in underexposed situations thus requiring a faster ISO ... just a thought.
5DM3 | 16-35mm f/2.8L II USM | 70-200mm IS f/4L | 24-105 f/4L | Sigma 18-50mm f2.8 | Speedlite 430EX
Cody21 is offline   Reply With Quote
Old 16th of February 2008 (Sat)   #3
jack Sparrow
cheers for that, my problem is ive got stuck working in manual and dont even give the other settings a thought now, maybe i should change my chain of thought
regards
jack
Old 16th of February 2008 (Sat)   #4
SkipD
SkipD's Avatar
Jack, I also work with the camera in manual exposure mode most of the time. I often use a handheld meter in incident mode to measure the light falling on the subject and transfer that reading to the camera's settings. While I use the hand held meter for the specific measurements that I transfer to the camera, though, I use the camera's built-in meter to clue me in on possible changes of the light level from time to time. When the built-in meter shifts, I take another reading with the incident meter.
Why do I use the handheld meter? It's because the camera's built-in meter is often fooled by the color(s) or reflective characteristic(s) of the subject. An incident meter is not affected by the subject at all. You merely need to read light that is falling on the subject or light that is the same as that falling on the subject (light from the sky, for example, assuming sky light falling on your position is the same as that falling on the subject).
Skip Douglas
A few cameras and over 45 years behind them .....
SkipD is offline   Reply With Quote
Old 16th of February 2008 (Sat)   #5
PhotosGuy
Moderator
PhotosGuy's Avatar
But how much time was there between changes? Pick your shots, & I'll bet there was way more time than it takes to do this: Need an exposure crutch?
www.FrankCizek.com
PhotosGuy is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Anyone else having a problem changing sigs? Radtech1 Forum Talk 11 23rd of December 2007 (Sun) 01:12
Changing light bikerider Urban Life & Travel 19 11th of September 2007 (Tue) 05:24
Trouble changing a light bulb FotOz The POTN Lounge 3 25th of July 2007 (Wed) 03:02
Changing hosts - Problem Downgrading Mysql DB lost Version 1.0-1.5 discussion 15 4th of October 2006 (Wed) 16:38
Another take on the changing light JLP9639 Nature & Landscapes 15 6th of July 2006 (Thu) 22:24
