#1 |
Hi All,
Ive been really busy working on a new website which has taken so long! I would really appreciate some feedback. Firstly not all the graphics are optimised yet, so some pages are a little slow. None of the galleries are loaded yet, but there are quite a few images on "Most Recent" What Im aftre are some opinions; I initially used an image as a background, but then hit upon another version, so what Id like to know is which do you prefer visually? The first is as my sig link bt just in case http://www.philnortonphotography.co.uk the second is: http://philnortonphotography.co.uk/black Im leaning towards the second, but would really like some opinions? Thanks Phil
Experience is something you get after you need it. 5D+Grip, 24-105L, 17-40 L, 100-400 L, 400D+grip, EFS17-85 IS, EFS17-55IS, EFS60Macro, EF70-300IS, EFS10-22, 580EX2 flash, Manfrotto 190ProB & Ballhead. Plus a bunch of bits. http://www.philnortonphotography.co.uk |
| sponsored links |
#2 |
Hi Phil,
Very nice layout, I like it. I'm kind of partial to the first one, actually. The second one seems a bit odd with the really dark background photo in some areas, solid black in others. It doesn't look quite complete, if that makes sense. Some other notes... Yes, the pages are huge, I'm wondering if the program you're using for generating this site is putting a bunch of that javascript in, and whether it's really all necessary. There are also validation errors you might check - though if the whole site is built through a WYSIWYG tool, I'm not sure what you'd do about them. I was intrigued by your comments about color quality, that's really a neat thing to have. I may "borrow" the idea if you don't mind. But I did have a couple edits here. Your first paragraph states that the images have been carefully balanced for color with photoshop, etc - but does not mention that you've calibrated your monitor. Then you go on to suggest that I might need to calibrate my monitor. I think you should add that your monitor *is* calibrated somewhere? Also you then state that "...unfortunately MS IE does not color manage...". I'm not sure why you head in that direction. For one, I wasn't using IE, to view your site, and secondly as you say virtually no common browser does. So this is not an IE "issue". Then you go on to say that your images have an sRGB profile - doesn't that mean that the discussion about IE not being color managed is a moot point? (I actually don't know - I'm asking). On your left side navigation, the little lozenge-shaped bullets are not aligned with the text to their right - they're shifted up 10 pixels or so. Depending on the background color, at times your text is a bit hard to read. Maybe you could brighten it up just a skosh? (yes, my monitor is calibrated Dave |
#3 |
Hey Phil, congrats on your new website. Here a couple of thoughts, take what you like
There are much cleaner ways (instead of tables and frames) to accomplish the layout you are looking for. Those iframes are completely blind to search engines. The corners are a little weird, In my opinion, rounding them completely off would be better. The gray text is a fuzz to dark, something closer to white (and a shade bigger) would be more comfortable to read. Also, the line-height is a little tight. When looking at images, the page reload to switch images is really disruptive. There are tons of free javascript (or flash) libraries that you could use to load up and serve your gallery with no page reload. Thanks!
Travis Isaacs http://travisisaacs.com Canon 5D MK II, 24-105mm f/4L IS, Canon EF 85mm f/1.8, Canon EF 50mm f/1.4, 580EX II |
| sponsored links |
#4 |
Phil, I love the website design, very good looking.
I'm defiantly partial to the 1st one. The only thing that I could see that may improve it in my eye, but still great, is if the background image of the 1st layout would rotate may be. Or when you go to a different page, the photo would change. But overall great layout. |
#5 | |
No I dont mind if you borrow the idea of colour. I added it because so many people are using monitors not calibrated, tho most on here prob have. The page was just to give some general ideas.....Ive used other monitors to check and found that just altering gamma, contrast etc helped alot when viewing the tone bar i included, which I found online somewhere. Yes your right about comments on IE being moot.........Ive read that images for web sould have an embedded srgb profile, tho quite why when browsers dont colour manage I dont know. But I have found that images without any profile display erratic. What browser are you using? Im interested in the validation errors, how can I chech and are they caseing a problem? Because of the prog Im using Im not sre if I can do anything about it. The buttons being displaced are a problem. The software has a bug that means sometimes some objects can be displaced slightly......I had to move all the buttons up 6px because they were moved down to compensate in IE, but it seems your browser may be shifting them up a tad. Thanks for taking the time Phil
#6 | |
Also is it the black site with the corners looking odd? They looked fine yesterday but now Ive had a break yes they do need attention. Thanks Phil
#7 | ||
Dave |
#8 |
There's a part on your colour page that says "Please not not all images on this site..." that needs to be cleaned up.
Seems it should read as "Please note that all images...".
Website: Iowa Landscape Photography | Blog | Gear List & Feedback Equipment For Sale: Canon PowerShot A95 - Canon Tripod Mount Ring B (B) |
#9 | |
ooops thanks!
#10 | |
I solved the problem with the buttons, instead of using my own custom made I used a "standard" button in the prog and customised it. Have not reuploaded it yet but did a test page just with the buttons and checked it in Firefox and its fine, so thanks for the tips on that. You seem to know coding, how would yo go about buiding at site like mine? Phil
#11 | |
When I do a site, my default presumption is that it will be html & CSS only. I will add Javascript and Flash only as needed for effect, but not when I can do the same thing with CSS. For example your navigation and many of the hot spots are graphics using Javascript for effects, where I would not consider doing it that way - I'd do this with CSS. It would be faster on the screen, with more compact code. Actually, I'm not sure I see a single place on your site which couldn't be done with html & CSS. I would probably use Flash just on your galleries though, because it does make for a site that's easier to maintain (adding/deleting photos) than doing it with CSS. Dave Another thing I use sparingly is frames & iframes. |
#12 | |
The galleries are actually going to be built with jalbum, its an image library prog with lots of skins available, so the one I will use is Fotoplayer..easy to update, built in cart etc....and show it on the site with iframes. Now I discovered Mediator uses iframes which is gonna screw me for browsers is there a way around it? I was thinking what if I had an entry page built that is browser friendly, and a link to the main site? At least I could get indexed, and users can always return to the main site, not the entrance page...just brain storming. Phil
#13 |
JAlbum is a great tool, I'm glad you found it. I use it for my galleries too (www.pixf.com) as I need to push out hundreds of event photos at a time.
I have seen sort of a wacky solution for the frames issue (presuming you mean that you can't have a url for any of the "sub-pages" - only the main frames page), but it's not something I would recommend (and not simple to implement - I'd call it a hack). But as far as getting indexed, I don't see a need for an entry page - you should be able to put content on your current home page which will get indexed as usual. Maybe I'm missing your point though. Dave |
#14 | |
I trawled the net for days and used all sorts of other progs and jalbum is so good.....I couldnt bear the thought of manually arranging hundreds of images....and trying to make simple changes! You understood right about the entry page, to be honest its not something I want to do, I hate entry pages. I can include keywords, but not really sure what keywords. Any tips? I also discovered I can atomatically generate a site map which is uploaded, a new feature added to help search engine spiders........ I corrected the nav links, and updated the colour page.........theres so much info out there but found this to e usefull http://www.gballard.net/psd/go_live_...Gprofiles.html# Phil
#15 | |
Code:
<body onUnload="PageUnloading()" onLoad="hist = new historychangeevent();" style="background:#2C2C2C;">
<table cellspacing="0" cellpadding="0" style="width: 100%; height: 100%;">
<tr>
<td id='maintd'>
<iframe id="mainframe" src="" frameborder="0" scrolling="no"></iframe>
</td>
</tr>
</table>
Since you are using a WYSIWG tool, there is probably not much you can do about it, other than write the HTML yourself. Thanks!
| Thread Tools | |
| Display Modes | |
| Do you just offer Print/Portrait Packages, or do you offer custom orders? | sonshine_rae | The Business of Photography | 4 | 7th of September 2007 (Fri) 01:28 |
| Need input for website decision | dave_borg98 | The Business of Photography | 6 | 20th of June 2007 (Wed) 08:10 |
| Need input on website | canoned | Presentation | 10 | 1st of February 2006 (Wed) 10:49 |
| Oh No......another Error 99 thread......seriously though...please offer your input. | ImperialRed | Canon EOS Digital Cameras | 13 | 18th of August 2005 (Thu) 21:16 |
