Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 18th of October 2004 (Mon)   #1
HOMEYJAMES
Default studio lighting
I would like to convert my garage into a studio. What type of lighting would be best...strobe or continuous I shoot digital. Thanks Homey
HOMEYJAMES is offline   Reply With Quote
Old 18th of October 2004 (Mon)   #2
scottbergerphoto
scottbergerphoto's Avatar
Default
http://www.photography-on-the.net/fo...ad.php?t=45269
One World, One Voice Against Terror,
Best Regards,
Scott
ScottBergerPhotography
scottbergerphoto is offline   Reply With Quote
Old 18th of October 2004 (Mon)   #3
FlipsidE
FlipsidE's Avatar
Default
Linkage...
http://www.photography-on-the.net/fo...ad.php?t=45482
FlipsidE
FlipsidE
FlipsidE is offline   Reply With Quote
Old 19th of October 2004 (Tue)   #4
mjordan
mjordan's Avatar
Default
Monolights are the best choice in most cases. They are light, can be moved around easy, the flash themselves don't put off more than a burst of heat (the modeling light can get hot), will last for years and you can use a lot of different types of light modifiers on them (umbrellas, softboxes, light panels, etc.).
Continuous lights, be they cold (floresent) or hot (high wattage photo floods) are good in that what you see is what you get. They are not so great in that the hot lights put off a lot of heat. Heat that can not only make a room hot, but you have the possiblity of putting something on fire or burning someone if it falls on them or it is touched while on. Cold lights don't have this problem, but they also don't put out the light that monolights and hot lights can put out. This might not be a problem or it might be.
There are a lot of choices out there. What ever you buy, you will want to look at the options, sizes, how many add-ons you can get for them, cost, power, etc. If you are going to be shooting day after day after day, White Lighting would be a good choice. If you are only going to be shooting maybe on weekends or the occasional evening, then the Alien Bees, Photogenic or the SP Excalibur line are good choices to look at.
Mike
Hillsboro, OR
Canon 1DMKII and lots of "L"
http://www.sitnprettyphoto.com
mjordan is offline   Reply With Quote
Old 20th of October 2004 (Wed)   #5
HOMEYJAMES
Default
Thanks Guys...This really helped me out !!!!!!! Homey
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
help with studio lighting photogirl27 Small Flash and Studio Lighting 2 3rd of December 2006 (Sun) 11:11
Studio Lighting lovelace415 Small Flash and Studio Lighting 11 13th of February 2006 (Mon) 18:55
Studio lighting... Scott111184 Small Flash and Studio Lighting 1 13th of February 2006 (Mon) 17:20
Studio, studio lighting, and flash meters? BTBeilke Small Flash and Studio Lighting 15 6th of December 2005 (Tue) 13:12
Home Lighting as Studio Lighting for Practice? BJClarke001 Small Flash and Studio Lighting 16 23rd of January 2004 (Fri) 00:19
