#1 |
well i read about it now i just have a few questions.
What is a good numbers of exposurs to take to make a hdr. how far off should each exposure be? by this i mean in the light meter in my 30d, should one be -2 then 1 normal in the middle and +2? i use photomatix. so all you do is just open the three photos and generate them to hdr then mess around in tone mapping.. correct? thanks espo heres my first hdr attempt.. its only two exposures though. lmk what you think, am i on the right track? thanks again ![]()
Canon 30D | Canon 50mm 1.8 | Canon 430ex II | ThinkTank Streetwalker Hard Drive | Selling Tokina 10-17mm 3.5-4.5 www.espospowdercoating.com |
| sponsored links |
#2 |
You can use as many exposures as you want.. I usually use -2, 1 ,2.
and yes you just generate the photos into hdr and then go into tonemapping. All the settings may be a bit confusing so I'll give you a link to read up about hdr. just play around and see what comes out. thats what I did. http://vanilladays.com/hdr-guide/ boucher.
#3 |
Moderator
Yes I agree with the above, however I mostly use HDRs for high contrast interiors.
Landscapes are normally best treated with GND techniques, either in camera or in PP.
My Photography Home Page RSS Feed MP-E, EF 100mm, EF 180mm : The Macro Dark Unholy Trinity : Bow down before their darkness and despair! Gear List FAQ on UV and Clear Protective Filters Macrophotography by LordV |
| sponsored links |
| Thread Tools | |
| Display Modes | |
| Using HDR in CS3, tips help, links | buyusfear | RAW, Post Processing and Printing | 12 | 17th of December 2012 (Mon) 03:41 |
| HDR Tips | CameraDaddy | RAW, Post Processing and Printing | 34 | 19th of October 2009 (Mon) 15:59 |
| HDR, tips? | Chris Davies | RAW, Post Processing and Printing | 1 | 8th of December 2007 (Sat) 09:09 |
| HDR photogrophy - tips and tutorials? | JasonMX | General Photography Talk | 2 | 31st of July 2006 (Mon) 16:05 |
| HDR manualy done -no photomatix, no Merge to HDR | chansh | Still Life, B/W & Experimental | 10 | 19th of May 2006 (Fri) 14:30 |
