Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > General Photography Talk
Reply
Thread Tools Display Modes
Old 4th of March 2008 (Tue)   #1
n1as
Default Flash bracket or shoot everyting horizontal?
Using a 40D, should I get a flash bracket so I can turn the camera vertical, or is it just fine to shoot eveything with the camera horizontal and crop the final image vertically?
I get 2592 pixels across the short dimension of the sensor. If that were scaled to a 10" print, that would still be over 250 pixels per inch. I should be able to take a horizontal photo, and crop the center to print just a vertical 8x10, right?
- Keith -
http://darwinphoto.zenfolio.com
n1as is offline   Reply With Quote
Old 5th of March 2008 (Wed)   #2
SBCmetroguy
Default Re: Flash bracket or shoot everyting horizontal?
Why not just purchase a bracket and save yourself a lot of cropping? Seriously, I never thought I would love a bracket until I got mine... been glad ever since.
SBCmetroguy is offline   Reply With Quote
Old 5th of March 2008 (Wed)   #3
Zansho
"I'd kill for a hot pink 40D"
Zansho's Avatar
Get a flash bracket and save yourself tons of time editing for crop. It's also worthwhile to have if you have any long lenses, as sometimes the flashgun will catch the tip end of the lens barrel. It's also great to have for throwing shadows more "behind" the subject instead of to the side, and and help eliminate some red-eye as well.
www.innerlightcreations.com - Gear? The stuff I have, does everything I need, and I don't worry about the latest and the greatest anymore - I worry about getting the best images I can.
Zansho is offline   Reply With Quote
Old 5th of March 2008 (Wed)   #4
scot079
scot079's Avatar
Yep get a flash bracket and off shoe cord. I use a Custom Brackets Digital T (~$50) but i have a Newton flash rotator on my perpetual gear wish list.
- Tim
scot079 is offline   Reply With Quote
Old 5th of March 2008 (Wed)   #5
n1as
DRAT Drat drat - that's NOT what I want to hear
The reason to not get a bracket is cost. I'm a believer in having the right tools for the job. If I get a bracket it will be a Newton folding flash rotating bracket and I'll be spending $200 or so on it. Plus another $70 on the TTL flash cable.
If I could just shoot horizontal (bouncing the flash, of course) then I'd save $270.
I suppose I could buy a cheaper bracket but from what I've read, most folks aren't that thrilled with the $80 units.
Well, I was planning on the Newton, I guess I'll continue to plan on it.
- Keith -
Old 5th of March 2008 (Wed)   #6
chs4
What's your time worth and how much cropping do you foresee doing? May not be such great savings in the long run.
Get the bracket...you know you want to.
Chip Slattery
350D w/Grip | 70-200 2.8L | 17-85 4-5.6 IS | 50 1.8 | SIGMA 17-70 2.8-4.5 DC | EF-500 DG SUPER | BOGEN 3021PRO/3030 | BOGEN 680B/3229 | DOMKE F-2 | KATA T-212
chs4 is offline   Reply With Quote
Old 5th of March 2008 (Wed)   #7
JWright
JWright's Avatar
What flash are you using? Most of the Canon flashes will swivel allowing you to bounce them off the ceiling when the camera is in portrait orientation. Even though I have a rotating flash bracket that will elevate the camera a foot above the camera, I rarely use it, choosing instead to keep the flash mounted to the camera and just bounce off the ceiling when I rotate the camera vertically.
John
JWright is offline   Reply With Quote
Old 5th of March 2008 (Wed)   #8
n1as
Camera is a 40D, 580 EX-II flash with a Demb bounce card. Yes, I can swivel the flash to bounce of the ceiling for H or V shots ... but the problem is when I have to take non-bounced shots using just the direct flash. I plan to use the Demb card to bounce the flash but it will still be pretty harsh & direct and will cast shadows that are unflattering.
- Keith -
- Keith -
Old 6th of March 2008 (Thu)   #9
asysin2leads
I'm kissing arse
asysin2leads's Avatar
I have the Stroboframe Flip Bracket. I like it, but it takes a little bit of getting used to. http://www.bhphotovideo.com/c/produc...p_Bracket.html
My dad is a fabricator and he's making me a flash bracket similar to this (http://www.bhphotovideo.com/c/product/464814-REG/Custom_Brackets_CBMINIRC_CB_Mini_RC_Camera_.html
. It will be laser cut and powder coated. That way I can work with the grip on my camera.
asysin2leads is offline   Reply With Quote
Old 6th of March 2008 (Thu)   #10
tonylong
....winded
tonylong's Avatar
- Keith -
When you're doing direct flash, you are indeed screwed. In fact, direct flash can be pretty ugly whether in portait or landscape mode.
The trouble with brackets is when you're out of the "studio" -- on the move, in the city, grabbing shots, making do with the environment and either don't have a bracket mounted or don't have one with you -- you have the 580, which has a built-in bounce card. I'd use that together with an attached diffuser and see what you can get. Experiment with different angles and use flash compensation!
It would be nice if we could carry around reflectors and brackets everywhere we go, but not so practical. If portrait mode gets the shot, you have to twist things around as much as you can, because those flash shadows can be ugly!
Tony
Tony Long Photos on PBase
Wildlife project pics here, Biking Photog shoots here, "Suburbia" project here! Mount St. Helens, Mount Hood pics here
tonylong is offline   Reply With Quote
Old 6th of March 2008 (Thu)   #11
n1as
That's the other bracket I considered. I've heard from several that it leaves something to be desired. So rather than spending $70 on something that is a bit heavy and awk to use, I'm going to spend $200 on something that really does the task.
- Keith -
Old 7th of March 2008 (Fri)   #12
Time Thief
Time Thief's Avatar
Buy a Newton and enjoy. I love mine.
40D, 20D, 24-105 4.0L, 24 2.8, 70-200 2.8L, 18-55 kit lens, 2 x 430ex's, way too many extras to list and even more that I need
DPP tutorials: http://www.usa.canon.com/content/dpp2/index.html
Time Thief is offline   Reply With Quote
Old 7th of March 2008 (Fri)   #13
sapearl
emailed Tim some prozac
sapearl's Avatar
Hi Keith..... ah, choices choices choices.....
I hate buying things twice. I research what works and really does the job right, and then I save up and buy it. Stroboframe makes some very adequate and economical brackets that won't break the budget and will hold up ok just so long as you don't abuse them. Better brackets like the Newtons are far more expensive, but are far lighter and perform FAR better. You can see mine here:
http://photography-on-the.net/forum/...d.php?t=338933
I've had mine for about 2 years and 12,000+ pictures now and have been very pleased with its performance. My particular model does not fold perfectly flat like some, but it takes up very little space in a bag. You can easily pack soft things around it too. - Stu
sapearl is offline   Reply With Quote
Old 7th of March 2008 (Fri)   #14
sapearl
sapearl's Avatar
Oh - forgot to mention. Yes, sometimes I will shoot horizontal and then crop. But that's pretty rare for me.... I mean why lose all those good pixels if it can be avoided? That's why I bought the 5D in the first place .
Old 8th of March 2008 (Sat)   #15
asysin2leads
I'm kissing arse
Don't get me wrong. It's a nice bracket, but I just don't like the fact that I have to take my grip off to use it. That's my biggest complaint.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
WTB: Delta Flip Flash II Bracket - 18" Flash Arm Leorooster Classifieds: Buy 0 13th of March 2007 (Tue) 14:31
camera rotate bracket or flash flip bracket clengster_77 Small Flash and Studio Lighting 40 15th of January 2007 (Mon) 20:07
Flash bracket for vertical shots for flash heads? PhotoScout Small Flash and Studio Lighting 2 29th of September 2006 (Fri) 19:43
Sigma lens/10d focus problem-new everyting? jro727 Canon EF and EF-S Lenses 8 17th of April 2005 (Sun) 00:05
