Reply
Thread Tools Display Modes
Old 5th of September 2002 (Thu)   #1
jimworth
Default Loss of Sharpness in Smaller Images
I've noticed that whenever I produce smaller images (e.g. 640 x 480 pixels for an eBay listing) from my G2 shots, the sharpness is degraded. I would like to understand why this is. For example if I take a large resolution shot (4 MPixels) and then resize it to 640 x 480 using Paint Shop, it doesn't look as sharp as the original. With both the original and the shrunk image, I'm viewing the image in a 640 x 480 pixel area of the screen.
I've tried shooting at 640 x 480 (small resolution) so that no resizing is necessary and still the shots don't look sharp.
The thing that confuses me is that when I view an image in a 640 x 480 area of my monitor, it doesn't seem like a higher resolution image (e.g. 1280 x 960) can provide any more information to the 640 x 480 pixels that are actually displayed than a low resolution image that is 640 x 480 to begin with. Why does the image captured at higher resolution it look sharper in this situation?
jimworth is offline   Reply With Quote
Old 5th of September 2002 (Thu)   #2
ken-w
Default Re: Loss of Sharpness in Smaller Images
Basically because you're throwing away pixels - image sharpness depends on edges and in a smaller photo there are fewer edges to work with.
With regards to your problem, you should be using the sharpening feature of Paint Shop (which I don't use so I don't know its capabilities). Almost all photos need post camera sharpening, in fact the pro recommendation is to shoot your pictures with in-camera sharpening turned off or set to the lowest setting and then do post process sharpening.
In programs such as Adobe Photoshop and Corel Photopaint the most effective sharpening tool is the "unsharp mask" or "adaptive unsharp" (I have no idea why they call a sharpening tool, "unsharp" - but there you go). I most often use a 3rd party plug-in called "nik Sharpener Pro" but that is overkill for what you want.
Sharpening should be the very last thing you do to the photo and it should only be done once - multiple sharpening only degrades the photo. You should get some pleasing (and sharp) results.
Good question - I have no idea - perhaps it is the way the program shrinks the photo - the original, even when shrunk still contains all the info, whereas the resized image has discarded much of this info in order to shrink the size (i.e. it has remapped all the pixels).
However, if you put the two side by side, and then sharpen the smaller photo (using your unsharp mask or whatever Paint Shop has to offer) it will look sharper than the original.
ken-w is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Help with images sharpness/iso dditzel Canon EOS Digital Cameras 9 2nd of April 2006 (Sun) 13:47
Making images smaller/keeping quality mattsiesco RAW, Post Processing and Printing 4 8th of July 2005 (Fri) 08:27
How do I make the images smaller KB? jackia Small Compact Digitals by Canon 3 17th of March 2005 (Thu) 21:20
10d Images sharpness ChuckB Canon EOS Digital Cameras 15 6th of February 2004 (Fri) 00:31
LOSS OF IMAGES ON D60 Burnett Canon EOS Digital Cameras 24 12th of October 2002 (Sat) 15:53
