Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EOS Digital Cameras
Reply
Thread Tools Display Modes
Old 10th of March 2008 (Mon)   #1
Todd Good
Default f/stop question on Full frame vs crop frame question
Is it true on a crop body the f/stop gets multiplied as well? So if I'm shooting at 2.8 on a 1.6 crop, I'm really shooting at 5.6. Any help on this issue would help. Thanks
Todd
Todd Good is offline   Reply With Quote
Old 10th of March 2008 (Mon)   #2
DVS_WiNdz
Default Re: f/stop question on Full frame vs crop frame question
No, f/2.8 is f/2.8. The only thing that changes is depth of field.
Stephen L.
Gear list
DVS_WiNdz is offline   Reply With Quote
Old 10th of March 2008 (Mon)   #3
Todd Good
So does FF have less DOF than a crop at the same f/stop?
Old 10th of March 2008 (Mon)   #4
DVS_WiNdz
Yes, full frame has less dof at the same f stop.
Here are some samples http://www.aminfoto.com/2007/12/cano...e-vs-crop.html
Stephen L.
Gear list
Old 10th of March 2008 (Mon)   #5
basroil
basroil's Avatar
no, the lens characteristics do not change no matter what the crop, a 200mm 1.8 will have a dof of .02m at 2.5m no matter what. what happens is that as you crop the edges, you need to stand further back to have the same framing. when you move back, you get more dof.
basroil is offline   Reply With Quote
Old 10th of March 2008 (Mon)   #6
JeffreyG
JeffreyG's Avatar
Essentially yes, supposing that you are framing the shot the same with each camera.
Suppose you set up a shot on a FF body with an 80mm lens at f/4. They you take the same shot at f/4 from the same distance with a crop camera, but this time you change the lens focal length to 50mm.
These two shots will look the same, except the FF shot will have a shallower DOF because the lens used is longer.
DOF increases with
Shorter focal length
Smaller aperture
Closer focus distance
My personal stuff:http://www.flickr.com/photos/jngirbach/
Commercial sports:http://girbach.zenfolio.com/
I use a Canon 5D and 1DIV and a Panasonic GF-1 Gear List: http://photography-on-the.net/forum/...postcount=1550
JeffreyG is offline   Reply With Quote
Old 10th of March 2008 (Mon)   #7
n1as
Todd
Crop factor has a lot of misinformation surrounding it. When you put a lens on a crop body, the crop factor does NOT change the lens focal length. The 50mm f/1.4 is still a 50mm f/1.4. Period. The lens focal length does not change.
Not.
The smaller sensor captures less of the image formed by the lens and therefore gives your image the field of view that is smaller, as if it were taken through a lens with a longer FL.
- Keith -
http://darwinphoto.zenfolio.com
n1as is offline   Reply With Quote
Old 10th of March 2008 (Mon)   #8
penagate
penagate's Avatar
Magnification is the key variable affecting depth of field which most people seem oblivious to.
5D, 400D
Flickr
penagate is offline   Reply With Quote
Old 10th of March 2008 (Mon)   #9
Wilt
Wilt's Avatar
A 100mm f/2 lens used on FF camera will indeed have a smaller DOF than a 60mm f/2 lens used on an APS-C camera...DOF 0.294' vs. DOF 0.52' at shooting distance of 10' to achieve the same framing.
But if you put a 100mm f/2 lens on both format cameras and stand at 10', the APS-C camera has less DOF at 0.184' vs DOF 0.294', because it has to be magnified by 1.6x more to make the same final print size !
If you move forward with the FF camera so that both frames have the same FOV with the same 100mm lens, the APS-C camera has greater DOF, at 0.18' vs. 0.10'.
Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.php
Wilt is offline   Reply With Quote
Old 10th of March 2008 (Mon)   #10
AJSJones
AJSJones's Avatar
Nope! DoF is not an intrinsic property of a lens any more than print size is an intrinsic property of the lens.
The degree of enlargement from the captured image to the print AND the viewing distance are both REQUIRED pieces of information BEFORE the CoC can be calculated. THEN, you need the appropriate CoC to use the DoF tables. The conventions (not NOT laws of physics!) before digital came along were based on something like a 35 mm frame, printed at ~8x12" (about 8x enlargement) viewed from ~15" derived from the observation that the human eye can commonly resolve 300 ppi under those conditions.
It has become murkier with digital if folks are printing at (e.g.) 300 ppi the print size and degree of enlargement is all over the place ; the 10D will give a 10 x7 print while the 1Ds3 will give a 18.7 x 12.5 " print, but these are 11.5x and 13.2x enlargements respectively - and who knows how closely they are scrutinized. Then there's 100% pixel peeping that's another 3-4 x enlargement. DoF is losing some of its credibility!
See also Post#10 in http://photography-on-the.net/forum/...d.php?t=467572 running concurrently on basically the same issue!
AJSJones is offline   Reply With Quote
Old 10th of March 2008 (Mon)   #11
Wilt
Wilt's Avatar
The CoC sizes are based upon the absolute resolution of the typical human eye to resolve tiny detail, and has NOTHING to do the dpi ppi or any other digital scaling. Assuming infinitely fine ability to reproduce details, the smallest detail perceived with the human eye can be described as an angular measurement which can be projected to a CoC size at a certain viewing distance.
Old 11th of March 2008 (Tue)   #12
AJSJones
AJSJones's Avatar
Glad you agree with me!
The CoC size ... NOTHING to do the dpi ppi or any other digital scaling. Assuming infinitely fine ability to reproduce details, the smallest detail perceived with the human eye can be described as an angular measurement which can be projected to a CoC size at a certain viewing distance.
The whole point I was making was that the digital world does NOT have the infinite ability to resolve fine details and many people will print their pixels to the max, without regard for their original geometric dimensions. You've seen the Threads on "how big can I print with a xxD?", so we have significant variations in degree of enlargement - and as you know - the CoC that is appropriate for calculating depth of field depends on that factor. Therefore we have significant variations in DoF. All of these have to be taken into account when some asks (either themselves or someone else) a question about DoF!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Full Frame Vs Crop Stump Canon EOS Digital Cameras 21 22nd of February 2008 (Fri) 15:19
Full frame sensor users and GND filters, I have a question jacobsen1 Canon EOS Digital Cameras 5 7th of September 2007 (Fri) 15:52
Math question on Full frame and cropped sensor th256 Canon EOS Digital Cameras 5 5th of September 2007 (Wed) 07:01
F stop for cropped sensors v full frame gameboy Canon EF and EF-S Lenses 5 14th of May 2007 (Mon) 06:18
crop vs full frame - anyone prefer a crop set up bowlesbe Canon EOS Digital Cameras 124 12th of April 2007 (Thu) 21:20
