#1 |
About 15 minutes ago I was taking some shots of my girlfriend when I went to change my shutter speed higher, I turned the dial to the right and the shutter number went down, I turned to the left the shutter went down, I was shooting in M mode and I held the AV button, turned the dial to the right and the aperture number went lower and to the left it went lower, I turned the camera off and then back on and nothing happened, I took out the batteries and the memory card and then put them back in and nothing. I turned off my battery grip and everything went back to normal, I turned the grip on and everything went out of wack again, off and on again and everything was fine. Now my camera and battery grip are both on and everything is fine............what could have caused this problem??
www.myspace.com/slonskiphotography
Gripped Canon Digital Rebel XT (350D), Canon Speedlite 430EX, Tamron 17-50mm f/2.8, Canon 50mm f/1.8, Canon EF 28-80mm f/3.5-5.6 II, Tamron 70-300mm f/4.0-5.6, Canon 500D Close Up Filter, Macro Reversing Ring....... |
| sponsored links |
#2 |
Possibly a short in the grip?
#3 |
dǝǝɥs ɐ ʎq pǝʞuɐds
Did the gear get wet?
| sponsored links |
#4 |
Sounds like the typical problem caused by a third party grip. Spin the main dial on the grip back and forth a bit, then turn it back on and see if the problem has went away.
#5 |
The wheel on the grip is inbetween stops. Move it.
#6 |
It is working now, i turned the grip off and back on and then it worked, i guess it is cuz of a thrid party grip, i think it is opteka...
| Thread Tools | |
| Display Modes | |
| Newbie. Please Help! (odd camera behavior) | Monika1 | Canon EOS Digital Cameras | 25 | 12th of December 2007 (Wed) 17:22 |
| odd question: do photos remain on camera body w/out card? | doubledragon | Canon EOS Digital Cameras | 23 | 12th of October 2007 (Fri) 15:12 |
| Odd issue when camera saves to CF card | S.E.V. | Accessories & Storage | 4 | 13th of August 2007 (Mon) 15:48 |
| Odd behaviour from 580 + 5D and off-camera cord | KAS | Small Flash and Studio Lighting | 2 | 13th of May 2007 (Sun) 21:59 |
| Fantastic camera support tool for odd situations | SkipD | Accessories & Storage | 1 | 23rd of July 2006 (Sun) 20:41 |
