#1 | |
**EDIT AGAIN***
This thread dates back to 2004, BEFORE Canon installed the now ubiquitous "AF ON" button. In those days, we used the * button. Modern EOS starting with the 1D MkIII and 40D use the AF ON button instead with a lot of additional options. ** EDIT ** This thread is a "Split" from the FAQ topic re: favorite custom functions; http://photography-on-the.net/forum/...amp;highlight= The Custom Functions Thread went a little bit O.T. with the subsequent discussion on the benifits and dislikes of using a particular Custom Function. The debate over CF # 4 is certainly worth its own thread ** End EDIT ** CDS Quote:
~ Jay ~ Canon EOS 20D ... lenses and stuff Without the Way, there is no going; Without the Truth, there is no knowing; Without the Life, there is no living. <>< Help remove children from poverty: Compassion Last edited by CyberDyneSystems : 20th of April 2009 (Mon) at 14:31. |
| sponsored links |
#2 |
Separating focus and exposure on the 10D and 1D Mark II has made a significant change in the way I take pictures. Focusing using the * or X button on the back allows you to choose instantly between all AF points and a manually selected one. In addition you can focus, release the * or X button and recompose, then depress the shutter button for exposure. In addition on the 10D, by not pressing the * or X button, the camera is in Manual focus and this forces the flash metering to average all the sensor input instead of biasing an active focus point resulting in more consistent flash. This is not the case though for the 20D which uses ETTL2. ETTL2 is independent of AF points.
Try it, you'll like it! Scott |
#3 | ||
Using the * allows you to keep focus, but delay setting the exposure until the picture is actually taken. |
| sponsored links |
#4 |
That makes so much sense it is almost difficult to understand why that is not the default setup ... thanks for the info !!
~ Jay ~ Canon EOS 20D ... lenses and stuff Without the Way, there is no going; Without the Truth, there is no knowing; Without the Life, there is no living. <>< Help remove children from poverty: Compassion |
#5 |
Here is the expert on using the * and X buttons to focus:
http://visual-vacations.com/Photogra...focus_tips.htm Scott |
#6 | ||
Wait, all that time and all I get is "Cream of the Damn Crop" ?!!!!!!!!!!!!!!!!
An article on the subject by famed Bird Photographer Arthur Morris http://www.birdsasart.com/ Quote:
#7 | |
"What a Tool I am"
How does this affect non-flash metering? I know that the 10D biases exposure metering on the focus points too. So would this help? Does anybody know if the 20D biases to the autofocus point for exposure metering? |
#8 |
Correct me if I'm wrong...
I don't have the reference material on hand.. but this is not how I understand it. For the 10D and 20D I understand that all metering is biased towards the center "Partial" circle regardless of active focus point. On the "1" series the ONLY time you get metering biased towards the focus point is when you use "Spot metering" As the 20D and 10D do not have Spot metering.. they are neccesarily incpabable of this ability. Correct me if I have misunderstood this.... but with the 10D in partial metering I know it uses the center circle no matter what AF point I use. Are you suggesting that if I used "evaluative" that the 10D would have "centered" on the active focus point? |
#9 | |
In flash metering, it is my understanding that in ETTL the flash metering is biased to the active AF points and that you can avoid that by switching to MF on the lens or using the Cfn's to put focus on * and X and releasing the button before depressing the shutter button. In ETTLII there is no such bias to AF points. Here is an additional reference: http://www.camera.canon.com.my/archi...rt/art14/2.htm Regards, Scott |
#10 |
Thanks Scott,
in my case I confused the issue beuase I use "Partial" so often... which allways "weights" the center circle for metering regardless of active focus point. Seems I need to use evalauative more often... particularly when using an off center focus point. Thanks. |
#11 | |
YesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYe sYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesY esYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYes YesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYe sYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesY esYesYesYesYesYesYesYesYesYesYesYesYes |
#12 | |
Brad Buskey http://www.sturmphoto.com Canon EOS 1D Mark II Canon EOS 20D Canon EF L Lenses Omega View 45F Monorail View Camera |
#13 |
Definately 1... and also 3 the difference being how the AE/lock functions on the half shutter press.
I usually use CF#4 @ 1 When you do this.. bursts can be an issue.. as each following shot will use the same mettering.. if the scene or more specifically lighting is changing as you track a moving subject.. then avoid using a "burst" whcih will lock the exposure on the first shot.. instead trip the shutter for each individual shot making sure to let up on it enough to maintain a "half press" exposure lock. By switching to 3 you can do away with AE lock all together.. but I don't like this as it won't allow the recomposure trick. |
#14 | |
It's so much easier to use the shutter button to focus and then fully press it to activate the shutter. For me it seems that focusing with the * button fixes a problem that I don't have. The only times that I have an exposure problem, the metering would be fooled no matter what and I switch to M to correct the problem. |
#15 | ||
| Thread Tools | |
| Display Modes | |
| 1dmk3 shutter button+focus | yokotas13 | Canon EOS Digital Cameras | 2 | 18th of February 2009 (Wed) 05:35 |
| 40D back focus button? Better than using shutter? | Jenniferrose | Canon EOS Digital Cameras | 24 | 8th of August 2008 (Fri) 13:04 |
| Separating focus from shutter button, 40D | Southswede | Canon EOS Digital Cameras | 5 | 30th of December 2007 (Sun) 13:07 |
| Focus with * button or shutter release button? | Keydogg | General Photography Talk | 20 | 30th of July 2007 (Mon) 00:11 |
| Custom Function 4, "Shutter Button, AE Lock Button | MadMesh | Canon EOS Digital Cameras | 21 | 12th of August 2005 (Fri) 14:10 |
