Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > General Photography Talk
Reply
Thread Tools Display Modes
Old 19th of June 2001 (Tue)   #1
mcaldwell
Default How To Get 8.5 x 11 Centered?
I have a new Canon S800 printer. Great prints. However, I cannot find a way to get a full sized, 8.5 x 11 pix centered on the paper. I have tried making the image much larger than the paper, setting custom print sizes of up to 9.0 x 11.5; just don't work. I can't believe Canon would design a photo printer that would not have some setup wherein one can get an even border all around. Anyone figured this out?
mcaldwell is offline   Reply With Quote
Old 11th of July 2001 (Wed)   #2
sasc
Default Re: How To Get 8.5 x 11 Centered?
This probably has to be set in your software you are printing from.
sasc is offline   Reply With Quote
Old 12th of July 2001 (Thu)   #3
Andrei
Check you printer properties carefully. There must be something like alignment.
Andrei is offline   Reply With Quote
Old 21st of July 2001 (Sat)   #4
n9505605
Have you check your page setup? check the page margin etc.
Boshala
n9505605 is offline   Reply With Quote
Old 21st of August 2003 (Thu)   #5
howard4113
Did you ever get this problem resolved.
I have the same problem - but am unable to set the margins in "Printer Properties".
howard4113 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Centered Photo, Does It Work For You? driverdave Critique Corner 10 8th of May 2007 (Tue) 10:55
html to set picture centered azpix Presentation 5 28th of March 2007 (Wed) 14:36
Centered Miniflash Wildlife 0 27th of August 2006 (Sun) 18:41
Centered or off center, Rule of thirds... Transportithere Still Life, B/W & Experimental 5 25th of March 2006 (Sat) 10:00
'Centered' Ballet Photo pdrow Urban Life & Travel 4 28th of March 2005 (Mon) 11:02
