Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > General Photography Talk
Reply
Thread Tools Display Modes
Old 20th of March 2008 (Thu)   #1
rick325
Default Is perspective determined by distance or focal length?
I know this has been discussed before, but I just cannot seem to find a definitive answer as it relates to a crop vs. ff sensor (most of the discussion is purely focal length / distance related):
Mock scenario:
1) 30mm lens on a 1.6x crop sensor
2) 50mm lens on a ff sensor
In both cases: Distance to subject is 1m
Both will give a similar FOV. Which of the following is true:
a) the pictures will look the same because the distance to the subject is the same (ignore the 2mm effective focal length discrepency)
b) the pictures will look very different, since the 30mm lens is "wider" you will get a more "3d" look while the 50mm will give a "flatter" image
c) none of the above. please explain
In my non-scientific testing, I believe "b" to be true. However, I keep reading on the forums that "a" is in fact correct--perspective is a function of distance to the subject and nothing else.
Thoughts?
rick325 is offline   Reply With Quote
Old 20th of March 2008 (Thu)   #2
rick325
Default Re: Is perspective determined by distance or focal length?
Can someone please move this thread to the "sharing knowhow -> talk about photography" section?
Thanks in advance.
Old 20th of March 2008 (Thu)   #3
Perry Ge
Batteries? We don't need no...
Perry Ge's Avatar
Perspective is determined entirely by distance from your subject (camera positioning) and not by focal length or your sensor size. Focal length affects your field of view. A cropped sensor crops that field of view. None of these have any bearing on perspective.
Move your hand close to your face, then move it far away. Notice its relative size in your field of view to objects around it. That's what moving closer to your subject does. When you're far from the subject, you tend to use a tele lens, hence the 'compression' effect, where the subject looks smaller than its surroundings. Vice versa with being close up and using wide angles. It's not focal length, it's camera position. All the cropped sensor does is crop off 40% of the edges of the image. It does nothing else.
This question has been asked a lot though, you should be able to find a lot of information by running a search.
Perry | flickr | C&C ALWAYS welcome | Gear
POTN Toronto | Sharpening sticky | Perspective sticky [READ THIS]
Perry Ge is offline   Reply With Quote
Old 20th of March 2008 (Thu)   #4
n1as
The relative size of objects in the picture is completely controlled by 3 things:
- Distance from the camera to the objects.
- How far it is from the camera to the objects.
- Amount of linear space from the objects to the camera.
And here are the things that do NOT affect the relative size relationships between items in an image.
- Sensor size (crop vs. FF)
- Lens focal length
- Shutter speed
- ISO
- Aperture
- etc.
Do a search for "portrait distance" and you'll find a thread recently that got into this quite heavily, including example pictures.
- Keith -
http://darwinphoto.zenfolio.com
n1as is offline   Reply With Quote
Old 20th of March 2008 (Thu)   #5
Madweasel
Madweasel's Avatar
Think about it this way. Perspective is the relative sizes of things at different distances from your viewpoint. This is a propotional thing, so that if you have two identical objects and one is twice as far from you as the other then it will look half as big.
So, imagine these two identical objects are 4 feet apart and you are viewing from a point 2 feet from the first and 6 feet from the second. The nearer one will look three times bigger than the farther, giving a 'strong' perspective effect. Now move our imaginary viewpoint back to 20 feet from the first, 24 feet from the second. Now the first one is only 1.2 times bigger than the second, giving a 'compressed' perspective effect.
These observations will be true regardless of the lens and sensor size you use. It's just that if you use a wideangle lens from the distant viewpoint, both objects will be small and near the centre of the field of view and the things that you notice will be much nearer, making you think you're getting an exagerrated perspective. But if you use a telephoto or crop the centre portion out of a wider shot, you'll see the relative sizes (and therefore perspective) of those two objects will be exactly the same.
I've seen this demonstrated countless times in books and magazines and apologise for the clumsiness of doing it in words.
Mark.
Madweasel is offline   Reply With Quote
Old 20th of March 2008 (Thu)   #6
Wilt
Wilt's Avatar
http://photography-on-the.net/forum/...69#post5023469
photos proving that FL does not change perspective...
http://photography-on-the.net/forum/...5&postcount=17
Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.php
Wilt is online now   Reply With Quote
Old 20th of March 2008 (Thu)   #7
rick325
You all are great, thanks! What I had gotten myself hung up over was a degenerate case:
Imagine a picture taken with a 8mm fish-eye, cropped to give you an image that replicated a 50mm FOV taken from the same distance. I would expect that the 8mm cropped would be distorted perspective relative to a 50mm lens at the same distance.
In any case, I'll stop the idle chatter, and thank you all for the perspective
Old 20th of March 2008 (Thu)   #8
Jon
Moderator
Cocker Spaniel Mod
Jon's Avatar
Well, visualize a 15 mm fisheye compared to a 15 mm UWA. Fisheyes aren't measured by the same rules as other lenses.
Jon
EOS, Powershot and Domke - it doesn't get any better than this!
T90 and stuff | F-1n, New F-1, FTb and more stuff out on loan
Cocker Spaniels
DC Cherry Blossoms
Jon is online now   Reply With Quote
Old 20th of March 2008 (Thu)   #9
Wilt
Wilt's Avatar
'Perspective' distortion is one beast, plain old distortion like fisheyes create is something entirely different. Fisheyes depict straight lines as curves, and show them as straight lines only if they pass thru the optical center of the lens!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Focal Length, Distance, and Subject - A theoretical question... jnick Canon EF and EF-S Lenses 17 23rd of September 2007 (Sun) 11:08
Formula for magnification, distance, focal length gasrocks Macro 0 4th of May 2007 (Fri) 13:14
Focal length and Perspective revisited KevC Canon EF and EF-S Lenses 5 1st of June 2006 (Thu) 14:22
Equations for Distance from Subject vs Focal Length homiegfunk Canon EF and EF-S Lenses 5 18th of January 2006 (Wed) 22:20
Focal Length VS Photo distance Littlebike Canon EOS Digital Cameras 1 4th of September 2003 (Thu) 06:13
