Reply
Thread Tools Display Modes
Old 21st of March 2008 (Fri)   #1
khukri
Default Zork MFS & Novoflex Lens Reversal Ring
Anybody here used the Zork MFS? If so, how does it (with a Rodagon 80mm lens) compare with ordinary EF macro lenses in terms of ease of use and final image quality? (For both - landscape and macro work.)
Also, any inputs on how good/efficient the Novolex lens reversal ring is? Which would be the ideal lens to use with this contraption?
khukri is offline   Reply With Quote
Old 26th of March 2008 (Wed)   #2
khukri
Default Re: Zork MFS & Novoflex Lens Reversal Ring
Come now, surely there are people here who have experience of these contraptions...!!? On the presumption that someone will respond, thanks in advance!
Old 26th of March 2008 (Wed)   #3
gasrocks
gasrocks's Avatar
Both of those are very expensive and probably not used much by people on this forum. Have you tried the Manual Focus forums?
gasrocks is offline   Reply With Quote
Old 29th of April 2011 (Fri)   #4
oharing
oharing's Avatar
Any update on this?
Florida Wedding Photographers
oharing is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
first go at lens reversal Jamie_F Macro 6 4th of December 2006 (Mon) 10:25
lens reversal rings? door Macro 4 1st of December 2006 (Fri) 09:18
Lens reversal for Canon G5: Will these work? heyjeyniceid Macro 7 14th of February 2006 (Tue) 18:30
Are lens -reversal rings worth the money? Big John Macro 4 30th of July 2005 (Sat) 05:58
Pets & People - Role Reversal Scottes The POTN Lounge 1 18th of May 2004 (Tue) 06:33
