Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > The Business of Photography
Reply
Thread Tools Display Modes
Old 6th of November 2004 (Sat)   #1
dsze
dsze's Avatar
Default Print Sizes Offered and Aspect Ratio
What do you guys/gals do with regard to showing proofs to clients & aspect ratio?
I mean, if I offer a choice of several sizes, then the image they see in proofs may change slightly depending on the aspect ratio. I'm just what the best way is to offer proofs:
1. at 'out-of camera' ratio w/ a disclaimer that actual prints may be slightly different.
2. Crop all proofs to an 8X10 frame
3. other suggestions?
thanks,
daniel
-daniel
"Life is not measured by the number of breaths we take, but by the moments that take our breath away."
-Gear List-
dsze is offline   Reply With Quote
Old 6th of November 2004 (Sat)   #2
timmyquest
User is banned from forums
Default
Based on the photo studio i work at and what i've seen said around here
Most, if not all proofs are 4x6 (2:3...ie your camera)
I guess it's up to whoever is pritning it to crop it as needed.
timmyquest is offline   Reply With Quote
Old 6th of November 2004 (Sat)   #3
dsze
dsze's Avatar
Default
Well, no not really.
If I put 100 proofs online, or give 100 4X6 proofs to a client and they decide they want #'s 3, 5, 34, 29 and 87. Two of those being 5X7's, and Three being 8X10's. So, now they've seen 2:3 ratio (4X6) proofs, but they want 2 different aspects.... Now, imagine that those photos were filled-frame photos that would lose valuable parts of the image by cropping to the 5X7 & 8X10 ratios.... So, what then? If these photos are sent to a Lab...they are just going to chop off the top and the bottom and send them. Its up to the photographer to crop the images correctly before taking them to the lab.... I'm just not sure how to work it into my workflow... and what ratio to show to clients as proofs.
-daniel
-daniel
-Gear List-
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Can I change the aspect ratio? SunTsu Canon EOS Digital Cameras 13 21st of February 2007 (Wed) 17:23
Aspect Ratio caspianx67 Weddings and Other Family Events 5 2nd of February 2007 (Fri) 15:06
Print sizes and Frames question + aspect ratio stuff learjet035 RAW, Post Processing and Printing 3 18th of July 2006 (Tue) 13:42
When the Aspect Ratio Doesn't Work... dsze The Business of Photography 3 20th of December 2005 (Tue) 07:46
3:2 aspect ratio perfectpixel Small Compact Digitals by Canon 8 30th of November 2005 (Wed) 11:55
