Reply
Thread Tools Display Modes
Old 23rd of March 2008 (Sun)   #1
ImagesByInku
ImagesByInku's Avatar
Default Brand new 50 1.2L focus issue
Ok, so I need some input. I just received my 50 1.2L and took some test shots. It has focus issues as described by many, many people.
My question to all of you is - what would you do? Return the lens and get a different focal lens (35mm 1.4L perhaps?)? Keep it and send it to Canon for calibration? Exchange it for another 50 and keep your fingers crossed?
I'm tempted to send it off to Canon for calibration. Input is appreciated. Thanks!
1D MkIII | 5D MkII | 16-35 2.8L II | 24-70 2.8L | 70-200 2.8L IS | 35 1.4L | 50 1.2L | 85 1.8
____
blog
ImagesByInku is offline   Reply With Quote
Old 23rd of March 2008 (Sun)   #2
JeffreyG
JeffreyG's Avatar
Default Re: Brand new 50 1.2L focus issue
I can only tell you my experience.
I got a 50L. This one had something really wrong with it and all shots were fuzzy. I've never seen anything like it. It wasn't OOF....it was just all fuzzy. I sent it back.
The second 50L I got consistently backfocussed about 4" at all apertures. This was not the famous focus shift issue....just a straight up backfocus. I sent it back.
Then I bought a 50/1.4. That lens is OK but not super sharp below f/2, and so I tend to use my 35L more.
BTW, if you are struggling with the focus shift issue then exhanging the lens will not make a difference. They all do that, and people's satisfaction with the lens basically hinges on whether or not they shoot in the specific conditions that cause the shift or not.
http://www.flickr.com/photos/jngirbach/
I use a Canon 5D and 1DIII and a Panasonic GF-1 Gear List: http://photography-on-the.net/forum/...postcount=1550
JeffreyG is offline   Reply With Quote
Old 23rd of March 2008 (Sun)   #3
Zazoh
Zazoh's Avatar
If you are describing the focus shift at 1.2 when using the center focus point, you will not be able to get around it other than the work around to use an alternate focus point.
Why trade for a differnent FL? If you need a 50 and are not happy with the 1.2 you could try the 1.8 or the 1.4.
Zazoh is offline   Reply With Quote
Old 23rd of March 2008 (Sun)   #4
kster
kster's Avatar
I went through two different 50Ls before returning to the 85L. Like Jeffrey said, they all have the focus shift, it's just part of the lens.
1DmkIII and some lenses
kster is offline   Reply With Quote
Old 23rd of March 2008 (Sun)   #5
JeffreyG
JeffreyG's Avatar
The focus shift does not occur at f/1.2, it has to be stopped down a little. Most complaints are from f/1.8 to f/2.8 at distances of 1 - 1.5 meters.
Old 23rd of March 2008 (Sun)   #6
nicksan
Man I Like to Fart
nicksan's Avatar
If you aren't happy with it, send it back. Maybe give another a try?
If it's not good, then perhaps you should stick with the 50 1.4.
Although I don't test any of my lenses to that extent, my lens is fine for my applications. I'm not saying the problems don't exist. I'm just saying I haven't seen it in the types of shots I take so far.
nicksan is offline   Reply With Quote
Old 23rd of March 2008 (Sun)   #7
r1ch
I have read too many problems sending it back to Canon, it often is not fixed. I have read that you can send the camera and lens in and get very good results.
I sent back my first 50 1.4 lens that had a front focus issue, I figured this out using the focus chart at the bottom of this link http://focustestchart.com/chart.html
The second lens was very good and worked for me. I did not have to send the camera back in. The problem for me sending in the lens and camera back in is that if all your other lenses work and the 50L does not and you have the camera adjusted for this lens, if you upgrade to a new camera, very likely you will have to send the new camera and your 50L back in to have it adjusted.
I would only send camera and lens back if you get serveral copies that exhibit the same problem.
r1ch is offline   Reply With Quote
Old 23rd of March 2008 (Sun)   #8
90c4
I got rid of mine as well. Even using the alternate focus points didn't seem to make much difference. I'm much happier with my 35L, 85L, and 50 1.4 than I was with the 50 1.2. I tried at least five and they all had the same issues. Really wanted the lens to be decent, but no such luck.
90c4 is offline   Reply With Quote
Old 24th of March 2008 (Mon)   #9
halfmoonray
i sent in my 50 for calibration, telling them which camera I use and what seemed to be the problem. They just sent it back to me saying: "We have examined the product according to your request, and it was found that the adjustment of the internal component was incorrect the image was blurred. Electrical adjustments were carried out on the internal component. Other electrical adjustments and inspection and cleaning were carried out."
My initial impression of test shots following calibration were very good. The lens is much better now following calibration.
Using the focus chart, and the middle focus point at wide open, the focus is very good but not tack sharp like some other lenses. However, I did not use a tripod and shutter release.
Using the outermost focus point at wide open, the image focus is just good. I assume fall-off , spherical aberration is typical as the sweet spot on all lenses is in the middle. I would recommend using the middle focus point at wide open. I seldom use the middle focus point. Using the lens at 1.6 with the outer most focus point and in good light without a tripod, I did produce a sharp image. I must say that I was very surprised
Average photoshooting has produced some excellent results. I still want to test the lens in better light, on the tripod and with shutter release using the focusing chart and different focus points. In these tests, any slow shutter release and movement in between focus lock and release can mess up the test.
I am impressed with the lens and more so following calibration. For me it's a keeper, but I am still learning the peculiarities of this lens.
5D mk 2
50 f/1.2L
85 f/1.2L II
100 f/2.8 macro
MPE-65 f/2.8
halfmoonray is offline   Reply With Quote
Old 24th of March 2008 (Mon)   #10
bildeb0rg
bildeb0rg's Avatar
If you don't like it, just send it back and get something else. Canon won't give a rats a$$ either way, and the 50L archive is ful of great pics that back up their opinion that this is a fine lens.
bildeb0rg is offline   Reply With Quote
Old 24th of March 2008 (Mon)   #11
mebailey
Dont send the lens for calibration. By the time you get it back the refund/exchange period will likely be over. Try another 50L or try another lens.
mebailey is offline   Reply With Quote
Old 24th of March 2008 (Mon)   #12
FretNoMore
FretNoMore's Avatar
It's a fine lens in most respects but it does have the focus shift that you need to know about.
Personally I'm not spending that kind of money and then have to work around a big design flaw, just at the sweet spot (large apertures) that would be the reason for buying such a fast lens in the first place too.
I'm waiting to see how the new Sigma 50/1.4 turns out, and in the mean time the Canon 50/1.4 will have to do.
Anders Östberg - Mostly Canon gear - Photos
FretNoMore is offline   Reply With Quote
Old 24th of March 2008 (Mon)   #13
nicksan
Man I Like to Fart
nicksan's Avatar
I should note that I bought mine used from another member here so I already knew what kind of IQ I would get with this copy. I am very happy with my copy.
So that might be another approach to take.
Old 24th of March 2008 (Mon)   #14
JAcosta
JAcosta's Avatar
If youre not happy with the AF you can always learn *GASP* to manual focus.
I dont understand that everyone overlooks just how great this lens actually is because of a focus shift issue that I havent experienced with two copies of the lens. You rarely hear about how great the colors, contrast, or even the flare control are. Couple that with f/1.2, L quality build, and weather resistant sealing. I dont understand how so many people can count this lens out because a few people got a few bad apples.
If your pictures aren't good enough, you're not close enough - Robert Capa
-=1D mark III=--=5D Mark II=--=16-35mm f/2.8L II=--=50mm f/1.2L=--=100mm f/2=--
-=Mamiya M645=--=55mm f/2.8=--=150mm f/4=-
JAcosta is offline   Reply With Quote
Old 24th of March 2008 (Mon)   #15
FretNoMore
FretNoMore's Avatar
Well... if you for instance want to use this lens at f/2.8 or so under the basket hoop you'll be in the problem range and there will not be time for manual focusing.
Manual focusing is also not the answer to the focus shift problem, unless you manage to compensate for the shift and actually set the lens out of focus slightly. The error occurs when the lens stops down to take the shot, not while focusing (when the lens is wide open).
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Focus issue? whaase Canon EOS Digital Cameras 13 13th of March 2008 (Thu) 21:08
help...focus issue. troyer16 Birds 15 18th of March 2007 (Sun) 00:08
Focus Issue widgetrich Sports 8 8th of January 2007 (Mon) 18:20
17/85 focus issue Chop_Top Canon EF and EF-S Lenses 11 2nd of February 2006 (Thu) 17:00
focus issue S2 sonnyJ Small Compact Digitals by Canon 2 22nd of November 2005 (Tue) 19:45
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
