Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Macro Talk
Reply
Thread Tools Display Modes
Old 24th of March 2008 (Mon)   #1
n1as
Default DOF in macro lenses?
Silly question here, but is there a difference in DOF between short and long focal length macro lenses?
I'm assuming my 60mm macro lens will give more DOF at 1:1 f/16 than a 100mm lens would at the same magnification and aperture.
True of false?
- Keith -
http://darwinphoto.zenfolio.com
n1as is offline   Reply With Quote
Old 24th of March 2008 (Mon)   #2
LordV
LordV's Avatar
Default Re: DOF in macro lenses?
Basically false - you get the same DOF at the same aperture and magnification. The only real difference between them is the FOV angle which can make shorter macro lenses have more recognisable OOF elements and longer ones a smoother bokeh.
Brian V.
http://www.flickr.com/photos/lordv/
http://www.lordv.smugmug.com/
Macro Hints and tips http://photography-on-the.net/forum/...d.php?t=807056
Canon 20D, Canon 40D, Canon 5D mk2, Sigma 105mm EX macro, Tamron 90mm macro, Canon MPE-65,18-55 kit lens X2, canon 200mm F2.8 L, Tamron 28-70mm xrdi, Other assorted bits
LordV is offline   Reply With Quote
Old 24th of March 2008 (Mon)   #3
ben_r_
-POTN's Three legged Support-
ben_r_'s Avatar
It will also give you a greater working distance from your subject, but yea same DOF...
[ Gear List | Flickr | My Reviews ] /|\ Tripod Leg Protection /|\
ben_r_ is online now   Reply With Quote
Old 24th of March 2008 (Mon)   #4
n1as
Really, ea? Same DOF at the same magnification? I'll have to ponder that a bit.
think ... think ... think
So what that says is that the shorter lens, which would normally produce more DOF, needs to be closer to the subject to get the same magnification, and moving closer means DOF gets smaller. Something like that I suppose.
- Keith -
Old 24th of March 2008 (Mon)   #5
egordon99
The reason the DOF is the same, is you have to get CLOSER to the object when you are using a shorter focal length lens (to achieve the same 1:1 magnification)
egordon99 is offline   Reply With Quote
Old 24th of March 2008 (Mon)   #6
gasrocks
gasrocks's Avatar
Only other thing (not mentioned) that changes with focal length (working distance) is prespective.
gasrocks is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Canon lenses DOF Charts ddlj81 Canon EF and EF-S Lenses 2 9th of November 2007 (Fri) 06:03
DOF on Macro Lenses The_Camera_Poser Canon EF and EF-S Lenses 14 21st of October 2007 (Sun) 11:22
DOF with Macro lenses coeng Macro 8 30th of May 2006 (Tue) 07:27
Apparently DOF dosent work with all lenses? ShutteringFocus Canon EF and EF-S Lenses 5 26th of January 2005 (Wed) 13:02
DOF scale ring on lenses? RinkRat Canon EF and EF-S Lenses 1 14th of January 2005 (Fri) 10:31
