FORUMS Photo Sharing & Visual Enjoyment Macro
Thread started 28 Mar 2008 (Friday) 05:30
Prev/next
MPE-65 vs reversed 50mm
LordV
LordV's Avatar
Worthing UK
Mar 28, 2008 05:30 |  #1
I used to use a reversed 50mm pentax lens on my sigma 105 before getting an MPE-65. Since then I've learnt a bit more about high mag shooting so decided to do a quick and dirty comparison of the 2 at 3:1. Using my 350D/sigma 105 with a reversed 50mm pentax lens at F7.1 and a 40D/MPE-65. I'd normally shoot around F7.1 at 3:1 - I used to shoot F11 when using the old combo before.
The target was the queens eye on a £20 note. The whole thing done handheld resting the cameras on a table so I can't guarantee absolute reproduction of shooting angles.
My conclusion was that the sigma 105/50mm combo does not have as flat a field of focus (important for 2-D shooting but not so much for 3-D subjects) as the MPE-65 (shooting angle might be different as well), but where both images are in sharp focus the resolution seems very comparable. One area I do think is different is the handling of OOF areas where the bokeh of the MPE-65 seems better. The focus distance of the 105/reversed 50mm was also a lot closer than the MPE-65.
Does show though that as others have demonstrated you can get excellent images with a reversed (old) 50mm lens and it's raining outside at the moment :) .
Brian V.
#1 350D/sigma 105/reversed 50mm pentax lens F7.1
IMAGE: http://farm4.static.flickr.com/3063/2368634176_c9c4159a9b_o.jpg
#2 40D/MPE-65 F7.1
IMAGE: http://farm3.static.flickr.com/2037/2368634182_4d176e7074_o.jpg
#3 100% crop of #1
IMAGE: http://farm3.static.flickr.com/2172/2368634184_da6b9cb263_o.jpg
#4 100% crop of #2
IMAGE: http://farm4.static.flickr.com/3052/2368634186_7720e3ec02_o.jpg
Macro Hints and tips
roman_t
roman_t's Avatar
Astana, Kazakhstan
Mar 28, 2008 06:40 |  #2
reversed setup looks good but 65mm worth its cost.
DaveBinks
Joined Jun 2005
Farnborough, Hants, UK
Mar 28, 2008 07:45 |  #3
Interesting photos - what type of adaptor did you use to reverse the 50 onto the Sigma - I've got a 50 that I'd like to do the same with?
Dave B
LordV
LordV's Avatar
Worthing UK
Mar 28, 2008 08:28 |  #4
Thanks for the comments :)
Dave - I just made a cylinder out of foam camping mat which tightly grips the 50mm lens (having preset it wide open and focused on infinity) and slide it on to the barrel of the macro lens - the tube was just stuck together with duct tape. You can of course use proper reversing adapters which have male/male filter threads to fit the filter thread diameters of your lenses (you may need a step or step down ring if you can't find the right adapter).
Brian V.
Action_Man
Action_Man's Avatar
England, Nr Europe
Mar 28, 2008 09:39 as a reply to LordV's post |  #5
Thanks for the tests Brian, what i would like to know is regarding the apertures of both lenses, how do you set those ?. i havent tried macro with two lenses before, i only have short focus prime lenses,from 50mm to 24mm, i dont suppose they would work very well together, would they ? ...
Gordon
http://www.justmacro.c​omexternal link
LordV
LordV's Avatar
Worthing UK
Mar 28, 2008 09:51 |  #6
Action_Man wrote in post #5209222external link
To reverse a lens onto another ideally you need a longer lens and a shorter focal length lens. For non macro lenses the Mag = focal length of camera lens/focal length of reversed lens. For a macro lens as the main longer lens then mag = as previous calc +1.
The aperture is controlled by the lens attached to the camera- the reversed lens is used wide open and focused on infinity.
Brian V.
Action_Man
Action_Man's Avatar
England, Nr Europe
Mar 28, 2008 10:39 |  #7
Yes i`ve tried it with two 50mms lenses, and its not recommended, the dof and vignetting are terrible :) ...
Gordon
Ballen ­ Photo
Moderator
Ballen Photo's Avatar
Joined Nov 2003
Southern Nevada and Idaho
Mar 28, 2008 10:55 |  #8
Thanks for this demonstration Brian, The capability of longer focus distance with the MPE-65 would make things easier IMO.
I've actually used the reverse lens idea when I was experimenting with macro, but if memory serves, was some what of a pita.
FWIW though, These two images compare favorably. :)
-Bruce
The Captain and crew finally got their stuff together, now if we can only remember where we left it. :cool:
newb2pro_1day_or_so
newb2pro_1day_or_so's Avatar
OH
Mar 28, 2008 11:15 as a reply to Ballen Photo's post |  #9
I think the MPE has a little bit of an edge on sharpness in comparison, but I actually like #1 better. The lighting doesn't seem quite as flat and the harshness is a little worse in number #1, making it more interesting as the ink is shown to be elevated with the harsh lighting. Very nice comparison as I have the canon 100mm and I bought a step ring for 12 bucks for my 50mm reversed. I as well went to an old camera store to pick up a 28mm with the same filter thread diameter as my 50mm to get a higher magnification...but that has RAZOR thin dof it's almost undesirable. Very nice comparison!
Dan, www.dandexterphotograp​hy.comexternal link
Canon 50D, 50 1.8 II, 100mm macro, Tubes, 430ex, 70-200 2.8 IS, 17-55 2.8 IS, MPE-65 & MT-24ex flash.
LordV
LordV's Avatar
Worthing UK
Mar 29, 2008 02:17 |  #10
Thanks for looking and commenting everybody :)
Dan whatever way you get high magnification you will get very thin DOF - comes with the territory.
Brian V.
Dalantech
Dalantech's Avatar
Bacoli, Italy
Mar 29, 2008 02:29 |  #11
Cool comparison Brian. What I'd like to see is a comparison of the two at F11 to see which combination focuses better at that aperture. The images that I've been taking at F11 between 3 to 5x have been pretty sharp with the MPE-65.
My Gallery (external link)
My Blog (external link)
Macro Tutorials (external link)
lance ­ v
lance v's Avatar
Levin nz
Mar 29, 2008 05:36 as a reply to Dalantech's post |  #12
now u just have to reverse a MP-E:rolleyes:
Flickrexternal link
Dalantech
Dalantech's Avatar
Bacoli, Italy
Mar 29, 2008 09:10 |  #13
lance v wrote in post #5215925external link
Actually I think that the MPE-65 is a reversed lens...
lance ­ v
lance v's Avatar
Levin nz
Mar 29, 2008 17:39 |  #14
Dalantech wrote in post #5216584external link
O....well thats no fun then lol
Flickrexternal link
macro ­ junkie
macro junkie's Avatar
Somerset - UK
Mar 29, 2008 18:49 |  #15
lance v wrote in post #5219202external link
u bought them diffusers yet u cheape skate :lol:
Uk prayingmantis forum - http://www.dragonscres​t.co.uk/forums/index.p​hpexternal link
My flickr gallery -http://www.flickr.com/​photos/hooked_on_macro​/external link
DA Gallery where i sell prints - http://macrojunkie.dev​iantart.com/external link
MPE-65MM - MT-24EX Twin Macro Flash (diffused with 2 X Gary Fong Puffer diffuser)
EF-S 60mm f2.8 USM - 430ex (diffused with lumeriqest soft box)
7,156 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00149 for 4 database queries.
PAGE COMPLETED IN 0.03s
Latest registered member is mrgas
976 guests, 526 members online
