Reply
Thread Tools Display Modes
Old 26th of June 2001 (Tue)   #1
AScare
Default LensMate+49-52mm step-up-ring
Will this combination (for my old pol-filter) obscure any "vital parts", such as focus-lamp etc.?
Asger Ellekrog, Denmark
AScare is offline   Reply With Quote
Old 28th of June 2001 (Thu)   #2
George
Default Re: LensMate+49-52mm step-up-ring
I just bought the LensMate and the 52mm step-up-ring and used it with my Nikon circular polarizing filter and didn't have a problem with it not working. However, I did have a difficult time trying to use the LCD to adjust it. I'm curious how others have dealt with this problem.
George is offline   Reply With Quote
Old 28th of June 2001 (Thu)   #3
ega1
Default Re: Re: LensMate+49-52mm step-up-ring
I find I can use the LCD to adjust the polarizing filter in situations where it makes much difference. For example, shooting bodies of water, I can definitely see glare reduction in the LCD.
Not as easy is trying to adjust for best sky color.
ega1 is offline   Reply With Quote
Old 29th of June 2001 (Fri)   #4
Bors
I just learned that to be most effective for the sky, it needs to point ~90 degrees from the sun. Point your index finger at the sun with your thumb straight out. Now rotate your thumb from horizon to horizon while keeping your index finger pointed at the sun. The arc described is where the polarizer will dramatically darken the sky. Point your polarizer at the sky along the line of your thumb and turn the filter. Should be pretty obvious on the LCD.
Bors
Bors is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Step Up Ring 52mm-77mm? tinpusher Accessories & Storage 9 22nd of April 2007 (Sun) 01:11
Bag for G3 and 52mm LensMate? Ogo- Canon G-series Digital Cameras 15 2nd of April 2003 (Wed) 01:37
