#1 |
The Record menu has three settings under Converter: (1) WC-DC58B, (2) TC-DC58C, (3) none.
I have the WC-DC 58B, and (except for its size and weight) really love it. But it's a pain to have to set the Converter menu, then set it back to none when I revert to normal shooting. And why bother? There is no difference in the recorded image, no matter what the setting selected. I've searched the Forum for an answer to this recurring question. Nobody seems to know what the Converter settings actually do. The Canon manual gives no clue. So I thought I'd start the thread again, this time with a title which should be a magnet for future discussions of this topic. Somebody must know the answer. The question also pertains to the A-series cameras, such as the A570. This also has the Converter menu. |
| sponsored links |
#2 |
I find if i leave my camera on the TC setting, it tends to take longer to focus on closer objects, if it focus at all.
If its a pain, i belive you can just use one of the two personal settings set for the WC. I use one for the TC, and one for Mirco settings. |
#3 |
You could program the converter under the shortcut button. Than the trouble of resetting is virtually non existing
Dino - 40D| 17-55 f2.8| 70-200 f4| Σ 30 f1.4 - S90 - Olympus OM-4ti | 28 f3.5| 50 f1.4| 135 F3.5 - -580EXII| 430EX (Manual mode beyond repair)| 2x 540EZ| Sunpack PZ40x |
| sponsored links |
#4 |
#5 | |
That the only option left is to program c1/c2 with the appropriate converter. Or maybe it is something for a firmware update
#6 |
#7 |
Moderator
I can not say what the converter settings do in the G9, but as a clue I can describe what they do on my Pro1:
I have not detected changes while focusing. I am almost sure that, if I manually use the zoom within the described ranges, I can leave the converter setting set to ‘none’ without adverse effects.
rafael Canon powershot Pro1, EOS RebelXT, EF-S 18-55mm II, speedlite 420EX, basic filters set. My photo galleries "PERSONAL MESSAGING REGARDING SELLING OR BUYING ITEMS WITH MEMBERS WHO HAVE NO POSTS IN FORUMS AND/OR WHO YOU DO NOT KNOW FROM FORUMS IS HEREBY DECLARED STRICTLY STUPID AND YOU WILL GET BURNED."
#8 |
On the G7 and A570IS (two cameras which I own) the Converter menu settings impose no limitations on the zoom range. It would make sense if they did limit the zoom, as you describe for the Pro 1. That's what I would have expected, but somehow that didn't get programmed onto the chip.
#9 |
Looks like I'm talking to myself, here.
I still do not know exactly what the Converter menu setting accomplishes, but I have a new clue. The User Guide implies that the menu selections are implemented when the camera is in IS mode. And in fact I now can see that when IS is selected the screen icon changes, depending on IS mode and Converter menu setting. So it may be that the Converter setting is used only to affect the Image Stabilization controller. |
#10 |
I can't remember where I read about this. But I thought selecting the wide or teleconverter setting was to allow the image stabilization to work correctly. The amount of image stabilization used by the camera depends on the focal point of the lens.
| Thread Tools | |
| Display Modes | |
| 40D Custom Functions and Menu settings...What's yours | S2000 | Canon EOS Digital Cameras | 8 | 2nd of October 2007 (Tue) 11:18 |
| S2 Converter menu setting - necessary? | 2Shiny | Small Compact Digitals by Canon | 8 | 17th of July 2007 (Tue) 09:06 |
| Canon S3 IS converter menu | yaga darvin | Small Compact Digitals by Canon | 2 | 14th of May 2007 (Mon) 18:23 |
| 20D QUALITY MENU SETTINGS ?? Can somebody help? | Malbuddy | Canon EOS Digital Cameras | 5 | 13th of November 2005 (Sun) 14:18 |
| S2 IS Converter Menu Settings? | Robertson Bruce | Small Compact Digitals by Canon | 4 | 29th of September 2005 (Thu) 22:27 |
