#1 |
I am having a problem with shooting indoors... (just family/birthday pictures).
Even if I set my aperature wide open, my shutter speed needs to be so low that I can not handhold the camera. When I use a flash the shutter speed stays the same... What am I doing wrong? How do I get the best setting? (I would prefer to handhold the camera...) Thanks! |
| sponsored links |
#2 | |
A better approach to using the flash is to shoot in M mode. Simply set the aperture for a reasonable DOF (try f/5.6 to start) and a fast enough shutter speed (say 1/100). Use ISO400 and take some shots. The flash will automatially expose the shot. If you don't like the results you can fine tune the flash exposure by adjusting the Flash Exposure Compensation.
My personal stuff:http://www.flickr.com/photos/jngirbach/ Commercial sports:http://girbach.zenfolio.com/ I use a Canon 5D and 1DIV and a Panasonic GF-1 Gear List: http://photography-on-the.net/forum/...postcount=1550 |
#3 |
Can you give specific settings. "wide open" depends on the lens. What flash are you using? (is it the built in or an external one)
Here is a link to a 3 part document on how Canon flash operates. It's well worth printing. http://photonotes.org/articles/eos-flash/ |
| sponsored links |
#4 | |
Tamron 18-250 3.5-6.3 Speedlite 580EXII |
#5 | |
#6 | |
Moderator
Use high ISO...
I never use Tv, and don't see any advantage in flash photography. Use either Av or M.
"I think the idea of art kills creativity" - Douglas Adams Why Color Management. Color Problems? Click here. MySpace Get Colormanaged PERSONAL MESSAGING REGARDING SELLING OR BUYING ITEMS WITH MEMBERS WHO HAVE NO POSTS IN FORUMS AND/OR WHO YOU DO NOT KNOW FROM FORUMS IS HEREBY DECLARED STRICTLY STUPID AND YOU WILL GET BURNED.
#7 | |
Tv can sometimes be tricked into working better with flash, mainly because once it has opened the lens up all the way it starts to underexpose....then E-TTL kicks in and exposes the shot. The reason Canon does this is that they fully expect you to select M mode when you are shooting with a flash. If Av and Tv modes did not assume "fill-in" then there would be no auto-metered modes that work with fill flash. BTW, if you never use fill flash you can set one of the custom functions to always set the shutter speed in AV mode = max synch speed when the flash is turned on. On my 5D it is function 3-1.
My personal stuff:http://www.flickr.com/photos/jngirbach/ Commercial sports:http://girbach.zenfolio.com/ I use a Canon 5D and 1DIV and a Panasonic GF-1 Gear List: http://photography-on-the.net/forum/...postcount=1550 Last edited by JeffreyG : 30th of March 2008 (Sun) at 14:12. |
#8 |
Great - thank you so much for that. That would explain a lot of frustration I've had while using my external flash! I will definitely start to try manual - and perhaps use Av when I need fill. I used to only use my pop-up for fill, but I know it's not the best route to take.
#9 | |
Just be careful the pop-up has enough reach. People are often shooting stopped down and low ISO in the daylight, and they forget that the flash does not care about how sunny it is. Flash reach only cares about Guide Number, Aperture and ISO.
#10 | |
#11 | |
The distance your flash can reach is equal to the GN/Aperture at ISO100. Every two stops higher in ISO doubles the reach. So f/4 and ISO100 cannot reach more than 11 meters with the 430EX or 3.25 meters with the pop-up. Where people run into trouble is shooting group shots outside with a pop-up. There you are shooting f/8 and ISO100 because it is so bright out. Pop-up the ol' flash for some fill and become puzzled because it can only illumnate people standing within 1.6 meters (5.5 feet) of the camera.
#12 |
Holy cow. I am hauling my 430 around from now on! Now I just need to invest in better batteries. I really think this has helped me to understand a lot about my flash troubles. Thanks again.
#13 | |
Flash draws lots of power. Disposable batteries are more expensive in the long run. Leave the alkalines for the TV remote and the thermostat.
#14 |
Yes, I have those. I believe my husband has stolen them to either put in a toy, or the tv remote. I'll have to steal them back and get four more for back-up.
#15 |
Do yourself a big favour and use Eneloop batteries for your flash - they won't lose charge if sitting in the bag like most NiMH's do.
For indoor flash situations where you want flash as main lighting P mode works well also - shutter speed won't go below 1/60 and flash will be the main lighting. Also for outdoor fill flash in many sunny situations the shutter speed will be higher than the max sync speed of the flash/camera (1/250 for most Canon's) and pictures will be overexposed unless you use high speed sync on the flash (not possible with pop-up flash).
Mark My Smugmug Eos 7D, Canon 15-85 IS, Canon 17-85 IS, Sigma 100-300 EX IF HSM, Canon 50mm 1.8, Canon 85mm 1.8, Canon 100mm 2.8 Macro, Sigma 50-150 2.8, Sigma 1.4 EX DG , Sigma 24-70 F2.8 DG Macro, Canon EF-S 10-22, Canon 430EX, |
| Thread Tools | |
| Display Modes | |
| Best lens for indoor family pictures? | kerry0621 | Canon EF and EF-S Lenses | 33 | 16th of November 2007 (Fri) 19:19 |
| Indoor pictures at a club | SonicYan | People | 4 | 19th of January 2006 (Thu) 13:49 |
| Indoor pictures without flash - G5 | heksa | Canon G-series Digital Cameras | 20 | 15th of November 2004 (Mon) 09:54 |
| Indoor pictures. | 93octane | Canon EOS Digital Cameras | 13 | 18th of June 2004 (Fri) 03:45 |
| blurred indoor group pictures | roanjohn | Canon G-series Digital Cameras | 20 | 23rd of December 2003 (Tue) 22:22 |
