Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > General Photography Talk
Reply
Thread Tools Display Modes
Old 31st of March 2008 (Mon)   #1
crammy
Default New to HDR
I just started experimenting with HDR imaging. I bought the photomatix which seems to be a good program, however, I am struggling a little with the details of it. How do you make an image look smooth? (almost like a painting). Also, once you combine your three images into the HDR image, should the image look enhanced or pretty close to the original. My tone mapping has 2 pages, tone enhancer and tone compressor which process separately. Should I be doing both ? I probably sound like a stumbling idiot but I'm very interested in HDR imaging and want to figure out what I'm doing wrong. I got lucky on my first try and made an ok image but now I can't reproduce whatever I did. Any tips would be helpful.. thx
crammy is offline   Reply With Quote
Old 1st of April 2008 (Tue)   #2
Boucher
Boucher's Avatar
Default Re: New to HDR
I only use detail enhancer.
The main sliders you should look out for is Strength, Light smoothing, luminosity, micro smoothing and micro contrast. I also tweak the white and black point different for every image.
The way I learned was through this site:
http://www.vanilladays.com/hdr-guide/
and through trial and error. Have a muck around with the program and see what the different things do.
boucher.
Josh Boucher | Flickr | DeviantArt
Boucher is offline   Reply With Quote
Old 1st of April 2008 (Tue)   #3
Cody21
Cody21's Avatar
I keep reading about HDR .... does Photoshop CS2 provide this ability? or is a separate software package required?
5DM3 | 16-35mm f/2.8L II USM | 70-200mm IS f/4L | 24-105 f/4L | Sigma 18-50mm f2.8 | Speedlite 430EX
Cody21 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Help with HDR? aduda RAW, Post Processing and Printing 2 18th of February 2008 (Mon) 11:13
my try at HDR steve535 Nature & Landscapes 14 4th of February 2008 (Mon) 05:43
Trying HDR LeuceDeuce Critique Corner 9 31st of December 2007 (Mon) 19:33
First go @ HDR bcap RAW, Post Processing and Printing 13 11th of May 2007 (Fri) 22:46
HDR manualy done -no photomatix, no Merge to HDR chansh Still Life, B/W & Experimental 10 19th of May 2006 (Fri) 14:30
