#1 |
I shoot everything from sports to weddings and am a little nervous about loosing images on a large card (a lot to loose) 16G
The other point that I have heard is that alot of the time, problems are from changing cards, and the less you have to open, remove, replace, the less chance of problems. What are your thoughts?
www.TotalPhoto.ca Canada's Official Nascar Photographer Obama Book http://www.blurb.com/bookstore/detail/562084 |
| sponsored links |
#2 |
Moderator
Cocker Spaniel Mod Join Date: Jun 2004
My concern is keeping the number of photos on a card manageable; around 200-250 seems enough. For my cameras, that's 4 GB, which conveniently makes a nice DVD backup too.
Jon ---------- EOS, Powershot and Domke - it doesn't get any better than this!
T90 and stuff | F-1n, New F-1, FTb and more stuff out on loan Cocker Spaniels Maryland and Virginia activities DC Cherry Blossoms Image Posting Rules and Image Posting FAQ Report SPAM, Don't Answer It! (link) PERSONAL MESSAGING REGARDING SELLING OR BUYING ITEMS WITH MEMBERS WHO HAVE NO POSTS IN FORUMS AND/OR WHO YOU DO NOT KNOW FROM FORUMS IS HEREBY DECLARED STRICTLY STUPID AND YOU WILL GET BURNED. |
#3 |
Well, that is one way to look at it. But you can also worry about losing cards (if you have several) or bending a pin in the camera while you are changing cards. My solution was to go with two large cards in my 1DsIII. That way if one corrupts I have another but I dont have to change cards or carry spares. Of course that only works with 1-series bodies.
My Gear |
| sponsored links |
#4 |
I just bought a 1Ds Mark2, files are crazy large! Thus my question...
Thanks!
#5 | |
"I am not the final word"
ed rader |
#6 |
I want to have a 16G sd for sure, just do not know if I should get 8G, 12G or 16G CF cards
#7 |
I use CF card to catch RAWs and the SDHC for JPEGs. Thus, I use a 8GB CF and 4GB SD. The CF holds 300 RAWs and the SD hold 400 or so JPEGs. If you do the same then select the largest card for RAWs. If you put the same on both cards then I would get two of the same size cards.
My Gear |
#8 |
Thank Mebailey, never looked at it that way. Just a quick queastion, My camera will hold and use 16G cf & 16G sd right? Wast reading some of the 1ds cameras would not take the 16G sd cards only 12G. My camera is a 1Ds mark2. Just want to make sure!
#9 |
Iam pretty sure 1DsII will take SDHC (16G) with a recent firmware update 1.1.6 which was available in Dec 2007 from Canon website.1.1.61.1.61.1.6
My Gear |
#10 |
On mine it says "card containing firmware is required to update" I guess that means my camera will not take them until it is updated? Is it easy to do?
#11 |
FROM CANON
VERSION 1.1.6 Dear PowerShot EOS 1Ds Mark II Owner: Thank you very much for purchasing the Canon EOS 1Ds Mark II Digital Camera. As a part of our ongoing commitment to maintaining the highest standards of product performance and customer support, we are taking this opportunity to inform you of a new firmware update for the EOS 1Ds Mark II. This firmware update (version 1.1.6) includes the following improvements: Fix the phenomenon wherein the camera does not detect the capacity correctly when high-capacity recording media are initialized. This firmware update applies to cameras with firmware version up to 1.1.5 installed. If your camera's firmware is already version 1.1.6, it is not necessary to perform this update.
#12 | |
Was there enough info there to answer your questions?
My Gear |
#13 |
Moderator
If you haven't got firmware 1.1.6 on your camera, you're limited to whatever the version you do have will support. What the statement "card containing firmware is required to update" means is that you must load the firmware (the *.fir file; goes on the card's root directory) onto a recognized card (generally recommended to be under 2 GB, but this may well be for legacy reasons) in order to perform the upgrade. You can't upgrade via a cable connection.
| Thread Tools | |
| Display Modes | |
| newbie question about used lenses & warranty cards | eyes_not_tech | Canon EF and EF-S Lenses | 2 | 25th of February 2007 (Sun) 20:51 |
| Cheap and Large CF Cards? | jcw122 | Accessories & Storage | 16 | 11th of January 2007 (Thu) 11:38 |
| 1Ds Large Memory Cards | steven | Canon EOS Digital Cameras | 6 | 30th of December 2006 (Sat) 04:25 |
| Two Smaller Cards or One Large | shutterghost | Accessories & Storage | 18 | 14th of June 2006 (Wed) 12:36 |
