Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Macro Talk
Reply
Thread Tools Display Modes
Old 9th of April 2008 (Wed)   #1
frjeff
Default Macro Lens Question
In my ongoing debate on which macro lens to buy, the following question:
I know that the Canon 100mm does not extend (which seems to my feeble mind to be an advantage).
Do the Tamron 90mm and the Sigma 105mm both extend then?
The advantage to non-extending is?
Fr. Jeff+
50D; Sigma 10-20 f/4-5.6; EF-S 18-55 IS; 50,f/1.8 II; Canon 60mm f/2.8 Macro; Tamron 28-75 f/2.8; Canon 70-200 f/4L; Canon 430EX II, Kenco Extensions -
Flickr
frjeff is offline   Reply With Quote
Old 9th of April 2008 (Wed)   #2
Lester Wareham
Moderator
Lester Wareham's Avatar
Default Re: Macro Lens Question
You might find this of interest http://translate.google.com/translat...language_tools and this http://www.zen20934.zen.co.uk/photog...m#Lens%20Table
So to answer your question, yes and yes. The first link tells you by how much.
The advantage is in handling (macro lenses with OLE get a lot longer) and less likely to scare bugs. You can manage however ie the MP-E 65mm which extends by a factor of 3.
My Photography Home Page RSS Feed
MP-E, EF 100mm, EF 180mm : The Macro Dark Unholy Trinity : Bow down before their darkness and despair!
Macrophotography by LordV
Lester Wareham is offline   Reply With Quote
Old 9th of April 2008 (Wed)   #3
gasrocks
gasrocks's Avatar
If your lens is IF (internal focus) and does not change in length as you focus, then the f/stops are true at any distance. Many macros do extend and the marked aperture is wrong at close distances. Comes into play if you ever were going to shoot in full manual, perhaps. My Sigma 150/2.8 Macro lens comes with hood and collar, front does not rotate, lens does not change in length - the way all lenses should be.
gasrocks is offline   Reply With Quote
Old 9th of April 2008 (Wed)   #4
Lester Wareham
Moderator
This not true, you will still meter a light loss with the Canon 100mm.
Old 9th of April 2008 (Wed)   #5
gasrocks
gasrocks's Avatar
Another reason to get the Sigma.
Old 9th of April 2008 (Wed)   #6
Lester Wareham
Moderator
Hmmm 895g vs 600g, quite a big deal for handholding and only a small gain in WD, each to their own.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Macro Lens question... Dylanlewis2000 Canon EF and EF-S Lenses 2 2nd of January 2007 (Tue) 18:42
macro lens question Fureinku Canon EF and EF-S Lenses 15 8th of September 2006 (Fri) 21:45
Macro lens question Onwuma Canon EF and EF-S Lenses 6 25th of June 2006 (Sun) 20:02
Macro lens question JoseC Macro 3 19th of March 2006 (Sun) 16:44
Macro Lens Question Please Spencerj General Photography Talk 4 17th of January 2006 (Tue) 08:30
