Thread started 11 Apr 2008 (Friday) 21:20
Prev/next
An Easier UniWB for EOS Digital Cameras (at least the XT)
E-K
Canada
Apr 11, 2008 21:20 |  #1
There are a few threads here and elsewhere on the internet discussing UniWB. Briefly, UniWB provides a mechanism that results in no (or very little) adjustment to the individual colour channels when the camera creates the embedded JPEG on which the camera's histogram is based.
This in theory provides a more accurate representation of what is actually happening with the raw data -- useful when trying to expose to the right.
Guillermo Luijk provides an excellent analysis at http://www.guillermolu​ijk.com/article/uniwb/​index.htmexternal link.
Now if you run PhotoBola's Raw Image Analysis tool on the sample UniWB images in the above link you will notice that for the areas of interest the raw values for each of the channels are essentially equal.
This is effectively what we are striving for. When you set a custom WB in the camera, you are asking the camera to figure out how it needs to adjust the raw data for the provided custom WB image to make these channels equal (i.e. white/gray). If the channels equal each other in the CWB image, than the camera thinks it doesn't need to adjust anything as for the given "lighting condition" the image is already gray.
G. Luijk's method does work, but it requires a little effort to execute. I'm lazy, so I looked for an easier solution ;).
Now I can think of two other "naturally" occurring scenarios where channels will have equal values (or approximately equal): a dark frame and a completely saturated frame.
Using the PB Raw Image Analysis tool on a dark frame and saturated frame returned average RGGB values of (255, 255, 255, 255) and (4095, 4095, 4095, 4095) respectively. The dark frame had more variance in values whereas the saturated frame was 4095 all the way through.
So far so good. Now the only thing to see was if the camera would take these images for use as a custom WB. On the Rebel XT, the answer is yes in both cases.
Using the dark frame resulted in WB coefficients for an image of (1.006, 1.000, 1.006). The saturated frame resulted in WB coefficients for an image of (1.008, 1.000, 1.004).
The obvious benefit with the dark frame is that you can do it at any point in case you lost your UniWB image/setting -- just shoot a frame with the lens cap on. The saturation method is a little more difficult as sometimes it can be difficult to achieve full saturation in all channels for some lighting conditions. For mine, I used a flash.
I would be interested to know if any other camera models can apply the same method.
e-k
tdodd
tdodd's Avatar
Essex, UK
Apr 12, 2008 07:27 |  #2
I tried your approach described above and found that the dark image gave results close to the uniWB balance - certainly the green cast is there - but the white image seems to have been recorded using a default WB that is equivalent to the daylight balance.
Here are comparative shots in LR and DPP of the white and black calibration images and a "real world" scene photographed with my uniWB, the light-uniWB and the dark-uniWB. Unfortunately the light conditions altered just a little from shot to shot - we have mixed sun and cloud here at the moment so light levels are fluctuating. I'll have to perform a more controlled test to really check the results out properly.
tzalman
Fatal attraction.
tzalman's Avatar
Gesher Haziv, Israel
Apr 12, 2008 08:42 |  #3
Very clever, E-K. On the basis of the 40D histogram I can't see much difference from panopeeper's CWB, using the blackframe method.
Elie / אלי
RebelTasha
Apr 12, 2008 08:47 |  #4
This is waaay over my head but it sounds interesting...
Rebel XT Flickrexternal link
Rebel 35mm Portfolioexternal link
E-K
Canada
Apr 12, 2008 14:21 |  #5
tdodd wrote in post #5312923external link
Do you mean the recorded raw values for the saturated image are not (4095, 4095, 4095) or that it did but when you used it for CWB it produced a result similar to daylight balance?
It's a pain to get the channels fully saturated. I had to use ISO 1600 and a flash on a white wall. ISO 100 was problematic as was trying to use a CF bulb (blue channel wouldn't saturate).
Thanks for giving it a try.
e-k
_GUI_
_GUI_'s Avatar
Madrid (Spain)
Apr 12, 2008 14:27 |  #6
E-K, I am Guillermo Luijk. Congratulations, you have achieved in about 10secs what took me a whole night to generate, and in addition to this I achieved a more precise UniWB for my Canon 350D with a saturated shot:
multipliers 1.006856 1.000000 1.005877 1.000000
0.69% deviation for the R channel is the max error, the closest to a perfect neutral WB I can achieve (probably because of some hot pixels or whatever).
It works fine for my camera. Please tell me your name so I can credit you in the original article.
http://www.guillermolu​ijk.comexternal link to subscribe click hereexternal link
Perry ­ Ge
Batteries? We don't need no...   . . . or cards.
Perry Ge's Avatar
Gallery: 83 photos
Hong Kong
Apr 12, 2008 14:33 |  #7
Oh that is COOOOOL. Thanks a lot for sharing this - perhaps the biggest challenge in exposing to the right is getting the embedded JPEG histogram to accurately reflect the channels in RAW, and this is a cool solution.
Perry | www.perryge.com (external link) | flickr (external link) | C&C always welcome | Market Feedback & Gear | Sharpening sticky | Perspective sticky
tdodd
tdodd's Avatar
Essex, UK
Apr 12, 2008 14:35 |  #8
E-K wrote in post #5314703 (external link)
e-k
Here are screen prints from rawanalyze. As far as I can tell I have blown everything. I attempted to white balance within the rawanalyze software and got perfect multipliers of 1.0000 for all channels.
When I used ExifTool to check out the white balance data that had been recorded in the exif - the data which I believe is actually used by software to work out white balance adjustments - the "measured" white balance values were exactly equivalent to those for daylight.
tdodd
tdodd's Avatar
Essex, UK
Apr 12, 2008 14:36 |  #9
Here is the RGB WB data in the exif information from the blown image (first attachment). You will note that the RGGB values are identical for "Auto", "Measured" and "Daylight".
The same data from my custom uniWB file (second attachment) clearly shows the nearly equal values for "Measured", which are very different from the "Daylight" values.
tdodd
tdodd's Avatar
Essex, UK
Apr 12, 2008 15:18 |  #10
I've looked further with rawnalyze and, if I'm reading the stats correctly, it seems that every single one of my sub-pixels is at 4071. I don't know the significance of that information. I guess it means that every single sub-pixel was as saturated as could be, but for some reason the sub-pixels top out at 4071 instead of 4095. What consequences would that have for attempting an easy uniWB with oversaturation?
Here's a screen print....
_GUI_
_GUI_'s Avatar
Madrid (Spain)
Apr 12, 2008 15:22 |  #11
tdodd wrote in post #5314963external link
Don't be surprised for this, some cameras do not saturate at the max value of their expected integer range (2^n-1 for a n-bits camera). Some saturation points:
- Canon 350D: 4095
- Canon 30D: 3398
- Canon 5D: 3919
- Canon 40D: 13823
The important thing is that R=G=B in your RAW file so the UniWB should be properly calculated; try it. Then shoot anything and check the resulting multipliers (this can be done with DCRAW doing: dcraw -v -w foto.cr2)
E-K
Canada
Apr 16, 2008 07:46 |  #12
_GUI_ wrote in post #5314737external link
Glad it works for you. I'm not worried about the credit but if you want to put something then just say e-k on the POTN forum or some such.
e-k
E-K
Canada
May 07, 2008 08:15 |  #13
tdodd wrote in post #5314776external link
Sorry to dredge this up, but when you used the saturated images as the CWB image. For images you shot using it as the CWB, what was the "As Shot RGGB Levels" set to?
e-k
tdodd
tdodd's Avatar
Essex, UK
May 07, 2008 08:57 |  #14
I just shot a fresh blown image with my 40D (the previous efforts above, which seemed not to work properly with the blown image, were shot with my 30D) - 30" exposure at f/5.6 and 200 ISO, waving the lens in the general direction of the sun on a clear day. I then used this image to set a custom WB and the camera warned me that the image might not be suitable for WB but I went ahead anyway and then fired a sample "real world" shot. Here are the results....
Blown image
Raw Image Analyse gives RGB coefficients of 1.0000, 1.0008, 1.0015
Exif Tool give "As Shot" values of 1045, 1039, 1039, 1052
Real world image with blown custom WB
Exif Tool give "As Shot" values of 1024, 1037, 1037, 1024
Maybe these figures suggest that the blown uni-WB does work after all, at least for the 40D.
Here is the image and histogram for the blown image and the "real world" image. I did not take care to maximise exposure with the real world shot - I just pointed the camera and centred the exposure meter manually.
tdodd
tdodd's Avatar
Essex, UK
May 07, 2008 09:00 |  #15
Here's the real world image after setting the WB to the daylight preset in Lightroom. No other edits/adjustments.
52,440 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00102 for 4 database queries.
PAGE COMPLETED IN 0.04s
Latest registered member is ashleyrose315
740 guests, 294 members online
Simultaneous users record so far is 6106, that happened on Jun 09, 2016
